Question about Microsoft Windows Server Standard 2003 for PC
Difference between DNS and WINS
Dear sir,
Could you please explain me the difference between WINS and DNS
  • venugopal_i Jul 21, 2008
    Thanks a lot for you.
Kjkjkjkjkjkjkjkjk
Posted on Jul 21, 2008
    Scholar:
  • 93 Answers
WINS is Windows Internet Naming Service, a system that determines the IP address associated with a particular network computer. This is called name resolution. WINS supports network client and server computers running Windowsand can provide name resolution for other computers with specialarrangements. Determining the IP address for a computer is a complexprocess when DHCPservers assign IP addresses dynamically. For example, it is possiblefor DHCP to assign a different IP address to a client each time themachine logs on to the network.
__________________________________________________
DNS, a.k.a Domain Name System is a database system thattranslates a computer's fully qualified domain name into anIP address.Networked computers use IP addresses to locate and connect to eachother, but IP addresses can be difficult for people to remember. Forexample, on the web, it's much easier to remember the domain namewww.amazon.com than it is to remember its correspondingIP address (207.171.166.48). DNS allows you to connect to anothernetworked computer or remote service by using its user-friendly domainname rather than its numerical IP address. Conversely, Reverse DNS(rDNS) translates an IP address into a domain name.
Posted on Jul 20, 2008
I have no idea how to find my WINS code. Can you please explain this to me?
-open command prompt by typing CMD in run window - type IPCONFIG / ALL then press enter - it will display there WINS proxy - if its says "No" for statusof WINS proxy ENABLED - then you dont have WINS code
Dec 29, 2010 | Computers & Internet
Error code 8002ad23
Hi Giles
You probably have your router connected to your modem, and a PC connected wired/wireless, and the ps3 connected wired/wireless.
1. First you need to start your ps3 system. Go to your network settings and select information. Write down your IP, Subnet mask, Standard Gateway, and the primary DNS.
2. Start your PC and go to your networks settings. Right click your network adapter, click properties. Select "Internet Protocol version 4 (TCP/IPv4). Click properties and type in manually the IP adress, Subnet mask, Standard gateway and DNS.
Then you click "Advanced" and then you click "WINS" then "Activate NetBIOS over TCP/IP". Save your settings and connect the ps3 to your network (should not make a difference if you do it wired or wirelessly)
Let me know if this helped and please do rate my solution.
Regards
KreativeGeek
Feb 06, 2010 | Sony Playstation 3 (PS3) Console
Limited or no connectivity
hi,
welcome sir,
what i can suggest u is that just reset the router and then install the wireless driver into ur computer and then try and connect to wireless network and hope u will be connected......good luck....
pls rate this solution..........pls...thanks
Feb 12, 2009 | Adapters.com PLANET USB WLAN...
Want to know my TCP/IP preffrered DNS and alternate DNS
DNS are ISP specific. They are normally provided by the network/company that gives you Internet access. The DNS then would be different from ISP to ISP, location to location.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 09, 2008 | Computers & Internet
Difference
I believe you can . You will need a seperate Windows server as well as a seperate Linux server. Than you need a desktop program that will let you get into both servers at the same time.
Sep 01, 2008 | Microsoft Windows Server Standard 2003 for...
Huge difference in film scanning quality
For ARCHIVAL quality scans, there is no comparison. The Nikon wins hands-down. For making small prints and web sharing, either will work fine.
Apr 16, 2008 | Nikon LS5000 Film Scanner
Dns error (80710102) on my ps3. It works wirelessly fine (but weak signal causes glitches) - but when I use a wired connection it will sometimes work fine for an hour or so and then kick me off the network...
please help me iam wired connection to the playstation 3 i have ((dns error)) but i still can make any download please help me quikly ......
engineer.sabah .talal
Apr 01, 2008 | Sony Playstation 3 (PS3) Console
Wireless connection problem
Internet Setup
Internet Connection Type: Obtain an IP automatically
Host Name: linksys
Domain Name:
MTU: Enable Disabled
Speed & Duplex: 10 Mb Half
Local IP Address: 192.168.1.1
Subnet Mask: 255.255.255.0
Local DHCP Server: Enabled
Start IP Address: 192.168.1.
Number of Address: 50
DHCP Address Range: 192.168.1.100 ~ 149
Client Lease Time: 0 (0 means two day)
Static DNS 1:
Static DNS 2:
Static DNS 3:
WINS:
DDNS: Disabled
NAT: Enabled
Dynamic Routing: Disabled
Wireless: Enabled
Wireless Network Name(SSID): linksys
Wireless Channel: 6 - 2.442 GHZ7
Wireless SSID Broadcast: Enabled
Wireless Security: Disabled
Feb 23, 2008 | Dell Inspiron 1200 Notebook
Microsoft Windows Server Standard 2003 for PC Logo
182 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
