Question about Canon PowerShot G5 Digital Camera
Canon digital G5 LCD monitor problem
The LCD monitor will only come on when the monitor is in certain positions.
  • bak1995 Sep 02, 2008
    I am also having a problem with my G5 display. Although the display appears completely blank, If i look very closely, at the correct angle, I can make out the menu and function screen images. I don't believe that following the posted solution of "re-attaching" the display wire would work because if it was detached, I don't think I'd see anything. It appears that the backlight, if there is one, is out. Any ideas?
  • celtickimi Sep 22, 2008
    my lcd is completely black..no faint display image at all. I have had this happen on 2 g5's any thoughts?
I took mine apart and found one of the flexible-connector solder joints had broken. I remelted the existing solder with a 15-watt pencil soldering iron (and a magnifier) and that fixed by backlight problem.
Jake
Posted on Sep 09, 2008
Very simple fix. Open the covering on the lcd screen and also remove covering that is between the camera and screen. There is a wire that goes from the lcd screen to the camera. It came out from all the twisting of screen when opening and closing. Carefully put that back in. Google keywords like "lcd g5 fix" etc. for more detailed description.
Posted on Aug 04, 2008
SOURCE:
LCD for Canon Powershot G5
did you look at the ifixit.com website? Not sure they already did the G5, but you never know.
Oct 27, 2013 | Cameras
Canon a2200 screen
The LCD screen inverter maybe faulty. Take your camera to the Canon repairer to have the camera fixed.
Apr 06, 2013 | Canon PowerShot G5 Digital Camera
Need written instruction manual for Canon Power Shot G5
get online and go to:
http://www.mica.edu/Documents/TSS/AV%20Manuals/still_canon_g5.pdf
You will get a manual in PDF format you can read with adobe reader. if you have trouble I have the manual I can send you in an email.
Nov 14, 2012 | Canon PowerShot G5 Digital Camera
Ik Krijg verschillende kleuren lijnen op m'n lcd van canon g5
Eerst moet je het "model" & "generatie"van uw G5 iMac moet je wetenHoe je je iMac te identificeren http://docs.info.apple.com/article.html?artnum=301724-enVerkrijgen van informatie over uw computer http://docs.info.apple.com/article.html?path=Mac/10.4/en/mh355.html
U kunt deze informatie weergegeven op de bodem van elk bericht door te gaan naar 'Mijn instellingen' die zich bevindt in de kolom aan de rechterkant onder uw naam, en het invullen van de gevraagde informatie.
Controleren om te zien of uw model iMac in aanmerking komt voor een van de iMac G5 reparatieprogramma programma voor video en voeding
Als uw computer niet in aanmerking komt, hopelijk heb je AppleCare.
Mar 21, 2011 | Canon PowerShot G5 Digital Camera
Blurry LCD monitor in Canon PowerShot A85
Sometimes humidity is the problem . Please keep the camera under room temprature and on position for maximum time . For the Battery low problem first try using alkaline or lithium ion batteries and see if they work fine...
Oct 12, 2008 | Canon PowerShot A85 Digital Camera
Colour banding on 10D images
Shoot in RAW mode and convert to 16 bit images to reduce banding
Sep 14, 2005 | Canon EOS-10D Digital Camera
Canon PowerShot G5 Digital Camera Logo
269 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
