Question about Toshiba e-Studio 161 Copier Copier
F and 5 code
When I switch on the copier power indicator keep blinking and after a second it's stop and display F and then 5.. please solve my problem with thanks.
    Problem Solver:
  • 7 Answers
F means exposure lamp
Check either lamp or may be more dust???
Thenks
Posted on Jul 21, 2008
My Sony TV when switch on after a few seconds it just goes to the standby and red button flashes 4 times short stop then 4 times again. Could you please help x
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 04, 2016 | Sony Televison & Video
Sir,i having a panasonic rear projection tv TC51P400H.recently it is not working.The red indicator which blinks three times in every 5 seconds intervel,when the switch on.please inform me the solution
http://electro-medical.blogspot.com/
Nov 15, 2016 | Panasonic Televison & Video
Sny led klv24ex430 red light 2 time bllinking how to solve
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Oct 17, 2016 | Office Equipment & Supplies
Hi my panasonic CS-PS18NKQ is not working,timer indicator keep on blinking.
• To make a diagnosis
1. Timer LED start to blink and the unit automatically stops the operation.
2. Press the CHECK button on the remote controller continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display. Note: Display only for "- -". (No transmitting signal, no receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote controller. The code "H00" (no abnormality) will be displayed and signal will be transmitted to the main unit.
5. Every press of the button (up or down) will increase abnormality numbers and transmit abnormality code signal to the main unit.
6. When the latest abnormality code on the main unit and code transmitted from the remote controller are matched, power LED will light up for 30 seconds and a beep sound (continuously for 4 seconds) will be heard. If no codes are matched, power LED will light up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by pressing the CHECK button continuously for 5 seconds or without any operation the remote control for 30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, you can narrow down the problem.
Feb 04, 2015 | Panasonic Heating & Cooling
Hi I ve a sony KDL-40W2000 stuck on stdby red light flashing 4 times the stop for 3 second ??any advice please
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 16, 2014 | Televison & Video
Blinking power light
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 10, 2013 | Toshiba 42HP95 Television
Hi there, my sony grand wega kdf60wf655 had stopped working and was flashing 5 red lights. I tested the voltage from the power board to the lamp ballast board and got a 272v dc. Just replaced the lamp...
http://homenol.blogspot.com/
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 05, 2017 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a nashuatec D445 and it is indicating an error code CS 547-00 what can i do to solve this problem?Please help.
Press 'Function Clear', 1, 0, 7, then press and hold 'Clear/Stop' button for 3 secands. Machine displays SP Mode. Now turn MAIN power switch off for 5 seconds. Turn MAIN power switch back on. This should reset SC 547 code. (Main power switch is located on the left side of the copier)
Dec 15, 2009 | Ricoh Aficio 450 Copier
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Sony KV-34s25 Blicking light
We can help, but I need to know the count of the blinks. That count will indicate the circuit that is defective. Also, please confirm that the model number is: KV-34S25.
Thanks,
Dan
Aug 08, 2008 | Sony KV-35S45 35" TV
Toshiba e-Studio 161 Copier Copier Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
