Question about Whirlpool Duet GHW9150P Front Load Washer
Control lock light on
How do I unlock controls
Push in your end cycle button for a few seconds
Posted on Jan 18, 2009
I have the same problem!
Posted on Jul 20, 2008
Maytag dryer control is locked. how do I unlock it?
Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light goes out when the control panel is unlocked. Also try unplugging it for five minutes to allow it to reset
Jan 12, 2018 | Maytag Washing Machines
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
Whirlpool duet dryer
Oct 22, 2013 | Dryers
Controls locked
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start. You can lock the controls while the washer is operating. To lock the controls: Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows. To unlock the controls: Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Aug 06, 2012 | Whirlpool AWM9000 Front Load Washer
I have a Maytag MSD2351 side by side and just replace the water filter. When I attempted to reset the filter light, the control locked and I can not get it to unlock. I pressed the lock and water button...
If the Control Lock feature has been enabled, the Control Lock light will flash 3 times indicating that it is activated. To turn off Control Lock, press and hold the Options key that says "Control Lock Hold 3 Sec" under it for 3 seconds. If the dishwasher has a dedicated Control Lock button in the Options selections, press and hold CONTROL LOCK for 3 seconds.
NOTE: You may need to disable Sleep Mode by pressing either Start/Resume or Cancel, or by opening and closing the door before you are able to turn Control Lock off.
NOTE: If your model requires you to press and hold PROSCRUB UPPER, 4 HOUR DELAY or BOTTLE WASH to lock the controls, the Control Lock light will be on when Control Lock is active.
Nov 03, 2017 | Maytag Refrigerators
The controls locked is displayed. what causes this and how do i get the controls unlocked.
Jan 11, 2011 | Whirlpool GEW9250 Electric Dryer
Control locked
If you want to enable the Controls Lock/Unlock Feature:-
To enable the Controls Lock feature when dryer is running: Press and hold the CONTROLS LOCK/UNLOCK button for 3 seconds. The control is locked when a single beep is heard and the Controls Lock status light is on. This feature allows you to lock your settings to avoid unintended use of the dryer. You can also use the Controls Lock feature to avoid unintended cycle or option changes during dryer operation.
■When the dryer is off, it is not necessary to press the Control On button before activating the Controls Lock feature.
For unlocking: Press and hold the CONTROLS LOCK/UNLOCK button for 3 seconds to turn this feature off.
NOTE:- When the dryer is running and Controls Lock is on, the dryer can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Good Luck and have a nice day
Rating the solution is highly appreciated.
Jun 29, 2010 | Whirlpool GEW9250 Electric Dryer
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
Maytag washer panel show a red light that say control lock what if anything i can do to releaseit
Try the "End of Cycle" button to the right of panel front, next to Start button. Mine says hold for three seconds to lock/ unlock control.
Mar 10, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal De
