Thanks for the suggestion re the F8 button but I tried and I'm getting no response whatsoever from that.
The motor is running but nothing else is happening regardless which
button I a press. As I said it all started when the screen just went
blank and since then it's just the same..
Is there any other way to get the menu to come up ?
Umm.....this is stress...
Try using your Last Good Saved Settings in that same menu where your press F8....
Other than that, i am as lost as you are
Hope you get through
No.... you do not understand....
If it is a software based problem, which i think it is, do the Last Good Saved Settings, and it should load up.
Just try it dude...
That is right....you have to just follow me man... If you do not want help, don't ask... It is quite simple....
Why ask if you do not want to proceed?
No good with that as I need view the last good saved setting don't I??
So back to square one still. Anyone know where I can find the relevant
User Manual online?
hey Clickman
how do I "do" the last good saved settings without seeing a screen?
I'm not with yer man! It's like restore yeah but I need see the screen
to know what I am accessing...or am I missing the point here?
I have pressed F8 non-stop and nothing happens...so I am indeed
following your suggestion. You're saying a menu should appear but it
isn't... so I can't see/do last good saved settings.
Have I misread you? Thanks a lot buddy
minitor not reselution it pixel is fixed
thx
laptop starts up but the screen is blanck . when i fiddle with the pin underneath the screen latch it goes on and off. what can i do to fix this .or can i bypass that switch help me plzzzzz
thanks
riaan
