If it is still moving in the off position -- then the switch is bad. you can remove the top and inspect the switch for a loose or broken wire that could be making contact with the rail. if you are not that handy then you can take the mixer to appliance repair shop and they will be able to fix the switch for about 25 to 35 dollars ( maybe less if it is just a loose wire ).
I have this same mixer here at my place and it is a great mixer,, pretty die hard,, it should give you many years of trouble free mixing.
NOW I was thinking that it almost sounds like you might have just bought this mixer and it is new -- if it is brand new -- I would take it back to the store that you bought it from and tell them the problem you are having and just replace it,,, also check the warranty time on the unit and the manufacture might be still responsible for repairs(??).
c...
