Question about Canon imageRUNNER 2200
Scanning from Canon image runner 2200
When I scan in a document I have to scan into Word, I would like to scan as a my adobe reader I don't see an option to import the scan?? any ideas?
  • 47 Answers
Adobe Acrobat Reader is just that, a reader. It is a free utility that allows you to read PDF documents only. It does not allow creation or modification of PDF documents. To do that you need Acrobat Professional but it is rather expensive, around $450.
Another solution is to use your Word to scan the document and then use a free PDF creation tool like CutePDF ( or PrimoPDF ( These install like a print driver so you scan the document into Word and then "print" the document to these drivers and instead of actually printing it it creates a PDF file.
Posted on Jul 21, 2008
You may have to upgrade your adobe
What is meant by PDF in used in scanning?
If you are asking about the "SCAN TO PDF" button, it allows the scanner to create a Portable Document Format (PDF) file. PDF files are files that can be viewed with the free Adobe Reader software. The PDF format files are easy to store on your computer and easy to share. PDF files can have many pages. Image files, like JPG, can only hold one page per file.
If you use PDF files, make sure you only get the reader software from
Adobe Reader Download Free PDF viewer for Windows Mac OS Android
Mar 31, 2015 | HP ScanJet Office Equipment & Supplies
I'm trying to scan a document into Adobe PDF. I have Adobe on my operating system but it's not coming up as option to select when scanning the document. Any suggestions?
All you need to do is use the MP Navigator. With that up and running you simply scan all the images then choose the save as PDF option. You only need the Adobe on your system to read the file, not to create it.
The Navigator will allow you to create and correct the images into a multi page PDF. It should be on the instalation CD if you have not loaded up Navigator.
Apr 23, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Canon Image Runner 2200 Error code E000225-0000
0000 A specific level cannot be attained for the signal during CCD gain correction
at power-on.
0002 The edge gain correction level is different from the correction level for the
preceding sheet by a specific level or more.
Main cause The scanning lamp is faulty. The CCD PCB is faulty. The rear controller
PCB is faulty.
1. Scanning lamp (LAMP1)
Is the lamp ON during the initial operation after the main power switch is
turned on?
NO: Replace the scanning lamp.
2. CCD unit, Reader controller PCB
Try replacing the CCD unit. Is the problem corrected?
YES: End.
NO: Replace the reader controller PCB.
Feb 28, 2011 | Canon imageRUNNER 2200
New all in one printer/scanner. when I scan I get:- Adobe reader could not open 'scan_Doc0001.pdf'
Might need a bit more information about this: But I'm presuming you scan your document and save it as a pdf document using the built in HP software?
Couple of things to try:
1 - have you got the latest version of Adobe Reader? It may be that you are using an older version - the pdf document specification has been updated over the years and it may be that you're saving the pdf using a newer version of the pdf format than adobe reader is able to read.
2 - Adobe reader isn't the only pdf viewer, there are numerous other pdf document viewers (some free some not) You could try another pdf viewer, like Foxit Reader (free to use) and see if that can open it?
3 - When you save the scan, make sure that in the Save Dialog box it is really saving it as pdf. Common mistake is that people often just save a file with .pdf and expect the program to know that you want to save as pdf. When you scan there are several other file formats that you can use (Tiff, Jpeg etc) Is is possible you're saving the file as Tiff or Jpeg but with a .pdf file extension? If you're not sure, re-scan the document and resave it, but don't use a file extension, let the scanning program do that, see what it saves it as?
4 - check where you're saving the pdf on your computer? Is the place you're trying to open it from, the same as the place you've saved it?
Feb 28, 2011 | HP Office Equipment & Supplies
Canon Image runner 2270
There is just know way to walk you thru this. Your going to need someone with the know how to come to your location to set up your scan option. Your local canon dealer can help you.
May 19, 2010 | Canon imageRUNNER 2200
Scan document as pdf on a Photo 926
open adobe acrobat..not reader, has no ability to create pdf's, and go to file, create pdf, from scanner
Don't forget to rank the advice!
Jul 27, 2009 | Dell 962 Photo All-In-One InkJet Printer
I have ir3300 how can scan as pdf formate? please advice me
my canon 3300 all in one printer (image runner) pdf files print very slowly
May 04, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Can not scan documents using Canon Image Runner 2200
you need to down load the network scan gear tool support downloads office /production then look for canon network utilities... down load scan gear tool [ not color}this file will have to be unzipped then run it... this will set a program in your program files open the one that says scan gear tool when opens either type in the device ip adress or you can select discover. once you do this you select it as the scanner in your scanning software Adobe Pro etc. you also must select scan on the copier then online before scan will happen
Dec 12, 2008 | Canon imageRUNNER 2200
You need to install the Canon scangear tool to discover your equipment then you can use Adobe or word to scan a picture with the newly discovered scanner. You can only edit documents with the Imageware software that you will have to buy.
Jun 11, 2008 | Canon Image Runner 3320I Copier
Canon imageRUNNER 2200 Logo
267 people viewed this question
old marine
old marine
