Question about HP Photosmart D5160 InkJet Printer
Cover is open
The printer will not print and keeps de faulting to photo printing
    President:
  • 2,351 Answers
If you are using windows XP for the operating system try this.
Left click once on the start button, slide to & left click once on printers and faxes. In the printers and faxes window right click once on you're default printer HP 5160 slide to & left click properties. In the next window click the button, printing preferences. Change the printer's settings in this window. After making changes, click apply & Ok.
Still having trouble? Click this link & go over (setting up your product). http://h10025.www1.hp.com/ewfrf/wc/setupCategory?lc=en&cc=us&product=1155996&dlc=en
Make sure you are using HP's most up to date software for you're printer. Click this link & follow the instruction on the web.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00633142&lc=en&cc=us&dlc=en&product=1155996&rule=22694
If you are running window Vista, check Vista for updates. Make sure you're printer is turned on while updating.
Good Luck!
Mike
Posted on Jul 20, 2008
HOW DO I INSTALL INK
Sir/Madam
Tell Me Your HP Printer Model Or You Can Perform These Below Step To Change HP Printer Ink cartridge,
Step 1: Open the printer
Turn on the printer. Press the Power button if it is not lit.
Open the printer cover, then wait until the print cartridge cradle moves to the right side of the printer and is idle and silent.
Figure 1: Raise the cover
Step 2 - Remove old cartridges
1 Press down lightly on top of the cartridge latch.
2 Pull out the bottom of the latch to unhook it.
3 Slide the cartridge out.
Step three: Use a cartridge protector
If you are temporarily removing a working cartridge (for instance, removing a Black cartridge in order to install a Photo cartridge), put it in a cartridge protector. Cartridge protectors come with Photo cartridges.
4100022b-6f18-428e-a2bc-bbd00a59c50f.gif 12806acc-4ccc-4074-b41c-6ca5d04702b4.gif
Step 4 - Make sure the new cartridges are compatible
Step 5 - Install the new cartridges
Figure 6: Remove the protective tape
Figure 7: Contacts and nozzles
1 - Contacts
2 - Nozzles
Hold the print cartridge so the nozzles are down and the contacts face toward the printer, then slide the cartridge into the carriage.
Cartridges marked with a triangle go into the left carriage slot.
Cartridges marked with a square or pentagon go into the right carriage slot.
Figure 8: Put each cartridge into the proper slot
3 Push down on the print cartridge latch until it snaps closed.
5e2afb9d-cef4-415d-bd5c-a6c08dc7a1c6.gif acbe1f2c-5f74-4596-9d01-84173e86e0c8.gif
4 Close the printer cover.
Print cartridge maintenance
After removing the print cartridges from the printer, it is necessary to follow basic care and maintenance guidelines to keep them from drying out. The following guidelines will help maintain HP inkjet print cartridges and ensure consistent print quality.
Do not reattach the plastic tape that covered the ink nozzles since this can damage the nozzles.
Store the print cartridge(s) in a print cartridge protector or airtight plastic container. If the cartridge is stored in an airtight plastic container, make sure the nozzles face down and are not in contact with the container. Do not use plastic bags: this may damage the print cartridges.
Placing a moist paper towel in the airtight container may help to keep the cartridges from drying out.
A print cartridge protector is provided with the photo print cartridge.
To insert the cartridge into this protector, slide the cartridge at a slight angle into the protector and snap it securely in place.
To remove the cartridge, press down and back on the top of the protector to release the cartridge. Slide the cartridge out of the protector.
Do not drop the print cartridge since it could be damaged.
In case You still Having Problem Then I suggest You Visit HP Printer Official Website
Removing and Installing Print Cartridges
Or
still Having Problem Then Follow Us On:
HP Printer Support
Feb 13, 2014 | HP PhotoSmart Office Equipment & Supplies
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
The red light with the arrow pointing down keep flashing and it won't print. It the print the first page just fine. What does it mean when the red light is flashing?
Its either a paper jam error or your printer is out of paper,open your printers back cover and check properly to see where the paper jam is located.
Jun 29, 2010 | HP Deskjet 5940 Photo InkJet Printer
Five flashes pause then a further 5 flashes
This error mean "non installed or defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number is QY6-0057.
Nov 25, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Stylus Photo 820 printing magenta lines
did you clean the communication ports , where the cartridges "talk" to the printer, the ports can get covered with paper dust and erronus signals can cause the printer to activate the magenta cartridge causing your problem. reomve the cartridges and Gently clean the comm ports with a q-tip and rubbing alcohol let dry then reinstall the ink cartridges.
Jul 12, 2009 | Epson Stylus Photo 820 InkJet Printer
How to print cd covers
ihad cannon 5000. there was same function. fo cd print . we shuld have driver for it .driver comes on with printer. and also come tray to keep cd.. infront of printer ,there is a hole to inserd tray with cd, then we can open this driver .From program. when can open cd write founction there is many design to print cd. thanks
Jun 16, 2009 | Canon PIXMA MX850 Multifunction Printer
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
DVD label won't print, tray is rejected, 6 orange flashes (cover is supposed to be open)
I've got this printer with no problem.
Make software ready to print with dvd cover closed and press print wait until software tells you to open drawer the place tray up to white arrow's and press print
Should work
Apr 14, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Printing
Possible firmware fault, if your not afraid of using a screwdriver in your printer remove in the inside top cover and check that the little optical sensor and gate are functioning properly! but as its working in the other 2 modes it would suggest its more likely to be a firmware fault so try resetting it or a firmwear upgrade from website! hope this helps
Sep 06, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
HP PSC 1210 All-In-One InkJet print problem
Follow the steps below to enable or disable the cover page option in Microsoft Word.
  1. In Microsoft Word, click File , then Print . The Print window opens.
  2. In the bottom-left of the Print window, click Options . A new Print window opens.
  3. Do one of the following:
    • Select Document Properties to enable cover page printing.
    • De-select (remove the check mark from) Document Properties to disable cover page printing.
  4. Click OK to close that window.
  5. Click OK again to print the document.
Jan 14, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP Photosmart D5160 InkJet Printer Logo
80 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
