Question about Samsung LN-S4051D 40 in. LCD Television
No sound on samsung lcd tv lnt4042h
Tv is only 5 months old
  • drz7 Jul 21, 2008
    thanks for your response but I fixed the sound problem by unplugging the tv for awhile and not I have sound,thanks again
  • Scott Hill
    Scott Hill May 11, 2010
    please inform me as to what you have hooked up to this tv for sound does any system hooked in give you sound, is the volume turneddown? do you have a dvd player or a sat reciever or cable reciever...is it hooked into a surround distribution unit? I need more inofrmation please to help you resolve this.
  • 558 Answers
Based on this info what happened is this someoe accidentally changed the setting on where the sound was to be inputed. by unplugging it you returned the tv to default. hope you can rate me thanks for asking and letting me know how it turned out.
S
Posted on Jul 22, 2008
15 month old samsung tv - has sound but no picture
If it is an LCD or LED TV then the problem is likely to be the inverter board(s).
Mar 02, 2015 | Samsung LE37B550A5 37 in. HD-Ready LCD TV
LNT4042H TV will not power on. No sound, no video.
Check the power supply module voltages first, it should have 5vdc standby voltage at all time the minute the TV is plugged into the wall outlet, try turn on the TV, then the main 5vdc, 12~16vdc and the 24vdc should be on. Look at the supply for burnt parts, blown fuse, etc.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN-T4042H+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 15, 2010 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung LE22B450C8W LCD TV freezing picture/sound
The Main bd needs a Firmware update or it is going bad.
Call Samsung and have them look up your warranty by the Serial number. Keep calling to get a different agent until they agree you have a in warranty set and agree to repair it.
Apr 10, 2010 | Televison & Video
I have a samsung lnt4042h and it has worked fine until about a week ago, it started making a clicking sound, and wouldnt turn on, the clicking goes on repeatedly until 5 secs after i unplug it. i kept ti...
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts.
Good Luck, big IRISH.
Oct 21, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Clicking on Samsung LNT4042H
go here and fix it yourself for less than $10
www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound
Jul 12, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Sound but no picture
It is most likely the inverter, here is a trick to check it. Turn the tv on a channel where you have audio(sound)
Take a flashlight or a lamp with a bare buld and shine it on the screen. Look very closely at the screen, if you see a video image your inverter is bad.
Let me know and I can instruct you on replacement.
lone99star
Jan 09, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
it's the T-con board attached to the lcd panel
Jul 29, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
46" Samsung TV loses sound.
R U using HDMI? If so that be the problem.
Jun 18, 2008 | Samsung LN-R460D 46 in. LCD Television
Samsung LCD LNT4042H
Hi Barb,
Unfortunatly the problem you are asking about is a normal happening in our area with customers of mine that use rabbit ear or house mounted antennas ( Normally not cable or satellite dish). This problem sounds to me like a lack of signal strength on certain channels where your loosing your sound. Since your LCD TV is digital it requires a bit more signal strength to produce sound and picture. Maybe a better antenna, or redirection the antenna toward the station transmitter. Hope this helps.
Ed
NC Electronic
Mills, Wyoming
Jan 05, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung LN-S4051D 40 in. LCD Television Logo
121 people viewed this question
Jerry Greenberg
Jerry Greenberg
