Question about Smeg 23 in. SE64 Gas Cooktop
Auto ignition won't stop
The auto ignition is trying to light on 3 of the jets. i have wiggled the knob to see if its stuck but cant seem to see that its stuck. how can i stop the noise
  • Anonymous Jul 20, 2008
    we have a belling with the same problem no idea how to stop it clicking \\\\\\\\\\\\\\ ggr\rrrr
  • akkadian May 02, 2009
    Have same issue on a Smeg gas hob. Found that by removing all four knobs and pressing each red ignition button in turn I found one that was sticking. After a few presses it seemed to become unstuck.
  • 93 Answers
If you accidently got the igniter switches wet, this will happen. If you lose a good ground on he unit this will also happen. Check both of these to see if that helps.
Posted on Jul 21, 2008
  • 59 Answers
Hello
I removed mine and cleaned them and they worked good exepct for the right front one, I had to replace that one, it cost me $15.00. To remove the sending unit to the ignitor, they are located in the switch rod, just remove the knobs and remove the switch covers and they are white with 2 wires attached to them, just remove the wires and lift, then clean good and put back on.
Hopes this Help
Eddie Rentas
Tupper Lake NY
Broken knob
Turn off the power to the appliance. Squirt WD40 liberally all round the knob, trying to get it in behind it. Wiggle the knob and press it down and up if possible to let the WD40 oil work in to the dirty or stuck joints. Leave for a few hours and wiggle it again to see if its loosened up.
Dec 15, 2013 | KitchenAid 30 in. KECC506R Electric...
Continuous clicking from an igniter in the off position. I have to slightly turn the control knob towards the hi position to stop the clicking and for the light on the control knob to go off
sounds like it was turned a little past the stop point.
Pull two knobs off and examine the back side that slides onto the shaft.
Switch them and try again.
If the problem is on the same burner, the shaft may be turned past its normal stop position.
You can try turning it until it stops in the opposite direction and force it just a tiny bit more.
That was how I fixed mine.
Nov 06, 2013 | DCS 36 in. CP-366 Gas Cooktop
The ignition on my hob is sparking every second or so constantly on it's own? The knobs don't seem to be stuck down or anything obvious. All four ignition points on the cooking points are visibly sparking.
I think the problem lies at your knob mechanism. Try to service the mechansm. Currently the possible problem is lies at the contact point(electrical) might accidently contact without pressing down the knob. This normally occur when it is hyper press or there are grease in between the contact. Possible solution is replace the damage knob... or repair it.
Aug 19, 2010 | Cooktops
R rear burner not sparking
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 02, 2010 | Dacor Preference SGM365SS Gas Cooktop
Dcs igniters
clean the knob control by using vaccium,pull the knobs then clean it.make sure how to remove the knob,same position to returrn the knob
Jun 30, 2009 | GE Profile JGP636 Gas Cooktop
The ignitor sparking will not stop in after the
when you turn the knob or push a switch is going to the on posicion so that means that the switch is stuck in one of the knobs , you just have to see witch one is stuck
Jun 18, 2009 | Wolf Range 30 in. SCB30C Gas Cooktop
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
Stuck auto ignition
try easing each knob upwards a bit.
Jul 15, 2008 | Smeg 23 in. SE64 Gas Cooktop
Automatic Eletric Ignition stopped working
It's is normal for the ignitors not to work when wet, once they dry they should work. The best thing is to check the electric sending unit, they are a small white kind of square that goes on the switch, just lift the knobs and take the cover of the switches and you should see the sending units righ on the rod that hold the knobs, they have to small wires attached to them, It seems to me that thats were your problem is.
Do you hear the click clik when you put the knob on LITE??
May 19, 2008 | GE 30 in. JGP336 Gas Cooktop
Stuck auto ignition
Either one of the ignition switches are stuck down internally or the ignition pack is faulty, no other possible cause. Regards Advisor
Aug 29, 2007 | Smeg 23 in. SE64 Gas Cooktop
Smeg 23 in. SE64 Gas Cooktop Logo
538 people viewed this question
Top Smeg Cooktops Experts
ray gallant
marlin siecinski
Bill Boyd
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
