Question about Hotpoint Aquarius WF210 Front Load Washer
Cycle stops Anytime i put a wash on, the machine stalls and i have to knock it off then move onto the next stage such as rinse and spin then spin.It also leaked from the door the other day. The machine is quite old, about 8 or 9 yrs. Is there any point in getting it fixed or would I be better off just buying a new 1. Also I can't seem to find the filter to empty it, I know its at the back of the machine somewhere, just can't see it.
The filter is inside the m/c Empty this and it will work again.
you need to tip the m/c over and unto the jubilee clip on the bottom of drom to large black hose inside you can remove the white plastic filter container...this will be full of crud.
Posted on Jan 11, 2009
I have a problem with my hotpoint wf340 1400 spin when i put it on it washes but wont come off the wash cycle and will continue washing unless i stop it manually i then have to select pump out and then a...
it is either a broken wire to your heating element or the element itself is open circuit. when the water does not heat the machine will not move onto next stage of wash.
Feb 20, 2011 | Hotpoint Washing Machines
Machine fills rinses and stops before drain and spin
Sounds like your timer is not moving the gears to the next cycle.
May 18, 2009 | Washing Machines
Programme gets stuck on wash cycle
Most likely a defective door switch.
Mar 02, 2009 | Washing Machines
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Washer will not go to rinse or spin cycle
electronic problem in timer board,not being electronically moved to next stage of washing
Jan 24, 2009 | Kenmore 43142 Front Load Washer
FP code appearing on lcd disply
remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
Dec 26, 2008 | Whirlpool AWM8143 Front Load Washer
Beko 1510S washing machine stalls at spin
check to make sure you have't got the rinse hold button pressed in. If it is your machine will stop at the end of it's rinse cycle and will not go into its final spin.
Jun 15, 2008 | Washing Machines
Does not spin in most cycles
It sounds like your timer is defective.  If this is the case you will have to replace it.
Oct 17, 2007 | Maytag Performa PAV2200
Hotpoint Aquarius WF210 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
