Question about Niko OTP-3211W 32 in. LCD Television
Picture size do you have any idea how to get the size or the picture back to the regular fomat, it just all of a sudden changed?
    Genius:
  • Niko Master
  • 1,689 Answers
This is from a failure starting to happen in the power supply, or the scan amplifier sections. The set will require proper troubleshooting to locate the defective parts, and then to change them.
You will have to have the set serviced by an experienced TV service tech.
Jerry G.
Posted on Jul 21, 2008
My TV just went from a full screen to a small, less than one quarter of the size and no idea why or how to get back to full screen
this could be your cable box or tv causing it. First try the tv. On the remote go into menu look for video settings. There though be a setting called aspect ratio. This should be set to 16:9. If that is set correct then try the same with the cable box remote.
Feb 05, 2015 | JVC CAR CD/MP3 RECEIVER, 7 BAND EQ, PREAMP...
How to change battery
Either the remote control is regular size or miniature like the remotes for cars. The only real difference is the type and size batteries it uses. The regular size remotes usually use 1 or 2 "AA" or "AAA" batteries, or occasionally, a 9 volt battery. The miniature remotes take "button" batteries that are available at Radio Shack or the big-chain drug stores like CVS. Whether the batteries are the regular type or miniature here's what you do: On the back side of the remote there will most likely be a small phillips-style screw in the middle. Remove this screw and then you will be able to open the battery compartment door. Write down or take pictures (better) of how the batteries are configured and note this as you remove the old batteries. Radio Shack has a battery tester. If ALL the batteries are still good, then the remote is defective. If ALL the batteries are dead or very weak, then most-likely the remote is working fine & will come right back to life. Enjoy!
Jun 10, 2014 | Sanyo RCS-SH1UA Wireless Remote Control
My bush tv picture has suddenly doubled in size for no reason try changing the size with 16:9 button but makes no difference and ideas
if can not get with adjustment, you may have bad component in the main board. check for leak or bulged capacitors in vertical and horizontal section.
Aug 18, 2012 | Bush Televison & Video
How to enlarge/reduce photo size & maintain proportions
I think you are referring to "crop".
After pasting the picture in MS Word,
You would see "Picture Tools" top tab. Then under "Fomat" you would see "crop" click on it and try editing your picture.
It should reduce the size of your picture and maintain the normal image size.
Hope this helps.
Thanks,
Jul 17, 2011 | Microsoft Office Word 2007 Full Version...
Change picture size on olympus stylus 500
Make sure you go to the camera menu and go to the setup tab and change All Reset from On to OFF. This will retain the setting of the image quality to SQ2.
Jun 15, 2009 | Olympus ? Stylus 500 Digital Camera
Picture to large for screen
hit your aspect button or fomat button on your remote it will adjust size of picture also verify cable box aspect ratio
May 08, 2009 | Televison & Video
My Power Shot S1 suddenly changed to taking smaller pictures
You must reset the camera in the mainmenu to default.
Regards,
Rob
Mar 14, 2009 | Canon PowerShot S1 IS Digital Camera
Change the picture size on an aurex tv using the buttons on the side of tv
I too have an Aurex TV ..and have to adjust the screen size regularly .I do this by the hand control.at the bottom of the handset are two rows of buttons..3 on the bottom row and 4 on the next row up..the on furthest on the right on the row with 4 buttons is the button for screen size change.
Oct 09, 2008 | Televison & Video
Samsung TSL3099WHF
Check the B+ output voltage, if this is higher than rated, this problem could occur.
Jan 23, 2008 | Samsung TSL3099WHF 30" TV
Niko OTP-3211W 32 in. LCD Television Logo
Top Niko Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Andrew Taylor
Andrew Taylor
Are you a Niko Televison and Video Expert? Answer questions, earn points and help others
