Polaroid 4241-TLXB 42 in. LCD Television Logo
JAMES EASTIN Posted on Jan 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen shows narrow vertical color lines across screen with no sound or picture what causes this and what fixes same.
  • JAMES EASTIN Feb 01, 2011
    THANK YOU FOR YOUR PROMPT RESPONSE, I HOPE TO HAVE IT REPAIRED ASAP.
  • JAMES EASTIN Feb 04, 2011
    LOCAL REPAIRMAN IS ON IT. THANK YOU FOR THE INPUT.
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Jan 31, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2467698
Points
19564
You have problem with the Tcon. Please check it and get repaired or replaced. Check also the audio circuit. Regards
Anonymous
Level 3:
  • Master 4,889 Answers
  • Posted on Feb 01, 2011
Anonymous
Master
Level 3:
Answers
4889
Questions
8
Helped
1512227
Points
14106
This is definitely a problem with the audio/video processing circuits. The easiest way to fix this would be to replace the main A/V board. Costs about 100$. I can find you a replacement if you wish to fix it yourself.
Sai.
  • Anonymous Feb 04, 2011
    You are welcome. Please do click the accept button next to my solution if you found my solution helpful
My Vizio TV has a bar of colored lines running veritcally over the picture. Should I replace the T-Con board?
What causes vertical colored lines on a TV screen? When a TV is showing vertical colored lines, a loose wire cable in the TV might be the cause. If you knock on the back of the TV, the vertical colored lines MAY disappear temporarily. This is a sign that a cable is loose or the T-Con board is faulty.
https://removeandreplace.com/2018/05/01/tv-has-different-color-vertical-lines-on-screen-how-to-fix/
What part is needed to fix colored vertical lines across entire screen of Samsung tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Toshiba 27A40 has single colored line across enter
Vertical output has cracked soldering. Around $150 to fix.
Horizontal color line across the screen
Most likely a bad Vertical IC or bad connections on the vertical IC. don't continue trying it on. If you have a bad connection it could do more damage. You also could damage the CRT ( picture tube ). If you remove the cover and look at the bottom side of the PC bord with a good magnifiing glass you may see what looks like rings around the leads comming from the Vertical IC. The Vertical IC is mounted on a heat sink usually towards the front of the set looking from back. If you do see the rings around the leads try reheating with a solder iron. If this dosen't fix you most likely need a new IC.
2helpful
No picture, only a horizontal line across the screen
Hi and welcome to FixYa,
Your described problem indicates failure at the vertical deflection circuitry. Almost always, this would be a defective vertical IC. In some instances, this could also be caused by the absence of Vcc (supply voltage) to the said IC. This is a relatively easy/quick repair. What would be more challenging is identifying the IC, removing it, and replacing. Replacement would be readily available from most electronics part stores including Radio Shack.
Good luck and thank you for using FixYa.
2helpful
2answers
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
2answers
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Television has no picture
That TV uses the PTK195 chassis, and the fact that you see only a thin line for each color near the bottom of the screen tells me your vertical output IC has stopped working, and is putting a small DC voltage across the yokes. I have seen this caused by a defective vertical output IC and I have also seen vertical problems caused by a small CRT coolant leak which drips onto the main board near the vertical output IC. If you do not have experience servicing the PTK195 chassis than have a qualified tech handle it for you.
POP and noothiing
yes it can still be fixed! the pop sound you've heard maybe came from a blown capacitor in the vertical deflection circuits. this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
