Question about Bunn BT10B Coffee Maker
I purchased my Bunn coffee maker on sale without an instruction booklet.It used to take about 5 min to brew. It has slowed down considerably. How do I clean it out?
  • 60 Answers
Here is the manual:
http://bunnomatic.com/pdfs/commercial/manuals/37688.0001.pdf
Posted on Jul 28, 2008
My Bunn coffee pot seems to pour out so quickly. The grounds come out the back and all over the counter and in the coffee.
I have had this happen when I used non bunn filters . perhaps they non bunn are too small thereby letting the water run over the top My bunn takes 3 minutes when it's clean to brew 12 cups .
Jan 12, 2015 | Bunn Coffee Makers & Espresso Machines
Tip
Bunn coffee brewer brews too slow?
lime builds up on the metal surfaces where the hot water cools down or evaporates, such as the sprayhead, the waterline to the sprayhead, the reservoir inlet, or the insides of the tank. the sprayhead and reservoir inlet buildup will restrict flow and extend brew time and may even not brew through all of the grounds. to fix:
1. remove the top of the brewer. the reservoir is right on top and the drain looks like a nut with a hole in it. lime will plug this up. using a deliming spring or even a philipshead screwdriver, push through and twist to get rid of the lime.
2. unscrew and remove the sprayhead and bore the lime out of the holes with a small flathead screwdriver or a paperclip.
3. if necessary, unscrew the reservoir drain nut, place it and the sprayhead in a cup of straight vinegar. for more stubborn lime, use CLR, but wash and rinse thoroughly.
4. if you have a deliming spring, push it through the outlet waterline to the sprayhead all the way past the 2 elbows and pull in and out, removing any lime buildup.
5. rinse parts, reassemble the reservoir, and brew a little without the sprayhead first to get rid of any loose lime. then put sprayhead on and run a test brew. if it brews short or too much, see tip for recallibrating
on Jan 15, 2015 | Bunn CWTF 15-3 Coffee Maker
if the coffee is ground too fine, it'll take longer to brew through. either grind more coarse or call bunn for a flow restrictor (800) 352-BUNN (2866)
Cleaning
The metal proble is use to clean out the water tubing. Remove your sprayhead and insert the metal rod up in the hole leaving out about 1-2 inches. Then simply twist and turn the rod about 5-6 times. This will remove any lime deposits. Then flush out with 2-3 decanters of water. You can obtain a new manual by calling customer service or going to the website-www.bunn.com going to @home, then products-click on your brewer-and then select use and care manual and you can print it out or view it online.
May 19, 2010 | Bunn 10 Cup Home Coffee Brewer
Filter basket overflows after cleaning Bunn VPR Coffee Maker
Some people also try adding fresh grounds to brewed grounds, resulting in an overflow. A restricter valve can be used, but a better solution is to simply pour in half the water at a time. This is what people who buy non Bunn filters do to stop overfills.
Oct 05, 2009 | Bunn VPR Coffee Maker
Tim Hortons Bunn Coffee Maker Instructions
which way do the gaskets go together in the reservoir of the tim hortons bunn coffee maker
Jul 13, 2009 | Coffee Makers & Espresso Machines
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
May 06, 2009 | Bunn NHBX-B Contemporary 10-Cup Home...
Water over filling pot
There is a brew timer on the left side of your machine near the heater switch. you need to remove an access panel to access it. turn this down a little, let the water heat up, then try another brew. Adjust as needed, brewing another pot between each setting.
Jan 07, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Brewing instructions
Go to this website fopr brewing instructions:
http://www.bunn.com/retail/service/faq.html
Thank you for using FixYA
Aug 21, 2008 | Bunn GR10 Coffee Maker
My bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
Sep 15, 2007 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn BT10B Coffee Maker Logo
201 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
