Question about Intel Motherboard
Beeps ok i have problem with mainboard. Just placed old sdr to ddr and now pc give me only beeps like 1 long beep an 2 short. Can u tell me what that means... Jukka
  • Anonymous Aug 27, 2008
    Biostar K8M800-M7A Motherboard
  • 68 Answers
Video card problem
Posted on Jul 22, 2008
1 long beep and then 3 short beeps
Hello here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5KPL-AM%20SE&p=1&s=22
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
It seems to be a graphic card problem, or the power supply not giveing enoug power.
Try to change the graphic card.
If you are useing the onboard graphic, look for bad caps on the mainboard:
If they look like this, the mainboard is dead.
Good luck
Feb 16, 2013 | ASUS P5KPL-AM SE Motherboard
ASUS P4V800D-X AMI BIOS AMERICAN MEGATRENDS BEEP CODES
Hello here is some beep codes:
Beep CodeDescriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed
My guess is you have a ram/memory module failure.
Try to renew the ram module.
The asus homepage is here:
http://support.asus.com/Download.aspx?SLanguage=en&m=p4v800d-x&p=1&os=
Here you can download a manual.
Please unzip the file when downloaded.
Your mainboard is using following type of ram:
Dual Channel Memory Architecture
4 x 184-pin DIMM Sockets support max. 4GB
PC3200/PC2700/PC2100 non-ECC DDR SDRAM memory
These module does not exist bigger than 1GB.
Oct 15, 2012 | ASUS Computers & Internet
1 long beep 2 short beeps
sounds like you've got a dead graphics card
May 16, 2012 | Nvidia Geforce FX5500 5500, (256 MB)...
My hp-compaq dx2300 microtower restarts automatically when working. It is installed on win xp sp3. Please let anyone help if solution is known.
Hi names Rui, i question for you does your PC give a beeping sound when you turn it on? if does can you tell me how many beeps it gives?
if it give a designated number of beeps this might be the problem i will give you a chart so you can differentiate the warning beeps you hear.
warning beeps:
1 Short Beep DRAM refresh failure
2 Short Beep Parity circuit failure
3 Short Beep Base 64k RAM failure
4 Short Beep System time failure
5 Short Beep Process failure
6 Short Beep keyboard control gate A20 failure
7 Short Beep Virtual mode exeption failure
8 Short Beep Display memory read/write test failure
9 Short Beep ROM BIOS checksum failure
10 Short Beep CMOS shutdown read/write error
11 Short Beep Cache memory error
1 long, 3 short Beep Conventional/Extended memory failure
1 long, 8 short beep Display/Retrace test failed
hope this will determine the problem if none of this warning beep is heard try reseting the power botton in you PC cause sometimes the power botton will loosen cause of continuous use of the botton.
hope this will help you.
Jul 20, 2011 | HP Compaq dx2300 Microtower - RT950UTABA...
I have gigabyte p67 ud4 motherboard and i get 1 long beep and 2 short beeps i reseated the video card and the ram i checked every power connector they all are connected
Your mainboard may be one of the mainboards on the P67 Chipset in that the SATA Controller dies.
These mainboards have been recalled by Intel, you should contact the place of purchase for warranty support.
Try to turn on the PC with no SATA devices connected.
Claim warranty support ASAP!
Be sure to rate this solution, thumbs up!
Thanking you
damnor01
Mar 18, 2011 | Gigabyte motherboard - GA-P67A-UD4
After turend on there are 3 beeps, no display, ram are ok tested
It is a memory problem. Verify if they are plugged in the mainboard slot.
Jul 13, 2010 | Intel DG965RY Motherboard
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
It does not start, gives one long beep (about 2-3 seconds) silence and beep again
Switching DDR cards solved the problem. I was getting long beeps every 2 seconds. No short beeps. Just one long beep every 2 seconds. Thanks Josh Whitehead.
Apr 23, 2009 | Computers & Internet
HP P4B-MX beep
HP P4B-MX is Award Bios
Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
Jan 19, 2009 | HP (5185-6477) Motherboard
Desktop PC
Hi mos, Your board uses an AMI bios. You can see the specification here: http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=46&CategoryID=-1&DetailName=Specification&MenuID=1&LanID=9
AMI BIOS beep codes
1 short = DRAM refresh failure
3 short = Base 64K RAM failure As noted at this link: http://www.computerhope.com/beep.htm
Suggest you remove your memory & re-seat one dimm at a time booting after each re-seat. If this is new memory insert old just to check board function. Shut down & try new memory. It wouldn't hurt to check against the manual pg. 6
2 DDR (184 pin, 2.5V) + 2
SDR (168 pin, 3.3V) DIMM sockets with a total capacity of 2
GB system memory
Need to test you memory? http://www.memtest.org/
Scroll down, about half way down the page to where you'll see............
** Memtest86+ V2.00 (08/02/2008) ** Typed in red. Pick you flavior.
Download - Pre-Compiled Bootable ISO (.zip) for CD OR
Download - Pre-Compiled package for Floppy (DOS - Win)
Feb 20, 2008 | EliteGroup P4VMM2 Motherboard
Intel Motherboard Logo
77 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
