How to clear Error Code Canon printers MP150 MP160 3. Enter Service Mode a. Hold Stop/Reset button and the Power button for 5 seconds 4. Do an EPROM reset. 3. The printer will probably now require the same setting up as when you first unpacked it. That is, you will need to select a language and let the printer do a head alignment. The printer is now enabled. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response Thanks, Joe
CANNON Printers
Unplug the printer for at least 2 minutes from the wall.
2. Plug the printer back in but leave the printer turned off.
b. Release Stop/Reset button but continue to hold Power button
c. Press Stop/Reset twice
d. Release the Power Button
e. Wait for the light to stop flashing. The printer is now in service mode. The display may be blank or simply read "Canon" during this time.
a. Press the Stop/Reset button 3 times.
b. Press the Power button twice. The printer will save the changes and then it will reboot. A little cd/dvd icon will appear in the LCD screen.
MP150/MP160 ERROR CODES:
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD over current error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
