Question about Cosco Alpha Omega Elite 5-Point 22-155
Unstable seaat When I install the carseat, front facing, in my Mazda 3, the back of the seat is secure but the bottom part can be moved all around, like it isn't solid on the seat of my car. I have heard advice from others to put towels and thing under the set, but would like to hear from the experts.
    Problem Solver:
  • 4 Answers
The base is too wide for some car seats, especially if you have bucket seats. The bottom-most portion of the carseat base can be removed to make it more stable. I have not tried to do this, as mine is fine with the wider base, but I have read reviews online that stated that other parents have had success removing the bottom part. I believe the manual tells you how to do this; if not, you can call the manufacturer, Dorel Juvenile Group, at (800) 219-0509 and they will advise you on how to do it. You may also want to check www.carseat.org/recalls to see if your AOE is one of the ones that has a problem with the harness adjuster; if so, they can send you a repair kit for free. Good luck!
Posted on Aug 26, 2008
How do I install an infant carseat in the 2004 mazda mpv
Is it a LATCH type seat? The best location is the middle row. There is an anchor in the rear bottom where you can clip the tether. The rest of the seat is secured by threading the warbler through the rear of the child seat.
Oct 02, 2014 | 2004 Mazda MPV
Can i place the car seat facing front?
Hi - If it is an infant carrier Group 0+ carseat it must never be installed facing forwards. It is designed as a rear facing carseat to keep your child safe in the event of an accident. Always install a carseat according to the instructions.
Feb 21, 2011 | Maxi-Cosi 22371HFL Infant Car Seat
Have removed cover from front facing car seat can't secure straps at back when put back on
The carseat harness should never be removed due to the safety implications of it being incorrectly re-fitted. Your carseat will need to be sent to the engineers for them to fit the harness correctly.
Feb 05, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Hi, I have my seat installed in a 2003 Envoy. The level lines on the side show the seat sitting too upright. Also I can not remember what the correct installation is for the top latch belt. This was used...
for a rear facing car seat, put a folded towel under the carseat where the back of the envoy seat meets the bottom cushion, this will bring the level indicators closer to level. Also, you might need to use more than one towel once you tighten the seat down.
Feb 21, 2010 | Eddie Bauer 3-In-1 with Latch
Bought used Britax Marathon and Roundabout carseats, without the manaul. Need directions on how to install- rear facing for now, but will need directions on forward facing as well.
Go to the Britax website they have a pretty detailed explaination. Basically use the latch clips put your knee in it and pull tight. where you get the real security is though the tether that comes of the back of the headrest, you attach that to the floor clip in your car or under the front seat if you dont have one.
Nov 05, 2009 | Britax Marathon
How does the infant car seat connect to the stroller
It goes in the front seat it will click in place on the top of carseat connector that came with the stroller.
Aug 30, 2009 | Baby Trend Sit N Stand LX-7300 Travel...
Alpha Omega Elite
I haven't seen a video for it, but I'll try to explain it clearly. To install it with the LATCH system, locate the anchors in your car - U shaped metal anchors in the seat, where the back meets the bench part. See your car's owner's manual - many cars don't have LATCH in the middle of the back seat, so you'll have to install it in a side seat or use the seatbelt to install, instead. Recline the carseat all the way - there is a handle under the harness adjuster on the front of the seat. Pull the handle while pushing back on the top of the seat. Tuck the top tether strap under and hook it under the base or the seat - it's only used when forward facing and is dangerous if left flapping. Pull the seat cover off of the front corners of the seat. Thread the black latch belt through the rear facing belt path (the holes on the bottom front of the seat - there should be a sticker identifying the path), making sure that it does not twist and is behind, not over or in front of, the **** strap, but in front of the the slots that the bottom of the harness straps go through. Replace the seat cover. Put the carseat where you want it in the car. Look to see that the level lines on the shoulder belt positioning guide are level with the ground. Double check that the top tether is secured underneath the seat. Fasten one latch hook to the anchor in your seat, going from above the anchor, so that the clip part of the hook is on the bottom and the solid side is on top. Repeat on the other side. Kneel in the car seat to push it firmly into the seat while pulling the strap tight through the adjuster. The seat is installed tight enough when you can grab it at the belt path and can not move it more than 1 inch side to side. It is normal to be able to pull the top of the seat towards your car's seat back some. To install it with a seatbelt - (Please note - you can only install with the LATCH system OR the seatbelt - doing both together increases the stress and force on the seat and can damage it!) Recline the seat and secure the top tether as above. Place the seat in the car and make sure that the level lines are level with the ground, as above. Thread the seat belt through the rear facing belt path (again, the holes on the bottom front of the seat...look for the sticker). Thread it under the seat pad. Like above, it should go between the bottom slots for the harness and the **** strap. Buckle the seat belt. Kneel in the seat, pull the seat belt all the way out from it's feeder, and feed it back in, pulling it as tight as you can. Check for tightness as above. While your child is rear-facing, the harness should be in a slot that is even with or below his shoulders. Pull it snug - when it's tight enough, you shouldn't be able to pinch up any slack lengthwise at the shoulders or hips and it should lay in a straight line without any sagging. Make sure the chest clip is even with the baby's armpits, not over the neck or the belly. Good luck!
Nov 22, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
LATCH Attached?
The latch can be used in the rear facing position.
On mine there was a screw which secured the nylon to the seat.
You need to remove the screw and remove the LATCH belt.
The LATCH belt must then be threaded through the belt location under the child's seat, rather than behind.
Pay attention if there are any arrows on your LATCH belt which point up, so that you thread the belt the right way. Remember that the seat is going to be rear facing! : )
On the side of my seat it shows a picture with the LATCH in use, threaded underneath the child's seat. Maybe your shows this too.
Hope this works for you!
Stuart
Nov 21, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Cosco Alpha Omega Elite 5-Point 22-155 Logo
181 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
