Question about Garmin nuvi 350 GPS Receiver
Map Update installation failure
I have a Garmin Nuvi 350GPS. I just bought the DVD for 2009 map updates. I follow all (3) directions, accept the agreement, then I get a message that I have a non recoverable error and the download quits.
  • Anonymous Mar 20, 2009
    Same here. See USB driver when connected. Unit will not update though. Have software version 4.09 on Garmiin 350. Have tried to update USD driver from download off of Garmin site, but will not complete. HELP, ready to pull hair out (what little I have left).
    Scholar:
  • 174 Answers
Seems like a communication problem. Are you using a usb hub between pc and garmin, if yes remove that. have a single connection between the pc and the nuvi. Does the nuvi go into mass storage mode (you see the screen change) if not you have a usb problem with the pc. You may need to install the proper driver from the cd. After. I'm assuming you are using Windows XP. Go to configuration menu double click on system, click on hardware and scroll down to the usb section. Plug in the Nuvi and see if it adds a mass strorage device amoungst the usb devices. No exclamation mark, that's good, if it presents an exclamation mark, right click and select update device driver, try the automatic option, otherwise manual and look for the driver on the dvd. Should go fine from there. If not get back to me.
Posted on Jul 20, 2008
  • Marcel Bakker
    Marcel Bakker Jul 26, 2008
    Before i forget, also disable all sorts of software that scans the usb for pictures and other stuf (including scanner software and usb printer monitoring software).
2 Suggested Answers
marcelbakker
  • 174 Answers
SOURCE: Garmin Nuvi 350
Did you get the new DVD, did you make sure nothing else is running (also taskbar objects), and you are not using a usb hub?
Posted on Jul 30, 2008
Need to know how i update the maps card for it
The latest version of Garmin Express provides the ability to install a map update directly to an SD card.
The SD card installation option will only appear when updating a compatible device that does not have sufficient internal memory for the largest allowable map region. When using the SD card installation option, critical files are loaded to the SD card so it must remain in the device after the update to ensure full functionality. For the largest size SD card a device can use, refer to: What is the largest size Secure Digital (SD) card that an automotive device can accept?
The SD card support during the map update will only function with up-to-date software. It may be necessary to update the device's software with Garmin Express prior to updating the maps. These devices do not support the SD card option:
  • Nissan 700
  • nuvi 295
  • nuvi 300 series
  • nuvi 500 series
  • nuvi 600 series
  • nuvi 800 series
  • nuvi 805 series
  • nuvi 5000
  • StreetPilot series
  • zumo 450
  • zumo 550
  • zumo 665
For devices that do not support using the SD card with the map update application, any maps that do not fit in the internal memory can be installed to the SD card manually, using these instructions:
Try the link.it may help.Under support.
Garmin United States Home
Nov 09, 2015 | GPS
How do i reset my garmin nuvi 200w satnav it says no detailed maps found how can i reinstall them
Locate the reset button, located on the back of the device, in the lower left corner. Remove the sticker covering the button, and use a straightened paper clip to depress the tab.
To reinstall maps
Connect your Garmin Nuvi to your computer via USB cable. You can only update the maps through connecting to your computer.
Open the "myGarmin" website and sign in with your Garmin account. Make sure to sign in with the account that you've purchased the map updates on.
heres a link to the site;
http://my.garmin.com/mygarmin/login.htm.
Click the "myMaps" tab on the myGamrin dashboard. This will load a list of all of your purchased map upgrades.
Click the drop-down menu in the "Recent Map Purchases" section. Select your Garmin Nuvi from the list of devices.
Install the Garmin Communicator Plugin when prompted. This is required in order for the Garmin website to transfer the map files to your Gamrin software on your computer.
Download and install Garmin Express. This is the program that allows your computer to interact with your Garmin Nuvi.
Register your device in Garmin Express. If you haven't already registered your device, you'll be prompted to when you start Garmin Express. You'll need to register in order to update the maps.
Click the "Updates" tab in Garmin Express. This will show all of the available updates for your Nuvi, including the new map update you just purchased.
Click the "Show Details" option next to your Map Update. Click the "Install" button that appears. You will need to accept the agreement before the update installs.
Wait for the maps to download and install. Once you agree to the terms, the map update will begin downloading to Garmin Express, and will then be transferred to your Nuvi. This will likely take several minutes to complete.
Close Garmin Express and unplug the Nuvi when the update is complete. The Nuvi will reboot and begin installing the updated software on the device. This may take another couple of minutes.
If you weren't automatically prompted to install Garmin Express, you can download it from
http://software.garmin.com/en-US/express.html.
Jun 06, 2015 | Garmin nuvi 200W GPS
When trying to put in an address the Garmin asks me for a country and then does not accept it after typing in the first letter. The other functions appear to be ok.
Hello
you need to update your map
Purchase your map updates (if necessary). You can purchase map updates for your Garmin Nuvi from the Garmin website. There are two basic options: a lifetime purchase or a one-time upgrade. The lifetime purchase gives you access to any new updates for the life of your device, while the one-time upgrade will provide you with the latest current maps, but you'll need to purchase again if you want to upgrade again later.
Make sure to log in with your myGarmin account before purchasing the map upgrade.
You can download garmin express here
Apr 19, 2015 | Garmin Nuvi 610 GPS Receiver
How can i update maps on my garmin nuvi 370 that i bought about 3 years back??
You can purchase map updates online from Garmin. Here's the link I use: https://my.garmin.com/maps/chooseDeviceType.htm
You'll need to connect your Garmin to your computer with a USB cable. Then go to the Garmin web site and follow their directions. You can buy a single update, or buy a "lifetime" (of the device) subscription to map updates.
Oct 09, 2010 | Garmin Nuvi 370
I need to install map update 2009 data card
If the map is on a SD card, just plug it into the SD slot on the side of your Nuvi with the power OFF. Then turn on your Nuvi and at the main menu, press the wrench symbol, then the map icon and then "map info". Uncheck your old 2008 map and check your 2009 map and you should be ready to go.
- Jim
SHARCNET-USA
Jan 18, 2009 | Garmin Nuvi 660 GPS Receiver
2009 map update not loading
Fixed. Called Garmin. It seems that version 4.90 FW on the Nuvi 350 (which came shipped on my 350) has a bug where it cannot communicate with the Garmin software either to update maps or update FW. Tech from Garmin e-mailed me a patch that I copied into the Garmin folder on the Nuvi itself, via USB and Windows Explorer. I then rebooted it; the patch installed itself which then allowed the unit to communicate with the map upgrade software and all is well. 2009 map update is now installed and the Nuvi is working fine again. Haven't tried upgrading to newer FW yet; will probably leave well enough alone.
Jul 01, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 350
Jun 08, 2008 | Garmin nuvi 350 GPS Receiver
Does it recognise the Nuvi? Are you connecting it through a usb Hub. Are the drivers for the nuvi installed properly? Usually there is a folder named USB, thats where the correct drivers reside, and that's where you tell the computer to look when it asks for the drivers.
May 18, 2008 | Garmin nuvi 350 GPS Receiver
Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
May 11, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
