Question about Panasonic Televison & Video
I have a Panasonic DVD Recorder Model DMR-ES46V with error code U61, which basically states that there might have been a power failure while the unit was on and the unit is in the recovery process. I had this problem about 18 months ago and resolved it by cleaning the laser optic and the overall unit. I’ve cleaned it again but the unit is still displaying the U61 error code, even after power cycling several times. I suspect that the laser assembly may be worn out. I have had the DVD about four years and have recorded more than 1500 DVDs. I have repaired may electronic devices over the years but haven’t worked on DVD players much, I wondering what might be wrong and if its worth fixing if I repair it myself. Thanks, Chris
  • XFLY Jul 20, 2008
    Removed the "four" screws holding the DVD drive top in place. Then moved
    the drive head mechanism back (towards the back of the unit).
    Plugged in the power, turned it on and had the same u61 error code. The drive head mechanism didn't move much, <.02". Any other Idea? Thanks
    Master:
  • 848 Answers
Take out the 3 screws holding the DVD drive top in place. And then move
the drive head mechanism back (pushed it towards the back of the unit).
Then plugg the power in, turn it on . This will remove the u61 error code .
Posted on Jul 20, 2008
    Genius:
  • 1,847 Answers
"unit is carrying out a recovery process, don't do anything , just wait till display returns to normal, remove disc first."
  • Legin Varghese
    Legin Varghese Jul 20, 2008
    don't know yet what the final outcome will be, but here's an update: I called Panasonic customer support. After going thru four phone transfers I finally reached a fellow who agreed that since I was only a couple of months over warranty, Panasonic will pay the UPS cost to return it to their service center where they will seek out the cause of the problem. Originally he did ask me to try simultaneously pushing down on "channel up" and "channel down" buttons (under the hinged front panel). That's supposed to give the unit a chance to reset (didn't help in my case}. I've read elsewhere that there may be a particular capacitor that tends to leak in these units (and is not expensive, but is very difficult to replace because of its location buried under other parts). I'm waiting now for a confirmation letter directing me how to send in the unit. I'll let you know more later.
  • Panasonic Master
  • 19,396 Answers
Try replacing the whole lens pickup, it is an easy job and part is not expensive.
  • Ginko
    Ginko Jul 20, 2008
    About the error U61, if you find a firmware upgrade for this unit you should be able to fix it by upgrading firmware.
    Here is a picture of a lens pickup, just replace it on your DVD:
    Just replace the lens block
All functions are not working; it will power on, the dvd tray opens, then it makes 5-6 odd noises displays U61,and then powers off by itself w/ the dvd tray still open.. I unplugged it over night and tried...
U61 is an error code which may indicate that the DVD drive is faulty, and/or the digital controller board (which the drive is connected directly to via ribbon cables/plugs). Unfortunately this is not a cheap service option, both the DVD drive and the board may require replacement by a workshop technician, which, assuming the replacements are available, could make this uneconomical to repair (these are not repairable at individual component level).
However, you can always submit the unit to an authorised repair centre, obtain a quote (on the likely cost(s) including parts and labour involved) and a second opinion (as to whether or not the DVD drive is defective and a new one is needed along with the digital controller board) - then you can make a firm decision afterwards as to what to do from there. Up to you.
Judging by your query, it sounds like your DVD drive is probably shot and should be replaced; hopefully the digital board connected to it is fine and does not require replacement - just the drive itself. The workshop quote should provide a better insight on the actual problem and the expenses it may entail.
Apr 28, 2011 | Panasonic DMR-ES46VS DVD Recorder/VCR
Panasonic dmr-es46v player recorder error code u61. what do i due
That error means: There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
I suggest you unplug all the cords o the unit and after 2hrs replug and see if the error is gone.
Let me know the result.
Thank you for using fixya.
Jan 03, 2010 | Panasonic DMR-ES46VS DVD Recorder/VCR
Paqnasonic DVD recorder Model DMR-EZ45VEBS is stuck with error code U61, and now will not play any disk. Every time I insert a disk it comes up with the error code, Problem started whnI was recording a TV...
try cleaning the OPTICAL LENS directly with a Qtip , gently rub , try again , the code U61 means a self test procedure that the unit is running according to PANASONIC tech people, good luck , AJ
Nov 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-ES15 DVD recorder startup failure
The unit failed during self check, probably the power regulation board. A check by a qualified TV/VCR repair person is in order.
Nov 20, 2009 | Panasonic DMR-E55 DVD Recorder
Panasonic dmr-es35v dvd/vcr recorder reads hello, then u61, then
Plug AC power cord to wall electric socket if it is plugged into a surge protector or extension, if not try a different socket, if issue still exist have unit service.
Sep 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Feb 26, 2009 | Panasonic DMRES15 DVD Recorder
Error code U61 on a panasonic DMR-ES35v When I turn it on it says "Please Wait" end the code U61 occurs after som while.
The manual refers to the U61 as being a recovery mode. Have you left it at U61 for a period of time while it tries to recover?
U61 ≥There was a power failure or the AC plug was disconnected while the unit was on. The unit is
You could always try to force it into standby mode and back out again:
Press [í/I, POWER] on the main unit to switch the unit to standby.
Now press [í/I, POWER] on the main unit again to turn the unit on.
If that doesn't take care of it, everything thing I've found points toward a replacement of components inside the system by a repair service. Hopefully you are still under warranty!
Aug 30, 2008 | Panasonic DMR-ES35VS
Error code u61 will not clear, unable to reset the DMR-EZ45VEBS
Hi, there was no solution to my problem with the error code U61, having talked to a Panasonic repair center it would cost £180.00 to fix this unit as the board and DVD recorder have to be replaced as one unit. It would cost me around £160.00 to buy a new one so there was no point in having it repaired.
Aug 04, 2008 | Panasonic Televison & Video
Panasonic DVD/VCR message U61
Dear stds ~ My DVD Recorder Keeps Opening & Closeing The Tray A Gives An Error Message Saying ~ Repair Has Failed ~
DVD Recorder ~ DMR ES46V Panasonic ~
Error Message ~ U61 !
If Possible To Resolve ~
Please Do !
Before I Buy A New One !
Please Respond ASAP To ~ glvw@nyc.rr.com
Thanks !
May 22, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
Model No'DMR-ES15 - U61problem
I get this message occasionally on my Panasonic DMR-ES15. It's actually a really simple fix. It occurs when there is a corruption in the disc which causes the recording mechanism to malfunction. There is a separate error message for this, however it is usually not detected until it's too late. When the recorder asks you to carry out the recovery process, do it. When the disc ejects, make sure you take the disc out that was in there when it occured and throw it away...it will keep happening because the disc is permanently corrupted. However, do not close the tray without a disc or the self-check will fail. Instead pop in a disc of the same format that the error occured in (if it was DVD+RW then put in a DVD+RW). It resolves the problem every time on the first try. (It only happened two times in a year and a half for me). As the manual says the unit is "NOT BROKEN".
May 23, 2007 | Panasonic DMR-ES10 DVD Recorder
Televison & Video Logo
379 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
