Question about Maytag MAH6700AWW Neptune Front-Load Washer
Amana front load washer error code 5d
I searched for a solution to an error code coming up on my Amana front load washer and got this site. Can anyone give a suggestion on how to get this error fixed. The washer still runs but seems to pause more and take longer to complete a load of clothes. Sometimes they spin out and sometimes they are wetter.
  • 2 more comments
  • rikzmom7 Jul 22, 2008
    After reading much information on the internet with no definite answer to what the code was, I tried a number of things. I cleaned my machine and then checked my detergent for its rating for use with this type of machine and consequently cut back the amount. And I have made it through 3 loads without the code so thank you very very much for your response.
  • Anonymous Aug 27, 2008
    Same problem. I called Amana this morning. The code is acutally SD meaning suds. This can be caused by expired detergent. It was suggested that I call the manufacturer to check the expiration date. Also, to run an empty cycle of just water and bleach. Then, try cutting back on the amount of detergent I use. Hope this helps
  • Anonymous Mar 17, 2014
    whont drained
  • Anonymous Mar 23, 2014
    Will not fill up
5d means you're using too much detergent.
Posted on Jul 22, 2008
SH: Open thermistor. Unplug appliance and let rest for 15-30 minutes, then plug back in. If code continues, unplug appliance and call for service.
bP: Pressure switch error sensed. Washer will not operate when this error is displayed. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
rP: Water supply problem in spin cycle. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
LO: Lock Out mode. To activate, press START and STOP/OFF pads at the same time. To deactivate, repeat the procedure.
AU: Flashes when a factory preset cycle is put on hold. A normal function.
Clean Filter: Flashes when a cycle is selected as a reminder to clean the filter before starting a cycle for optimum drying results. Code clears when the door is closed and the START pad is pressed.
Posted on Sep 01, 2010
Error code 5d
Ok the Sd error code (not 5D) indicates that the unit has detected too much suds and has shut down until the error is cleared.
Try running a load with no soap and that should clear the problem.
If that does not solve the problem, then you will need the service manual to perform further diagnostics to the unit.
Here is a link to the manual.
Oct 17, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Long spin cycle of my Samsung WF8590NHM Front Load Washer is always interrupted and throws this flashing "5d" error code.
Hi.
The error code is not 5D but SD, which means slow drain detected.
Check drain hose. Check drain filter attached to the pump. Check pump itself and pressure switch.
Regards.
Ginko
Aug 20, 2011 | Samsung WF306BHW High Efficiency Front...
My washer is displaying a 5d code on panel, what does this mean?
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jul 01, 2011 | Kenmore Front Load Washer
My kenmore washer is stopping constantly and has error codes like 5d, rL, F21 and some other codes. We checked everything the manual says to and it all seems fine. What is the problem?
That 5d is a clue. Too much detergent, the wrong detergent, or detergent in wrong dispenser can cause the 5d which is suds overdose. The F-21 is from banging on the touchpad in frustration!
Keypad error! Take the base panel off and find the tech sheet behind it. The tech sheet will give error codes and what to try. I have an HE washer service manual and some repair photos HERE
Jan 12, 2011 | Kenmore HE2 Plus Front Load Washer
What does 5d mean when it comes up on front load whirlpool duet
5d is: It denotes suds lock (overdose of detergent dectected during the wash cycle).
Chances are you just put too much detergent in, or maybe the wrong detergent - make sure you're using the HE detergent.
These codes and more details are printed on the service technician diagnostic manual that is affixed to the inside of the washer's front panel.
Unplug your washer, and unscrew the three 1/4" socket screws at the bottom of the washer. The manual should be taped to the back of the panel, and the code and some recommended procedures will be right inside.
Jun 01, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2t washer - error code 5d
5d is a definitely a the code for a plugged discharge. We removed the lower access panel and discovered a virtual treasure: $12.50 in quarters, nickels, dimes and pennies, a pen, a pencil, collar stays, 10 bobby-pins, 3 barrettes, a elastic headband, a draw string, a box cutter, 3 washers, 3 broken zipper parts, a elastic waist band. Amazing it took all to trigger a 5d error code. Hope this helps!
Dec 05, 2009 | Kenmore HE2 Plus Front Load Washer
Code 5d
its a water senser error code check for loose wire bottom front of outer tub ,i have never had a bad one "less soap plz"
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code 5d???
sure it's not sud? if so may be oversudsingbe sure you are using an he detergent if you are and suds are and issue try cuting back on detergent
May 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
6,314 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
