Question about Karcher 2500 PSI Pressure Washer
I squeeze the trigger, I have pressure for 2-3 seconds and the engine dies.
I have removed the piston and spread white lithium grease all over it and put back together and that did not work. I am connected to a garden house and assume that I have a high enough volume of water running through the system. The pressure washer is about 8 months old and the previous owner used it one time about 6 month ago. I started it up 3 days ago and used it for about 20 minutes. The pressure was intermittent then at first but then was constant and was running fine. I ran out of gas. I put new gas into it a couple days later and have had this problem every since. I used regular gas instead of premium....could be part of the problem.
  • 33 Answers
Your pump is probably cavatating. when you first hook it up and turn hose on open thr trigger and let water run thru until it quits spitting and flows smooth. then crank it up and see if this gets it done. if not you could have a problem with the pressure valve bolted on the outside of pump. there should be a nut shaped stem to adjust pressure . turn it in and see what happens.
Posted on Apr 21, 2009
How do i stop it from pulsing?
Getting to much air to carb probably.
Jul 11, 2015 | Karcher Garden
Engine cutting out
Check that the fuel is flowing, there should be an fuel filter, check it out.
Jul 20, 2008 | Karcher 2500 PSI Pressure Washer
DPD 3100 gas pressure washer. No water going through pressure washer. Have taken screen completely out and still no water moving through
See this diagram:
http://www.mastertoolrepair.com/images/DPD3100_pump.jpg?osCsid=1f3m03ijp5lcht6569kran6rk2
Remove Items 122 (Un;loader) and 138 (Thermail relief). Clean them up as best you can with a nylon brush under some slow running water. Dis-assemble the unloader valve completly to clean (both ends). Then lubrcate them with White Grease and reinstall both parts AFTER placing White grease in the cavity the valves mount into. Very briefly... Test water flow with the engine not running Then start the unit with water off and let run 30 seconds. Turn off engine. Turn ON water supply and test water flow engine OFF. Note you will get a certain amount of white grease initially that passes through the unit. Start unit and rapidly actuate the trigger 1/2 second on 1/2 second off multiple times to force the unloader valve to cycle.
You can get parts here if either of the valves have completly failed:
http://www.mastertoolrepair.com/dewalt-dpd3100-n001194-pump-p-59405.html
The above steps should get your presure washer working properly again.
Thanks for choosing FixYa,
Kelly
Sep 03, 2011 | Dewalt DPD3100 Gas Pressure Washer
I have a honda power washer and it will run for about 30 minutes and then start losing pressure,gaining pressure back and losing for about a minute until dying, if i let cool off it will be good for...
Since you did not include a model number.. I have to speak in generic terms. On the output side of the pump there is a high pressure / unloader / bypass valve. There is probably corrosion on the stem of the unloader and the corrosion is causing the stem to stick in the brass stem guide. Remove the unloader valve assy from the output side of the pump. Clean off the corrosion with some scotch brite and the GREASE the stem. (Make sure the input water supply hose is connected but NOT on.) Dump about 2 oz of engine oil into the hole where you removed the unloader valve. Place a liberal amount of grease in the hole where the unloader was then install the unloader valve.
Start the unit but do NOT turn on the water for about 1 minute. Squeeze the power wand knowing full well your going to get oil and grease out of the end of the nozzle for about 45 seconds. Begin cycling the wand trigger rapidly.... multiple times. Your forcing the unloader valve to work.... Then try normal use.
I Not only work on these I have an Excell 2400 with the honda 5.5hp GX 160 engine that just this last weekend I had to do this exact procedure for the same reasons.... It is working like a champ again and it was new in 1997.
Kelly
Jun 03, 2011 | Garden
Karcher Power Washer -power is intermittent. it fires up, goes for maybe 10 seconds then loses power/pressure. Does not seem to get to full power.Water is flowing at all times, but power comes and goes.
Sounds like the unloader is cruddy with mineral deposits and sticking, if you pry off the silver cap, remove the black cover, use an Allen wrench to remove the two "star" screws (or you can remove the four engine mounts and remove the whole engine), lift out the white plastic part with the brass needle & spring, finally lift out the stainless steel piston or start up the engine (make sure you have the water hooked up and running) and watch out for the piston as it will shoot out ( placed a towel over the piston before starting the engine). Then you can put white lithium grease all over the piston and reassemble
Mar 13, 2011 | Garden
Once the trigger is released it won't starting spraying again.
I have the same problem. This is the responce for Karcher......
The unloader valve may be sticking, or is dirty. It probably needs to be cleaned and may need to be replaced, it is inexpensive. It gets a lot of use, but extends the life of the pump. The function of the unloader is to allow the machine to run in a bypass mode while the trigger of the gun is closed. First, a lack of high pressure can be caused by: 1. Insufficient water feeding to the unit, so check that the water is turned on all the way and that there are no kinks in the hose. 2. The inlet filter may be clogged. (it will need to be removed and thoroughly cleaned). 3. An internal water leak. 4.Also, low pressure can be caused by worn spray tips. If you have checked the first three with no resolution, the problem is internal and could be as simple as a sticking unloader valve. If you are mechanically inclined, you can clean this valve yourself and greasing the o-rings (use lithium based grease), or take it to a local service center. You do not need to take the pump apar
t. The unloader valve is located under the cover, and is secured with 2 bolts. (Use needle nose pliers to remove the valve) For those units with pressure and volume controls, the unloader is located under the pressure and volume control knobs themselves. Do not take any other bolts off or you will open the pump and lose the pump's oil.
Note: Lithium based grease will prevent future failure of the unloader valve.
Also, check websites such as fixya.com for tips and how-to info particularly on cleaning the unloader valve. Be sure to use lithium grease if you reassemble it.
I am going to check the manuel to see where it's at
Sep 24, 2009 | Karcher 2500 PSI Pressure Washer
Gas engine will not start without pulling trigger on wand to relieve pressure-engine dies when letting off trigger
I am afraid that is how they work even electric ones wont start unless you squeeze the trigger ,once they are running you should be ablr to release the trigger , and then squeeze it again whilst running . if yours dies when you release the trgger while motor is running -----good chance you are working at too high pressure. but to start you have to release all the internal pressure
Aug 22, 2009 | Campbell Hausfeld 2000 Psi Gas Pressure...
I HAVE A BRAND NEW TROY-BUILT 2600PSI pressure washer. I have used it twice for about 1/2 hour each time. It worked perfectly. I tried to use it today with everything hooked up perfectly. The Honda engine...
Sounds like the governor is stuck. My pressure washer speeds up when it has to pump. Don't know if yours uses vacuum to trigger governor or direct linkage. Good Luck.
Jul 04, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Karcher K3.91 compressor run for a few seconds every 10-15 second
They have a problem. I removed both valves and lubed with lithium grease as I was told. Unit is now working for how long who knowes.
May 18, 2009 | Karcher PSI Electric Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
434 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
