Question about Sharp AR-5320 Black and White Copier
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
I have a problem in My Sharp Copier AR-5320. Although it print the document but on the document it gives black and white horizontal lines. Light misprint occur beneath the Black and White lines.On a legal size paper it gives parallel 5 or 6 black and white lines after every 3 inchs on the printed document.
  • 1 more comment
  • Anonymous Mar 21, 2014
    connect computer with Sharp AR-5320 Black and White Copier
  • Anonymous Mar 23, 2014
    doesn't print out in black and white.
  • Anonymous Mar 24, 2014
    There are no such lines when i print with it, but the lines come up each time i make a photocopy.
  • Sharp Master
  • 2,794 Answers
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Posted on Jul 20, 2008
AR-5320 Black and White Copier: new 5320e no photocpies but print out blank paper...
hi dear may you dont have put the origenal document proper or may be blank, just put writing side down on the glass or if u are using ADF put the writing side up side,
thanks
May 18, 2010 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 B & W copier giving F 5 alternatly.
thinksssssssssssssssssssssssssssssssssssssssssssss
Oct 07, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 B & W Copier giving L 4 error msg alternatly
L4 is main motor drive overload. It could be a power problem going on with the copier. Are these copiers plugged into surge protectors?
If you can have a Sharp technician look at it, it would be a good idea to determine if the motor, power supply, or main board is the culprit.
Sep 21, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Copier giving L 4 error alternately
The only way to corret the problem is to replase the fixing unit... That is what the L4 is refering to. It is not reading the correct tempurture..
Sep 20, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 giving me L 4 error some time
Usually the error is caused by a main drive over load. The machine needs to be looked to determine if its the motor, power supply, or a board.
Sep 19, 2008 | Sharp AR-5320 Black and White Copier
PC cannot send data to printer
You might have some trouble using the pdf when printing. Use the PCL driver. It's more reliable.
Sep 02, 2008 | Sharp AR-5320 Black and White Copier
Horizontal black and white lines are coming on copy
you don't mention whether the document you are copying also appears on the paper.If it does you could have 1 of 2 problems-
The drum cleaning system could be at fault or-
the fuser roller has picked up some **** easy test...... run copies and when the 1st copy edge appears switch OFF. This is a crash stop.Now examine the sheets in there.Is the stripe on the copy before the fuser (Heat) roller? If yes you could have a drum cleaning problem, usually fixed by changing the drum module.If no and the stripe appears after the heat roll, the problem is with the fuser system,dirty rolls etc. There are a number of other problems with stripes, but you have to start somewhere! If the document does NOT appear on the copy, forget all above, could be scan or ROS problem
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
D-Link Print Server Compatibility issues
DP-300U Print Server is not compatible with Sharp AR-5320. Pls check D-Link website on the list of compatible printer. For USB Print Server that is compatible with Sharp AR-5320 try Intellinet.
Jan 27, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-5320 Black and White Copier Logo
618 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
