Question about HP Photosmart D5160 InkJet Printer
Hp d5160 my printer keep saying cover is open
  • 1 more comment
  • Anonymous Feb 04, 2009
    Incredible. Tapping the top of the control panel works.
  • Anonymous Apr 17, 2009
    Again, tapping the contrl panel seems to have resolved it (but for how long?)
  • Anonymous Apr 22, 2009
    Haha,
    Thanks guys - I had the same problem.
    Just tapped the top of the printer near control panel!
Don't unscrew anything, a light knock on top of the control panel with a finger resolves the problem everytime for me after closing the cover
Posted on Jan 11, 2009
Had the same problem and found it was due to a failure of the plastic lever inside the printer that generates the cover open signal. Give away is that the left hand side of the top cover is slightly higher than the right.
Solution depends whether you are in warranty or want to fork out for a service repair. If not, the way I found to solve this was to take off the control panel (there's one screw on the top that you need a 2.5mm Allan Key to take off, then the panel can be prised off carefully). This reveals a grey plastic vertical activator on the left inside of the printer case which needs to be knobbled so that it's in the up position. Once you've put everything back together, you'll not get an indication when the top cover is open, but at least the printer will print.
Posted on Aug 07, 2008
Yup, that suggestion also works fine for me. Don't start unscrewing stuff until you've tried it.
Posted on Jan 28, 2009
    Problem Solver:
  • 5 Answers
Open the cover, disconnect an ink tank and reconnect it, close the cover firmly. works every time
Posted on Jan 25, 2009
Retira el panel frontal quitando previamente el tornillo superior.
Verás una pieza de plástico gris que se debe elevar al presionar la pestaña de la tapa en un pequeño rectángulo en la zona izquierda.
Esta pieza se atasca y deja de deslizarse suavemente y por ello el sensor no detecta la tapa cerrada. Para evitar esto pon dos gotitas de aceite con la ayuda de un palillo en las guías de la pieza que desliza verticalmente y verás que ahora se mueve suave. Monta el panel, el tornillo y listo.
Fernando.R
Posted on Feb 03, 2009
2 Suggested Answers
hashir4u
  • 79 Answers
SOURCE: HP Photosmart D5160
Hi Arnie,
Infact the machine cover is not a customer replacable part, hence u ll not be able to open it . however if u try to open it make sure u ll not break the bezel.
thanx .. nd best of luck
Posted on Jun 15, 2008
Hi: Re HP Photosmart D5160 printer: 1) Prints a
You may have added a separator page,
1). Open printers and Faxed.
2). Right-click your printer and select 'Properties'.
3). Click 'Advanced' tab
4). click 'Separator Page'
Delete any text in the box and click 'OK'
Sep 13, 2011 | HP Photosmart D5160 InkJet Printer
HP Photosmart D5160 gives error message -0 03 31 IF F$ 4d dd d6
Issue
The product displays an 0x ... error code when printing (for example Error: 0xf0af8004). These error codes indicate that the product has an internal condition.
Solution
Use the instructions below to resolve the issue by restarting the product.
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
Open the cover of the product and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the product and wait for one minute.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover.
If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, contact HP technical support for assistance.
Mar 05, 2011 | HP Photosmart D5160 InkJet Printer
Help, I have lost my installation disk for my HP Photosmart D5160 Printer. They would like to charge me $38.00 for a new disk. Any suggestions?? Thanks, Mary
You can download the Softwares/Drivers for your printer from these links (similar with the contents on the Hp CD) :
Hp Photosmart D5160 Printer for windows xp 32 bit
or
ftp://ftp.hp.com/pub/softlib/software10/COL15834/dj-41864-2/TF_regna_psp_NB.exe
Hp Photosmart D5160 Printer for windows xp 64 bit
or
Hp Photosmart D5160 Printer for windows vista 32 bit
or
ftp://ftp.hp.com/pub/softlib/software10/COL18384/dj-47558-2/SF_CDA_Full_Non-Network_enu_NB.exe
Hp Photosmart D5160 Printer for windows vista 64
or
Hp Photosmart D5160 Printer for Windows 7 32 bit
or
ftp://ftp.hp.com/pub/softlib/software11/COL30907/dj-76773-1/SF_CDA_NonNet_Full_Win_WW_130_140.exe
Hp Photosmart D5160 Printer for Windows 7 64 bit
or
Hp Photosmart D5160 Printer for Linux
For Mac Drivers, please visit here and follow the instructions given there.
It would be much easier for you and for me if you had mentioned the Operating System installed on your computer where you are going to install the printer. Anyway, select the suitable link for your operating system.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Aug 23, 2010 | HP Photosmart D5160 InkJet Printer
Photosmart d5160 keeps printing a test page after i print anything
Please perform the following steps:
* Make sure the CD/DVD tray is closed.
* Double-click the HP Solution Center icon.
* In the HP Solution Center (for Windows OS, if you are using Mac please let me know), click the tab for the HP Photosmart 5100 series.
* Click the Settings button.
* Point to Print Settings.
* Highlight and click Printer Toolbox.
* After the Printer Toolbox opens, click the Align print cartridges button.
* Follow the on-screen prompts to align the cartridges and print an alignment page.
:) Dr Tony
Apr 17, 2010 | HP Photosmart D5160 InkJet Printer
Cannot remember how to load new print cartridge on to my HP Photosmart D5160 series printer
keep the printer ON.then open the flap on the front side.there is a small gap made in the flap to get it opened.as u open the flap the cartridges will automatically move and come in the position where u can remove the cartridges.just pull the cartridge to the dwn side near to you and it will come out.in the same way insert the new cartridge.
Nov 30, 2008 | HP Photosmart D5160 InkJet Printer
Message keeps saying "Cover is Open" and I get a red exclamation at top right corner of the printer. The cover, however, is NOT open and the printer is not responding. Help would be most appreciated. Thak...
I have had this problem also and have found that instead of "dropping the cover hard" I can just give the "sensor area" on the left side of the cover a sharp rap with my finger and the light goes off.
Aug 15, 2008 | HP Photosmart D5160 InkJet Printer
HP Photosmart D5160
Hi Arnie,
Jun 15, 2008 | HP Officejet 5610 All-In-One InkJet...
Hp 97 use to D5160
see whether your printer is capable of using other hp cartridge.it may be the same on physical appearance but check it on the manual of your printer if you could use 97 as a replacement cartridge
May 27, 2008 | HP Photosmart D5160 InkJet Printer
HP Photosmart D5160 InkJet Printer Logo
797 people viewed this question
Ben Johnson
