Question about AEG Santo U 86000i Compact Refrigerator
Ice develops at back of fridge
We have an AEG Santo 2500i fridge. It is at least 12 years old. It is a built-in, rather small model compared to most North American fridges. Ice builds up on the back wall of the fridge. Within about a month it becomes 2-3" thick and continues to grow, almost like a glacier. This is especially bad in the summer. It eventually forces the shelves forward so that the fridge door won't close. Food at the back of the fridge freezes. So every month or so we have to empty the fridge, turn it off and defrost.
The fridge is over top of a AEG freezer, which generally runs fine.
  • chrisdh Jul 20, 2008
    The first response I got was to "defrest the frize". I'm assuming that means defrost the fridge- which is quite obvious and what we have been having to do too often. My question is whether there is a problem with the fridge that is causing this ice to build up so quickly. I was hoping for more clear and helpful advice than this. Anyone?
  • chrisdh Jul 21, 2008
    Yes, there is a temp control in the fridge. It does not seem to matter where it is set, the problem still persists.
    Scholar:
  • 68 Answers
Hi chris
dave here hope i can help
I would test the defrost timer, defrost heater or defrost limit switch
TESTING AND REPLACING THE DEFROST TIMER
This timer activates the heater that melts frost in the evaporator for 10 to 20 minutes every 10 to 12 hours. In the process, it turns the compressor off and on. If it fails, the compressor may not run. Or the heater may not go on, eventually causing a hidden ice buildup that blocks the cold-air flow and disables the evaporator fan. An access hole lets you test the timer. If the timer isn't in the control panel, look behind the front grille or behind the rear access panel. If the compressor fails to run turn the timer until it clicks. If compressor goes on, timer is faulty. If unit isn't defrosting automatically and turning timer stops compressor or fan, timer is faulty.
Before replacing timer, spray it with electrical contact cleaner through access hole and turn it a few times. Stop just before a click and wait to see if timer advances on its own.
To replace timer, unplug the refrigerator and open control panel. Remove screws holding timer to panel and pull of leads. If wires aren't in a plug, move then one at a time to new timer.
EVAPORATOR AND DEFROST HEATER
In a frost-free unit, the evaporator coils, their fan, and the deforst heater are located behind the freezer's back wall or under its floor. The fan, which circulates cold air between the coils and the two food compartments, is controlled by the door switch, the thermostat, or both. To check the fan, open both doors, wait for the compressor to go on, and hold in the door switch. If you can't hear the fan running, test the fan(below).
The defrost heater, which melts frost on the coils, is cycled on by the defrost timer(above). If the frost melts before the end of the defrost cycle, the defrost limit switch turns the heater off. The heater may be a metal rod, a wire wrapped in foil, or a coil inside a glass tube. All are tested the same way. Test terminals for the heater are often located in the control panel or under a doorjamb; check the wiring diagram. Or test the heater leads inside the evaporator compartment.
TESTING THE EVAPORATOR FAN
To remove the evaporator fan, unplug unit; open back panel(or floor) of freezer. Then unscrew housing holding fan, and take off leads going to fan motor. With VOM(Volt-Ohm Meter) on RX1, probe motor terminals(except green ground wire terminal). Look for moderate resistance(50 to 200 ohms). Replace fan if much lower or infinity.
TESTING THE DEFROST HEATER
Open control panel. With VOM on RX1, probe test terminals. Look for 15-to 100-ohm reading. If infinity, turn defrost timer(as above); retest.
TESTING DEFROST LIMIT SWITCH
Trace and disconnect leads. With VOM on RX1, probe leads. Look for infinity reading when switch is warm, zero after 20 minutes in working freezer.
Hope this sources your problem
Thank you for using Fixya.com
Posted on Jul 20, 2008
  • 2,071 Answers
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.You must change this defroster heater assembly so it will works normal again..
hope this may help;
  • 6,487 Answers
There's really something wrong with it if it freezes that fast, Is there a control to adjust the temperature of it?
  • Mark Gil
    Mark Gil Jul 21, 2008
    Empty space in a refrigerator or freezer is generally a bad idea...and often causes the refrigeration to cycle more often. Having it filled with things is much better, since the thermal inertia of the stuff will help keep it colder and more stable temperature wise. Also the less room for air there is, the less problems you'll have with condensation.
  • 813 Answers
U need to defrest the frize
  • sandip panchal
    sandip panchal Jul 21, 2008
    u need to call a professionl service man he will help u
How can i stop my larder fridge from producing lots of ice?
If your fridge is built into the furniture, pull it out by releasing all the retaining screw, clean the condenser and the areas behind your fridge. Dust and fluffs reduce the efficiency of the fridge. Also turn the dial to three, if it is higher, older fridge do not need to be cranked to higher numbers. If no joy call an engineer, the level of refrigerant in your system may need topping up. Will cost you anything from sixty pounds for a qualified engineer to do this.
Aug 15, 2014 | Refrigerators
Finding a refrigerater seal for an old aeg santo 1605
HI DAN.wow still going hain.well u'll be lucky to find one.i think yours is a screw on seal.try matching it to a universal fridge door seal.and cut to size.no other way.:) good luck.ali
Jul 04, 2012 | AEG Refrigerators
MY fridge freezer Model Santo C61841I is not cooling
My Santo C61841i has stopped cooling. Power and the fuse is ok (light still comes on), its 8 years old is it worth repairing or buying nes
Aug 11, 2009 | AEG Refrigerators
Thermostat not working in my Santo fridge
yes
it is a requirement as they are not repairable
you have to consider the cost against lost food and the cost of anew fridge
may be possible to get a thermostat to suit from e-bay
Dec 05, 2017 | AEG Santo U 86000i Compact Refrigerator
AEG Santo 3778-8 KA Temperature Problem
hi tracy, think its possibly better getting a repair guy in as this fault is not streight forward. possibly a fault in the defrost circuit, or freezer fan not functioning, or possibly a leak in the system. all theese areas need testing equiptment.
Sep 19, 2007 | AEG Santo 7085 KG Side by Side...
AEG Santo U 86000i Compact Refrigerator Logo
584 people viewed this question
Top AEG Refrigerators Experts
Oscar Netto
Oscar Netto
ashburton
Jim Goldsmith
Jim Goldsmith
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
