Question about Kenwood Car Audio & Video
I have a word titled "PROTECT" on my kdc mp333, how do I get it to function properly again? Pls reply asap.
    Scholar:
  • 94 Answers
When the stereo goes into PROTECT mode it is due to a speaker wire having a short circuit or is touching the car chassis somewhere.
Check all speaker wires from the unit to the speakers.
First check that each pair of speaker terminals at the speaker end is not touching. Or, a wire fell of 1 terminal to rest on another.
Best way to check if it's a blown speaker or a wiring short, is to disconnect all speaker connections ( at the speaker end ) making sure the disconnected wires don't touch each other or any metal in the car. press the reset on the unit and power up. If the unit powers up ok, then its a blown speaker.
Otherwise it's a short in the wiring.
If it's a blown speaker, you can connect 1 speaker at a time and the blown 1 will send the unit into protect mode again.
If it's the wiring, disconnect the unit from the wiring and use and ohm meter to check each pair of cables. A reading suggests a short.
If you don't have an ohm meter a battery and bulb will do. This method usually works on a short.
If you have no joy with either method, take each speaker wire in turn and check with a source of earth (anything metal connected directly to the body of the car, cigar lighter main body when pulled slightly out is good)
Regards
Philip
Posted on Jul 22, 2008
I have a kenwood kdc mp333 cd player, it reads cds and the radio is fine but therers no sound... like i turn it up and stuff but no sound.. is there a mute button on my cd player or would it be my...
Could be one or the other, look at every button on the face and ensure there is no mute button, although usually when you adjust the volume it will unmute. I would also look in back of the deck and make sure your wiring harness did not get disconnected, if it is connected you can try testing a speaker or two right from the harness and see if you get audio.
Mar 13, 2011 | Car Audio & Video
Model kdc-mp438u "protect" shows up on the screen when powered up
This indicates that a problem has been found in the final output stage of the amplifier. The amp stays off to prevent further damage. Remove all of the speaker wires and try again. If the protect message remains, the problem is within the amp and th amp will need service. If you are able, check the output transistors for a shorted condition as that is the most common failure part.
Keep us posted.
Dan
Apr 23, 2008 | Car Audio & Video
Hi , i have bought a car with kenwood kdc-mp333 audio player. i get an error protect all the time i turn it on. could u tell me how to solve this problem
More then likely it has an anti-theft system built into the radio. They only thing you can do is try to contact the previous owner if that isnt possible look for a really small reset button.
Feb 09, 2011 | Car Audio & Video
Hi, i can not figure out how to get past or reset the protect mode on my kenwood kdc mp 142
The model that you refer to has the reset button just before the 1 Button. Press that for a second with a pen or something of the the same point size and there is no need for force. This will reset the head unit. All personal settings are lost when reseting the unit. However if it goes into protect again then there could be a mistake in the installation somewhere, most likely incorrect speaker installation or speaker cable shorting on metal somewhere. There could be other reason but these would be most likely the cause. Good luck dreamsystems
Feb 08, 2011 | Car Audio & Video
KDC-4051UG Only comes "ON" with
Your head unit is now connected correctly. That is how it is intended to be installed. Unless it doesn't store the radio stations. In that case the power cables of the head unit (RED&YELLOW) are incorrectly connected, but not a big problem. hope that helps dreamsystems
Feb 06, 2011 | Kenwood Car Audio & Video
I have a kenwood KDC-MP5043U stereo and it says the word protect. I wish to find out how to get it going again, it is only a year old
Hey, to fix the protect problem all you need to do is insulate your speaker wires. In the manual it says that this is the cause. Once you have done that you just need to reset the unit. The reset button is in between the skip buttons and the channel buttons on the unit. I have the same problem with mine and am just about to try it. Hope this helps
Sep 06, 2010 | Car Audio & Video
My kenwood head deck kdc-mp6036 shows on the screen protect what's wrong with it
A "PROTECT" message/display normally indicates a problem with your speaker or your speaker wires. Pls check for any open or shorted (busted speakers) or if any of the wires are touching the chassis/ground.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 11, 2008 | Car Audio & Video
My kenwood kdc mp332 car cd player is saying that it is on protect and will not play anything. how do i get it on and off protect?
if the power is not turned on (or it is on, but will be off immediately,) the speaker wire may have a short-circuit or touched the chasis of the vehicle and the protection function may have been activated. therefore the speaker wire should be checked. the press the reset button. also it will do that if it gets hotter than 60 degrees celsius or 140 f
Apr 20, 2008 | Car Audio & Video
Kenwood car stereo KDC-W3534 : warning message PROTECT
i had the same problem and i just disconnect the battery and and reconnect it and everything works fine!! try it
Dec 19, 2007 | Kenwood KSC-310CCS Center Channel Speaker...
Car Audio & Video Logo
109 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
