I have a 32 inch Vizio LCD and lost the picture. I replaced the power board and he main board as well as a wire harness that I pullled apart by mistake. Now I have great picture but no sound. I have had the sound come on for a minute then stop. Is this a problem with the main board or somthing else?
  • dotson1799 Jul 22, 2008
    No, there are no lose wires.The wire harness I mentioned has been replaced and has connections on both ends that are firmly in place. I wish it were as easy as connecting a lose wire.
    Genius:
  • 1,011 Answers
Sir,
This is the problem that u pulled wire by mistake. That wire is to be soldered. Or check the wire is to be loosely or not? check the board is there is any going sound output wire is loosely fitted?
Thanks
Good luck
"Don't forget to rate the solution"
Posted on Jul 20, 2008
    Scholar:
  • 191 Answers
Yes you need to resolder the wire on the main board. that will take care of the issue
Vizio VL320M Vizio badge lights and turns blue, but no picture and no sound. Both power and main board have no burned parts or swollen caps. Fuse F1 is good.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 15, 2016 | Vizio VL320M 32 in. HDTV LCD TV
How to fix black screen
Logic board fault. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 10, 2015 | VIZIO E320i B2 32 Inch 720p Smart
What is the purpose of tickon board in samsung 32
T-con board takes the serial video data from the main board and converts it to a format that the LCD panel will understand. The T-con also supplies power to the panel.
Aug 28, 2013 | Vizio 42 in. LCD TV
No picture no sound on a Vizio HDTV10A. The green light comes on then turns to amber after a couple of seconds
your Main board went bad, common issue with these units. Need to be replaced, in tv land it called main board in computer world mother board. your unit has only two boards power board and that is good cause you get a amber to green to amber led. good luck Vizio field tech
Feb 01, 2013 | Vizio 32" l32 hdtv 10a high definition...
No picture or sound and tv won't turn off
Check and replace its main power regulator board as card basis.
Sep 21, 2012 | Vizio L32 32 in. LCD HDTV
No picture at all. had no problems until last night, turned TV on, and no picture. TV is VIZIO 32 inch LCD
Do you still get sound? If you do get sound, then the problem can be in the backlight inverter board or in the main power supply that supply 24vdc to the inverter board.
Oct 30, 2009 | Vizio L32 32 in. LCD HDTV
32" VIZIO PROBLEMS
The main board is bad. I have seen a lot of TV has the same problem like you have. Replace main board will fix it. If you bought these TV from Costco and less than 2 years then they all still under warranty.
May 05, 2009 | Vizio L32 32 in. LCD HDTV
Picture goes black, but audio stays on ????
Well i have the same tv , and when i took it apart i switched a few wires around and i managed to get it working again, i can send some pictures of what i did because, i really had no clue what i exactly did by switching the wires.
Jul 26, 2007 | Vizio L30WGU 30 in. HD-Ready LCD...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
