Question about Canon PowerShot A85 Digital Camera
Memory card error
Hi, it has been a few days since my camera wont work, when i on it it says "memory card error" and i cant take pictures, because on the screen it says that there is "0" pictures. I tried to figure out what was wrong , but i cant. please help me. thank you
  • 1 more comment
  • fahima Jul 21, 2008
    thank you so much , it really helped , but it wasn't the pins it was that the memory card was not inserted properly.thank you for helping.Because of you we figured out the problem. thank you ever so much.
    bye
  • Anonymous Feb 09, 2009
    hi there i have the same problem with my canon powershot A85. the display reads "memory card error"
  • Havin probs Apr 04, 2009
    I am having problems with turning on and turning off my camera. Plus, when it's on it says there is a memory card error- E18 and you can't take any pictures or use the zoom button.
  • Canon Master
  • 4,738 Answers
Bet you have a bent flash card pin. Remove the card and look in the slot for a bent pin. If so, remain calm as you might be able to fix it. Remove the camera batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed).
It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Posted on Jul 21, 2008
I had this camera for a couple months and it currently contains a 16gb memory card with a few pictures on there. my camera is a vivicam f536 and when i start it up an i fix this?it says storage error and...
did you try taking the memory card out of the camera and putting it directly into your PC to download the pictures?
The other problem could be, is that the memory card was never formatted correctly. Once you get the pictures off, if possible, reinsert the memory card into your camera, and search thru the menu for formatting the memory card. I do believe that could solve your problem.
Aug 20, 2011 | Nikon D7000 Digital Camera
I have a kodak c743 with error code #126,1,0,0 and 226,1,o,o the lens will not go in and i cant take a picture
To remove the error, follow the instruction:-
1) Turn OFF the camera. 2) Remove the memory card from your camera. 3) Reinsert the memory card, then push down on the card until you hear a click. check the memory card is firmly fitted in your camera. 4) Turn ON your camera.
This will clear your error.
Have a nice day Rating the solution is highly appreciated.
Mar 06, 2010 | Kodak EasyShare M873 Digital Camera
Sandisk micro SD "card error"
The five pics are being stored on the camera's internal memory. The card you used was formatted and used in your phone. It's a miracle it worked at all. You need to get a new card, format it in your new camera have fun.
Dec 28, 2009 | Olympus FE-46 Digital Camera
Panasonic Lumix DMC-FS5 cant upload photos!!
Did your friend use the "safely remove hardware" function when removing your card from her computer? That could corrupt your card if she didn't. Try this...take your card to a store like Walmart that has a Kodak picture kiosk. They can usually read everything on a card. There, you can print the pics or even make a cd of them. Afterwards, format your card in your camera.
Dec 14, 2009 | Panasonic Lumix DMC-FS5 Digital Camera
4GB Lexar Premium 60 switch is up, but the message I get says
i have the lexar 4 gb memory card with a ton of pictures which i never deleted. when i put it in a card reader it wont pop up on the screen. it wont work in my camera it will say once i turn it on (card can not be accessed reincirt/change card or format card shows up on my camera screen.) this worked a few days ago and just stopped working randomly. help me
Sep 30, 2009 | Lexar Professional High-Speed 2GB Secure...
Is there a size limit for the memory card for the SD630. I put a 4 GB one in it, and it say memory card error
This camera only supports up to 2GIG or memory card so that's the reason why the 4 GIG wont work with it....
Jul 31, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
My memory card locked! i need to know how to unlock it
There is a small switch at the base that needs to be moved to the "Unlocked" position. It's at the side of the card.
Mar 26, 2009 | Cameras
File Error
You need to format first your memory card so that your camera will be able to properly recognize the memory card that you are using.
Go to Set Up and select Format option. Hit on Yes.
Jan 04, 2008 | Samsung Digimax S730 Digital Camera
Canon PowerShot A85 Digital Camera Logo
64 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
