Back to:
Tags:
Cars
Generic problem for all Lotus Elan Cars
Doesn't seem that the turbo
posted by andycarlsimp on Jul 20, 2008
doesn't seem that the turbo is working
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Oct 05, 2008
Not Rated (0)
rossv3
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
with the engine cold remove the turbo outlet hose and check for free rotation of the spindle. if it is ok check the wastegate capsule link arm mechanism is not seized as this is fairly common. if all is ok check the pipe work from the turbo outlet to the intercooler (lh side below airfilter headlaamp area) then from intercooler through up to inlet manifold. if all is ok, get a manual pressure gauge on the take off port at rear of inlet manifold should be a pipe blocked off with a rubber bung (lh side back of manifold) (lh side is gear box side of engine) drive car an see what the gauge reads. if it is registering boost then is often the manual boost transducer module on the right hand wheel arch by the cam belt cover that is not working so boost is there just does not register in the car.full boost is not achieved until car is at normal operating temp. if no boost turbo may need checking for wastegate operation or damage on the exhaust side. Hope this helps
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on doesn't seem that the turbo:
I don't want to Accept this solution
Can you Help with these Cars problems?
1998 Chevrolet Malibu
The fog lights on my 98 chevy malibu stays on even when...
2003 Dodge Caravan
Dear Expert: I have a 2003 Dodge Caravan, which has only...
1999 Honda Accord
how do i replace an inginiton on a 99 honda accord, it...
2003 Nissan Altima
I am an auto repair novice and wanted to know how to...
1984 Nissan Pickup
the tachometer just stopped working at all in my 84 nissan...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
