Question about Samsung Televison & Video
Samsung le23r86bd.how do you connect a sky box a dvd &video with scrat leads .
Bluehound
  • 25 Answers
SOURCE: Connecting TV, Sky box & DVD player
If it's just an DVD Player, the easist way is just run a skart lead from the player out socket to the spare skart (ext2) on the TV. Then choose ext2 on your TV remote.
Posted on Jan 06, 2008
sids8065
  • 61 Answers
SOURCE: Yamaha DSPAX761 no s-video to HDMI
S-Video and Composite are analogue and HDMI is digital. Your receiver dose not have the capability to convert from analogue to digital and hence you are not not getting any video.
Posted on Feb 29, 2008
KEV TECH
  • 3 Answers
SOURCE: Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Posted on Apr 11, 2008
Slinteriors
  • 8617 Answers
SOURCE: samsung hdtv, loud buzzing sound
thats usually the first sign of a defective light engine. Is this a DLP television?
Posted on May 04, 2008
SOURCE: Connecting TV-DVD recorder-Sky plus
scart from the sky to the dvd recorder. then a scart from each to the tv. Job done.
Posted on Jun 14, 2008
Tv dvd and sky box
isn't there any manual/ book?
To connect TV to Sky Box VCR, connect the SCART lead from the AV1 socket on the TV to the TV SCART socket on the Sky Box. Connect another SCART lead from the AV2 socket on the TV to the AV1 socket on the DVD player and an RF cable from VCR to the aerial in socket on the TV.
Apr 27, 2013 | Televison & Video
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
Can you show me how to connect up the scart and aerials up to the following so they operate correctly Samsung PS42C450 42-inch 600Hz Widescreen HD Ready Plasma TV with Freeview SAMSUNG DVD-SH893M 160GB...
hello firstly scart lead from sky box to tv1 in) this is at the top there are two AV inputs ,,,on the bottom AV slot this is where your DVD conects too).iff you are using sky you will not need aerial in back of tv as this is for analogue use such as indoor antenna or outdoor antenna or iff using horizon the scart lead will suffice for all goodluck
Mar 19, 2011 | Samsung PS42C91HDX 42 in. Plasma TV
Have samsung dvd sh893m all though followed instructions from both dvd & sky manual cannot get signal from digi box ?
if you have followed the sky instructions and connected the aerial to the sky box first, don't. Always connect the aerial to the digital tuner first as the sky box and any other equipment will reduce the signal strength.
Mar 29, 2010 | Televison & Video
Want 2 record from my DVR 2 Magnavox DVD Recordable/VCR MWR 2046
should have avi scrat out at back of DVR place scrat lead here and the other end into avi scrat input on your DVD recordable & feed to screen as normal.
if no scrat scoket avaible you can get a converter to switch from one to other.See your local dealer.
And happy days of u go.
Aug 07, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a Sony dav-100dz dvd player. It has a scrat lead but no hdmi or usb ports. can I add hdmi or usb port in my player?
I wish to connect to a Sony BLUray using the
existing Sony dav-dz1
i am connected to a sky hd box and dvd/video
player with sound through dav100
Regards
Brian
Jul 15, 2009 | Sony DAV-DZ100 System
Connection advice needed
hello.on that samsung you probably have more than one hdmi conection so conect your dvd/vcr with hdmi cable to tv and sky box with hdmi to if its have hdmi or with scart if not.if you still have problems with conection,make some photos of tv,dvd/vcr and sky box all back panel and send to me (dodzio24@o2.pl) and i send you the best solution i can.
Aug 14, 2008 | Samsung Televison & Video
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Setting up
on the back of your sky box there are two scart ports. one says tv and the other video.
from the sky box connect a scart from the tv port to the back of your tv.
from the DVD connect a scart from that to the video scart port on the back of your sky box.
now when you turn your DVD player on it will override the sky and come through on your telly without having to change the scarts around.
what i would like you to do now. is get an RF lead. ( aerial lead) plug this into the RF out socket on the back of your sky box either one will do ie RF out 1 or 2 makes no difference.
Then plug the other end into the back of your Tv if you have an aerial cable coming into your home then simply plug this straight into the aerial port on the back of your sky box.
The last thing your going to have to do now is tune your telly in. if you click on channel 6 on your telly then go to menu, setup, and manual tune.. A good tip for you put your sky on the TV GUIDE screen this will make life easier for yourself as you will know its the sky channel.
once you find it STORE.
now when you turn your dvd player on if you select channel 6 you will now have the sky channel so you can record whatever you like
Hope this sorts you out.
cheers
Little Dish Fitter
Dec 28, 2007 | Samsung DVDHR738 (250GB) DVD Recorder /...
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Open Questions:
Televison & Video Logo
35 people viewed this question
Henry  Thomas
Henry Thomas
