Every time I try to print with my HP 1300 - I get an error message saying problem with black toner cartridge. I have swapped the cartridge with no improvement
  • 19,396 Answers
Try a new cartridge, if cartridge is ok, usually you have a problem with fuser lamp, replace the fuser.
Posted on Jul 20, 2008
  • Ginko
    Ginko Jul 20, 2008
    Ensure that it is not just a bad cartridge, try a new original cartridge, as re-manufactured or regenerated toners sometimes can give you this kind of troubles.
    Once you are sure that the problem is not really the toner cartridge, then is usually the fuser lamp that is not generating enough heat. Replace the fuser.
    Here is the replacement for your printer: Hewlett Packard Laserjet 1300 Maintenanc
I have a HP Color Laserjet 2025. I recently replaced the color cartridges and when I tried to replace the black toner cartridge I got the message - "remove the shipping lock on the black toner...
My suggestion is to put the 2 cartridges next to each other and look at them as closely as you can. There has to be a difference between the one that works and the ones that give the error.
Something that just occurred to me. Check the slot where the black cartridge sits. Check it for something that could have fallen off the original cartridge and is wedged in the slot. Compare the slot with another cartridges slot.
Because one cartridge works and others don't, it tells me it's a physical(hardware) problem not electrical.
Jul 07, 2011 | Office Equipment & Supplies
How can i clean the print heads of my HP 1300...i need to print an important report this minute..
The HP LaserJet 1300 does not have a print head. If you are having print quality issues then 9 times out of 10 it is coming from the toner cartridge. Simply swap it out if you have a spare. The only other possible cause is a bad fuser film which can cause double imaging or a problem where some of the print from the top part of a page is reprinted lighter at the middle or bottom of a page.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | HP LaserJet 1300 Printer
10.1000 Supply Memory error. How can I fix that?
sounds like might be your toner, specifically your black toner.
is this a non-standard toner or HP? IF it your toner you can try this:
Place a stip of opaqe tape or paper or the chip. When the printer detects a non-standard cartridge press the green (go) button. It will then reset the LCD to Ready.
Found this info on a recycled manufacturer site. http://www.infinityimaging.com/cgi-local/SoftCart.exe/online-store/scstore/p-2300.html?E+scstore
otherwise it's probably the memory on the printer, try removing or replacing a DIMM
Jun 09, 2010 | HP LaserJet M1522nf Multifunction Printer...
Please remove shipping lock from yellow cartdrige
I'm not sure this will apply to all instances of this, but we had the same problem on a CP1515n. I tried cleaning contacts and waving the cartridge about, to no avail.
I then found a message from an HP employee in another forum saying to swap the yellow with another colour, start the machine and then swap them back. I swapped it with the magenta and the printer went through quite a long initialization process eventually saying "incorrect supplies". I swapped them back and it worked.
Jan 29, 2009 | Office Equipment & Supplies
I have a HP 6656A Printer Cartridge that sometimes works good and other times will fail the power on check. Error message varies between Ink Cartridge not compatabile, Check Color Cartridge (even though...
I got hold of another set of 56 and 57 Ink cartridges. By swapping the four of them in and out of two printers, I determined that one of the Black 57 cartridges was bad and caused a missleading error message to pop up saying to check the Color 57 cartridge. I don't know why I was getting different messages at first, but after several swaps in and out of two printers, the error message finally became consistant and I learned that the one Black 56 cartridge was the faulty guy. One Color 57 cartridge printed good but the other (newer one) left streaks on the Cyan and Magenta colors even after soaking the head surface for a few minutes and cleaning it with inkjet cleaner fluid.
The end result is that I have one good Color 57 cartridge and one good Black 56 cartridge which work good in two different printers.
By the way, can you email a labled pinout reference drawing of the hp56, 57 & 58 Ink Cartridges???
Reggie Bostwick
Jul 07, 2008 | HP Office Equipment & Supplies
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Laser cartridges with chips
you need to replace the chips so it will read the amount of pages printed by the toner cartridge.This chip is only for measuring how many pages printed.
Mar 30, 2007 | HP Q2613A OEM Genuine Black Laser Toner...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
