Question about Sharp Viewcam VL-Z1 Mini DV Digital Camcorder
Dew problem Hi i have vl-z5e sharp camcorder with e007 dew problem, i had to pay to fix this problem first time to change the sensor. after 3 month waranty expired i had again the same problem i dont want to change the sensor again because i don,t trust that problem will happen again i sudgested to the technician to try if he can remove the sensor and put resistor instead to delete sensor but he refused. my question is can i delet that sensor and if yes do you know where is that sensor in the corder and how it look like(i can do it my selfe because i am technician)thanx
  • 10,594 Answers
Thats great that you are technician. This dew sensor locates near video head assy area. you need to find it urself. this sensor looks like black carbon pattern on white cemented plate or yellowish flexible base. Main thing is it has only 2 points and can be recognise easily. just remove it and place 1k or 820 ohms resistor there. I am not sure about resistor value because it depends on circuit requirement. Hope this info helps you out.
Posted on Jul 20, 2008
I have a sharp vl-z300 camcorder which is displaying an e007 error can you help
The 007 error is associated with dew sense and is a fairly routine repair.
PC board traces open at System Control IC, and will need to be hard-wired. I would suspect that any reputable electronics service facility should be able to perform this repair.
To find a Sharp authorized center in your area, contact Sharp support at sharpusa.com/CustomerSupport.
Hope this helps (remember to rate this free answer and leave a testimonial).
Sep 27, 2011 | Sharp VL-Z300U Mini DV Digital Camcorder
I have a sharp vl z300 displaying an E007 FAULT .CAN YOU HELP WITH WHAT IT IS AND IS IT WORTH FIXING
Whot does it mean when dew on screen and turns off just after
"Dew" means there is condensation (moisture) in the camera. The camera may refuse to operate until it is thoroughly dried out.
Nov 29, 2010 | E.Digital Sharp VL-Z5E Digital Viewcam...
Bypassing of DEW sensor
there is no way to bypass it, but simple modification is available to correct this problem. contact any sharp authorized repair center.
Sep 13, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp vl-z8 dew light keeps coming on
It seems that the due detector can suffer from bad soldering or soldering alteration after few months of use.
1. The (ideal but uneasy) solution consist to fix this solder by making a clean new one, I personally did it, and it worked for a few months without a problem anymore ; but then it came back again.
2. The other solution consist in short-circuiting the dew detector to eradicate the problem.
Of course, it will also mean that when real dew will happen you may use the video tape recorder when you shouldn't, but at least you should not see the problem coming back again some months later.
To know more about this dew detector circuit and how to fix it the way you want go there:
http://ataplow.googlepages.com/sharp-dew-problem
a zoomed picture of where to fix the detector can be found here:
http://ataplow.googlepages.com/sharpdew.jpg
Hope this will help as it helped me,
Good luck,
Fabien.
Sep 25, 2008 | Sharp VL-Z800U Mini DV Digital Camcorder
Sharp viewcam
my sharp viewcam model no VL-E650U CAN NOT PLAYBACK IN COLOUR AND SOUND
Apr 18, 2008 | Sharp Viewcam VL-Z3U Mini DV Digital...
Dew indicator
look inside the camera to the front.wou will see 2 solder bloba,run a line of solder between them to by pass the dew,it works
Nov 04, 2007 | Sharp Viewcam VL-Z3U Mini DV Digital...
E007 and DEW indicator
Few restarts fixed this for me but I know this is going to come back again soon.
Mar 30, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Camcorder Error
for a quick fix I usually override it by slightly opening the tape when its being loaded, i think its a sensor issue. my cams been rendered useless because of this stupid error, I cant even sell it now because it only works 10% of the time and that's usually when im just checking out the cam, only when I need it the most does it screw up on me
Jun 06, 2006 | Sharp Viewcam VL-A10U Camcorder
Sharp Viewcam VL-Z1 Mini DV Digital Camcorder Logo
262 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
