Question about Roper RAB2121KW Top Load Washer
Where's the pump?
How do I get to the pump?
Thanks.
  • 770 Answers
You will need to remove the 2 screws holding thwe contreol panel they are in the rear at an angle on the two plastic sides then the console will filp up like a car hood after that unplug the lid switch and release the 2 spring clips on both sides the cabniet will then slide forward and off you will see the pump at the bottom front
Posted on Jul 30, 2008
The pump will rum on first stage but is tripping power on second speed
Hi Martin, Thanks for the question. It sounds as though the pump relay or the pump itself is fried. I would recommend calling a service technician. If you know how to check voltage yourself, use a multimeter or (fluke meter) to test the voltage between the pump relay. if that reads normal then test the pump itself. It could be the difference between buying a new pump, or a new spa pack. I hope this helps, Thanks again!
Feb 16, 2014 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
My 1996 dodge neon is not getting any fuel to the system. theres gas in the car a brand new fuel pump and filter. what could be wrong?
Thanks for choosing FixYa and welcome to the site. Fuel is pumped out of the tank by the fuel pump. It then goes to the fuel filter. Then, it goes through the gas lines to the injectors and engine. You need to scan your gas lines and make sure they are not damaged or clogged. If the lines are ok, you need to check your injectors. Check your fuel pump fuse/relays and reset button, if equipped. I am guessing the car will not start? Thanks for using FixYa.
Apr 10, 2011 | Dodge Neon Cars & Trucks
I have to replace fuel pump, do you have a procdure to replace fuel pump in 2001 focus wagon, 2.0 split port engine. thanks.
There is a complete guide to remove and install fuel pump.Its a complete procedure.Click this link directly:---- http://technoanswers.blogspot.com/2011/04/how-to-replace-fuel-pump-on-2001ford.html -------------------- Read the instructions mentioned and follow it properly.This will help to replace the fuel pump .Thanks.Helpmech.
Apr 05, 2011 | 2001 Ford Focus
Hi I have a hotpoint ultima it is showing f11 could you tell me what it means Thanks
F11 - No pump connection.The drain pump is either blocked or drain pump is loose or drain pump hoses are loose .Or the drain pump connections are faulty. The error f-11 is related to drain pump and its connections,. ----------- You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Hotpoint Ultima WF860 Front Load Washer
E1 error, pump spinning but not pumping
Just replaced wash pump unit
Thanks anyway
Ernie
Jun 11, 2009 | LG LDF6810ST Stainless Steel Built-in...
Kenmore 90 series washer is leaking water from the pump. How do I remove the pump to repair or replace? Thanks!
Hi, You can change the pump by disconnecting power, water fill hoses, & take drain hose out od drain. Lay the washer on its back (use some padding under machine so that you do not damage threads on inlet valve. The pump is located on motor and has two clamps holding it. Just remove those clamps and the two drain hoses from the pump. The pump should release from the motor shaft. If the motor shaft is rusty, the pump might not want to come off ease and the shaft will need to be cleaned with sand paper or emery cloth so the new pump will go on easy. Failure to get the pump on all the way will cause the new pump to leak also.
Put your hoses back on the pump and everything should be ok.
I hope this helps you some.
Vic
May 10, 2009 | Washing Machines
Vacuum pump oil
If you are using 6CFM vacuum pump then it's need 16 OZ.of oil & you should change every 10 Hrs of vacuuming.You can use Yello jacket vacuum pump oil also.
Feb 02, 2009 | Robinair 13204 Premium High Vacuum Pump...
High pitch noise when Maytag washer is in spin cycle, sounds like metal on metal
hi. thanks for the question. the problem you are having is with the water pump . some piece of metal or plastic is in the pump .check the water pump. thanks the appliance doc
Oct 01, 2008 | Maytag Washing Machines
Leaking out the bottom of the washer
thanks for the question Tip the washer back to the wall now you can see underneath the pump is right there at the front if you see the pump leaking replace the pump thanks for the question The appliance doc
Aug 03, 2008 | KitchenAid KAWS850L Top Load Washer
Roper RAB2121KW Top Load Washer Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
