Question about Kenmore Kitchen Ranges
Kenmore gas range model 790.75863. When pre-heating oven the "preheat" light comes on but when oven reaches temp the "preheat" light does not turn off indicating oven has reached temp. The oven is hot and the "oven" light cycles on and off as the unit regulates the temp, but "preheat" light wont turn off.
fridgetech
  • 473 Answers
SOURCE: bake part of kenmore not working seems to take to long
Chances are the oven ignitor will need to be replaced.  Look and see if it glows.  If it does then it is weak and not opening the gas valve to lite.  Let me know what you find.
Comment by fridgetech, posted on Oct 20, 2007
Should be able to remove the bottom drawer and unplug the ignitor from below.  Or you can cut the wires on the old ignitor and splice the new one in using ceramic
Posted on Oct 20, 2007
  • 146 Answers
SOURCE: unable to preheat
You need to replace the temp. sensor. It's not reading correctly. These occasionally go when you use the self clean as the range gets up as high as 900 degrees. Replace it and it will solve the problem
Posted on Dec 21, 2007
textonor
  • 130 Answers
SOURCE: Preheating Oven
Cold Stove, you may not be able to. The issue here is that oven manufactures put on their units a fast preheat. However it isn't possible to preheat an oven for 7 to 9 minutes and bake short time bake items properly. Also the oven sensor will respond faster than the absorbation rate of the sheet metal in the oven liner. To preheat an oven properly takes 15 to 20 minutes before putting in the food. I see this will a lot of current ovens. Sounds like a normal format of the control.
Posted on Feb 04, 2008
aborcass
  • 2651 Answers
SOURCE: I have a hotpoint RGB745 oven temp problem
sounds like abad oven ignitor issue, repalce hte ignitor nad it should light everytime
Posted on Mar 16, 2008
  • 409 Answers
SOURCE: TAKES TO LONG TO PREHEAT
sounds like the thermostat may be open and nees to be replaced. have a technician take a look at it.
Posted on Sep 13, 2008
My Kenmore Model 91195371790 oven Preheat light comes on as soon as you turn oven on and then flashes f2
Over-temp condition due to either oven temperature sensor or ERC (electronic range control).
Testing should be done by a qualified tech to prevent risks to user.
Jan 16, 2015 | Kenmore Ovens
Kenmore oven shuts off before preheated
On any gas appliance there is a high and a low limit temp stat which could be indipendant or on the gas valve it's self, that is faulty.
When the oven reaches temp, it cuts out. sounds like faulty over heat stat.
Mar 21, 2014 | Ovens
Oven lights ,but doesn't heat to preset temperature
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jun 17, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
Feb 26, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
I have a 4 yr old kenmore glasstop electric range. Problem exists with the broiler as it comes on when I set the oven to bake.
this is normal
about 8 years ago manufactures started to include the broil element in the preheat cycle to heat the oven faster
it should cycle down once the set temp is reached
Sep 27, 2009 | Kenmore Kitchen Ranges
Caloric Heritage Series oven has no preheat achieved indicator
I have the same range. There is an indicator light next to the temperature setting for the oven. when it comes on, it's pre-heated.
Apr 05, 2009 | Heritage Kitchen Ranges
Kenmore gas range--oven won't come on
My oven will not work. After pressing the desired temp on the oven, the preheat light and oven light comes on. After about 15 minutes, the oven is slightly warm and maybe an hour later the oven may or may not heat to desired temp. Kenmore gas range model #790.72851301.
Nov 15, 2007 | Kitchen Ranges
Preheat issue with a new kenmore electric range
times quoted seem about right and don't suppose your old oven was much different. element ratings don't vary much for same size ovens
Jun 07, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Kitchen Ranges Logo
107 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
