I need a spindle motor for a Marantz DV9500 dvd player. Where should I look?
  • ralexg Jul 22, 2008
    The bronze bushing is gummed up and it won't spin a disc anymore
I'm looking for a spindle motor for a Sony DVD player. Try looking at partstore.com or pacparts.com. I looked both places for a motor and they didn't have one, but they might have the one you're looking for.
Posted on Jul 26, 2008
  • 979 Answers
Try consumer electronics support/parts if a visit to Marantz's website does not work. Just "Google' it and see what kind of listings there are. What's wrong with the spindle motor that you have?...accordianman
Posted on Jul 20, 2008
My Numark CDN 90 Is saying no disc although a disc is in the CD drawer of the unit.
The unit needs the lens cleaned or the spindle motor is not turning due to wear or it needs oil.
Jun 21, 2013 | Marantz PMD351 CD Player
How do I remove the front of the tray on Marantz dv9500 so I can remove the transport from the enclosure?
Turn the laptop over, follow the guide lines of the DVD player, you should see one or two screws near the center back, remove the screw, take small needle or fine screwdriver and look for a small hole in front of the DVD loading tray, carefully insert in the hole until you hear a slight click, tray should pop open, pull all the way out and remove DVD driver. there is no need to remove bezel since everything comes out in one piece.
Mar 21, 2012 | Computers & Internet
Help me to my toshiba sd-260 dvd player...can't spin the disk...said bad...
If the disc didn't spin, high chance that the spindle motor is already faulty. Check my tips on how to test the spindle motor and fix your unit yourself.
Faulty spindle motor tips 1
Faulty spindle motor tips 2
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 13, 2011 | Toshiba SD-260 DVD Player
I have a cyberhome 300 dvd it is in a sleep mode and I can not get it to turn back on . can you help me with this
hi,
There is a possibility of spindle motor problem. If the spindle motors is short or open then this model dvd players will not turn on from the standby mode. Just replace the spindle motor. And the check. Spindle motor is one in which the cd rotates.Have added the picture of spindle motor for your reference.
ajin_g_56.gif ok
Jun 13, 2011 | Cyberhome CH-DVD 300 DVD Player
The light on the dvd player won't turn green any more.I can't get it to play any more. If I did get it to play it would say bad disc the light is now yellow not red are green any more.
hi,
You dvd have problem with its spindle motor. Spindle motor is one on which the CD rotates. If the winding of the spindle motor become short this problem can occur. you can see the spindle motor in the center of the mechanism. spindle motor will not cost a lot. Just replace the spindle motor your problem will solved.
ok
May 06, 2011 | Cyberhome CH-DVD 300 DVD Player
Dear Sir The dvd cannot read the disc
One of the problems with many DVD players is as they get older the spindle motor is unable to overcome the inertia of the spindle + the disc.
If this is the case the read head will try to hunt for the start of the DVD if it is not spinning then it wont be able to find the DVD. If you can access the DVD by taking the cover off you can give the DVD a chance to spin by giving it a little push if the player can find the DVD then you can watch the movie.
If this is the case you will need a new spindle motor fitting to your player.
Jan 06, 2010 | Polaroid PDM-0742 Portable DVD Player
Marantz dv9500 stopped dig coax 2 channel output error reads no audio
go into the menu and choose change the settings under digital output and turn on
Apr 27, 2009 | Televison & Video
My one-year old Marantz CD5001 CD player
these models use the 12.1 philips laser mechanism and it is a very common problem for failing to read discs.
various technics / marantz / philips / cyrus cd players etc also use it and are plagued with the same fault.
it's a 90% chance the laser is dead!
philips realised the unreliability of this laser and uprated it to the identical looking VAM-12.
do not dismiss the spindle motor as these also fail quite alot on this mechanism.
hope this helps.
Dec 20, 2008 | Marantz CD5001 CD Player
DVD PROBLEM
Often on Panasonic DVDs, error code H07 indicates that the spindle motor is not turning. The spindle motor is relatively small and expectedly wuld develop hardware problems over time. In some cases, a temporary remedy wold be to clean and lubricate the inside of the motor. Here is my post on similar problems with spindle motors of another electronic device, while here is an illustrated how to.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 09, 2008 | Panasonic DVD-RV32 DVD Player
Marantz CD48 - CD spins backwards
Check the small signal transistors BC338 and BC328, they're under the transport mech and will be near where the spindle motor plugs in to the PCB.
One of the transistors acts as a brake which momentarily puts the motor in reverse polarity to stop the CD rotating during 'stop' or 'open tray' modes. The reason the CD is spinning backwards is that the transistor which drives the spindle motor forwards during playback is faulty and is triggering the braking transistor hence spinning backwards.
The transistors should be 'BC328-25' / 'BC338-25' (25v)
Replace these and all should be well.
Hope this helps
Sep 05, 2007 | Marantz CD-48 CD Player
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
