Samsung RS2578BB Side by Side Refrigerator Logo
Posted on Feb 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What do you look for when your refriegerator/freezer does not get cold at all and the displayer in the front of the refriegerator signal blinks on freezer temp display
R Subramaniyam Iyer
Level 3:
  • Master 2,133 Answers
  • Posted on Feb 01, 2011
R Subramaniyam Iyer
Master
Level 3:
Answers
2133
Questions
Helped
953438
Points
6173
Check fridge compressor is working. If not replace relay. If working keep arm in condenser coil for warm. If no warm, no gas. Leak test and rectify. If warm and no whistling sound in freezer, system chocked. Release all gas and flush out system and replace filter drier. Vacuum and recharge gas. Check freezer thermostat setting is 5 degree. And also timer and heater are not malfunctioned.
thanks.
My LG Refrigerator Freezer has the green temperature control lights blinking on and off. How can I stop it?
When the refrigerator and freezer reach the set temp, the blinking stops. – If the blinking does not stop, unplug the refrigerator for about 30 seconds to reset the processor. – If the display still blinks it may indicate a problem within the freezer.
Have Frigidaire chest freezer about 5 years old. Front light indicator was blinking but has now gone out. Seems cold inside. Light bulb? Or more urgent problem?
If you are talking about an external light, it is most likely a neon indicator light that tells whether you have lost power to the unit. Blinking is normal with age or power fluctuations.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Why my fridge freezer keeps beeping four hort beeps
Temperature alarm
If the temperature becomes too warm, an alarm will sound and the temperature display will flash. The temperature the appliance is set at will determine when the alarm is triggered.
The alarm will sound and the display will flash under the following conditions:
  • - whenevertoomuchwarmairflows into the appliance, for example when food is being loaded, re-arranged, or taken out.
  • - wheneverlargeamountsoffoodare being frozen at once.
  • - whenevertherehasbeenalengthy interruption of the power supply. Door alarm
    If the appliance door is left open for longer than approx. 60 seconds, the alarm signal will sound.
Switching the alarm system ON
The alarm system is always active. It does not need to be switched on manually.
Switching the alarm OFF early
Once the set temperature has been reached in the freezer section, the alarm signal stops and the temperature display stops blinking. If the alarm signal bothers you, it can be switched off early.
^ Press the alarm off button. The alarm signal will stop. The temperature display will continue to blink until the set temperature has been reached. The display then stops blinking, and shows a steady reading. At this point, the alarm system is ready again if needed.
Why blinking yellow light and green light infront of cpu
Check if the signal cable for the display is connected and whether there is any kink that may break a wire inside the cable. If the circuit for display inside the computer is broken, most of the time you would hear beeping when turning on the computer.
LG Fridge / Freezer GWL227YBQA
sounds to me that you have either a sensor problem or a main board issue. to avoid spend money and the intricasies of trouble shooting, call for service. Sears has a Service Smart Agreement that is reasonable and would cover needed repair up to 500.00
Not cooling, the front digital display keeps blinking
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
faf
3answers
I have a 98 chev cavalier z24. Both indicator
Sounds like the signal multi-function switch has a short it it. Get a new one.
LG LFX25980ST REFRIGERATOR W/BOTTOM FREEZER SHOWS MESSAGE ON DISPLAY ER IF WHAT DOES THIS MEAN
The control is not seeing a feedback signal from the ice room fan. (the fan inside the freezer which pushes cold air up to the in door icemaker) It is probably blocked with a build up of ice or frost, preventing the fan blade from turning.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
