Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Sandisk flashdrive i need help. i dont no how to use
  • 64 Answers
Also known as pocket drives or thumb drives, your flash drive is basically a portable memory stick that acts like a hard drive, allowing you to carry documents, pictures, music, or any type of file with you.
When you plug it in to your usb port, after a minute or two, you access your thumb drive by double-clicking the My Computer icon, or using Windows Explorer. At that point you simply use it as you would any other drive.
Posted on Jul 20, 2008
I just bought a sandisk flashdrive from radio shack and its saying that it needs a password
write to the companey via email exsplain the problem they will give u a code that will work
Nov 13, 2013 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do I put pictures from my home computer onto the SanDisk?
Once you plug the sandisk into your computer, a window should pop up asking you if you want to view the files on the disk, if it does, click on it. If not, just go to Start Menu -> My Computer -> (The Flash Drive). Move this window to the side so you can see the desktop aswell as the flashdrive folder. (You have have to 'demaximize' (Restore Down) the window so that you can see the desktop aswell. Then go to the start menu again and go to "My Pictures" or wherever your pictures are located. then, you can click and drag the pictures from the "My Pictures" folder into the FlashDrive's folder. Once all the images are copied into the flashdrive folder, you can unplug the flash drive and the images will be on it.
Hope this helped, Nathan Taylor
Jul 21, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How to get the pc games to the removable disc(J) sandisk.Can not Move them to Flashdrive disc.
It is not completely clear if you mean large PC games or if you mean small PC games.
By small PC games I mean games similar to the games that come with Windows and that appear in the 'All Programs -> Games' folder. Such as 'Free Cell', 'Hearts' or 'Solitaire'.
By large games I mean games like 'World of Warcraft' or 'Mortal Combat'.
Also, do you want to install the games on your Flashdrive or store them there?
If you want to store a large game on your flash drive. Place the CD/DVD with the game on it in your CD/DVD drive and insert your Flashdrive in a USB port.
Open 'WIndows Explorer' or 'My Computer'. Locate the CD/DVD drive that you inserted the game disk in (most likely your D: drive).
In the 'Edit' menu select 'Select All' and then in the 'Edit' menu select 'Copy'.
Then locate the Flashdrive in 'WIndows Explorer' or 'My Computer'. And in the 'Edit' menu select 'Paste'.
While this will copy the files from your game's CD/DVD disk to your Flashdrive you may or may not be able to install the game from your Flashdrive.
You can use this same procedure to copy small games to your Flashdrive from your Hard Drive.
You will need to know where on your hard drive they are located. And they may or may not run from your Flashdrive.
Also you may be able to install and run games from your Flashdrive, When you run the Setup program from you game disk you will usually be given the option to select a alternative location to install the game.
Select your Flashdrive at that point and it may install correctly to your Flashdrive. If it does you should be careful to always use the same USB port or the game won't run.
Hope that helps.
Jul 04, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk 8GB lights up but wont register
This one is just a hunch. The drive might be bad but this is worth a try. Its possible the drive letter somehow changed on the flashdrive. Plug in the drive, RIGHT click on "My Computer" and select "Manage" from the drop down menu. Now select "Disk Management" from the list. If you see your flash drive on the list, right click on it and select "Change drive letter and paths", then click on "change", now assign it a new letter like "F" for example. Click ok, ok, ok. If it showed up the the list and it's still not registering, unplug it and plug it back in. Hope that helps.
Feb 15, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Whats wrong with my flashdrive?
Are you on Win_xp? If so, are you the administrator? If not Win_xp won't let you delete ANYTHING!
Jun 22, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Scandisk/flashdrive
"Scandisk"? Do you mean "Sandisk"? If you do, there is no difference between a sandisk and a flashdrive. Sandisk is one of many companies that manufactures flash drives.
Mar 18, 2008 | Computers & Internet
Sandisk cruzer micro flashdrive - not working on vista
you'll need to go to the sandisk site, and get a vista driver set..
Mar 11, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Malfunction
unfortunately the files cannot be recovered immediately, macs a are compatible with PC flash drives but not the other way around. you need to format the disk. go to start>my computer> then right click on the flash drive and then left click on format, then click ok. when it is done bring the flash drive back to the mac and put the files back on. now try putting the flash drive into the pc again
Jan 23, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
Flashdrive wont start
Delete all your USB drivers from device manager and then restart your computer. This will allow the computer to re-detect and install them. This should fix your problem.
You can get to device manager by opening control panel, then system, hardware, then device manager.
Dec 05, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
46 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
