Hampton Bay Portable Air Conditioner
Our Hampton Bay portable air conditioner constantly drains water! The "drain water" light goes on and the unit shuts off until you drain the water. If you leave the water drainage hose attached and a pitcher under it, the unit will continue to run but will constantly empty water into the pitcher -- by the time we wake up in the morning the pitcher is almost full. We have never had this much water accumulate in such a short amount of time, why is it all of a sudden doing this? Thanks in advance for any advice.
SOURCE: Owner's manual for a Hampton Bay HBTE120 Air Conditioner?
http://www.appliancefactoryparts.com/content/pdfs/118255.pdf
this is the pdf of the manual for that particular model of a/c.
hope that helps.
Posted on Aug 29, 2008
aroracaty2
  • 503 Answers
SOURCE: We have a portable air conditioner. It keeps
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
If you doubt the veracity of this information, or it does not work as
expected, you can get it directly from the source at:
1-800-237-4277
which is the Sharp customer service line. But, you'll need to call
between 7 AM and 7 PM US Central time, and have your model number and
serial number ready
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Jun 28, 2010
SOURCE: beaumark portable air conditioner operation
Beaumark air conditioners are made by GE…head over to their site and download a manual for their air conditioners - they are very similar.
http://products.geappliances.com/ApplProducts/html/GEAResults.htm#Category=Window_Room_Air_Conditioners
Posted on Jul 06, 2010
SOURCE: carrier holiday portable air conditioner manual
Mine has a model number of PCA061D.
If you remove the water capture reservoir, there is a sticker that has the model number.
Posted on Sep 29, 2010
SOURCE: Parts for Amcor Portable Air Conditioner
need a window kit for amcor kf9000e.
Posted on Jun 09, 2011
The DeLonghi PACA130HPE 13000 BTU Portable Air Conditioner unit will not function. Unit displays the Alert symbol only and no other designation as identified in the product manual. The unit was in heat...
I had the same problem, you have to empty the water pan in the rear of the unit. In the heat mode it will NOT evaporate the water like in the air conditioner mode. If you use it a lot in the heat mode and have a lot of moisture in the house you will have to modify the water outlet to have it constantly draining in a pan or out of the house.
John
Oct 09, 2012 | DeLonghi PACA130HPE 13000 BTU Portable Air...
I have a portable air conditioner model LP0711WNR. My issue is when I drain the air conditioner, it only drains about one cup of water. Then, when I turn it back on it and use it, after about an hour it...
The easiest way, is to tilt it over slightly when you drain it. But, be very careful doing this, as the unit has caster wheels and you don't want it to get away from you. If you have a helper, so much the better. Remember to always turn the unit OFF & Unplug it, before draining the water from the tank.
I hope this helped you and thanks for choosing FixYa.
Jul 21, 2011 | LG LP0711WNR Portable Air Conditioner
Air conditioner shuts down constantly, need to
Sorry but you are just going to have to keep emptying it. These types or air conditioners are also use as de-humidifiers and unless you can place it somewhere where you can connect a drain hose it is going to require many trips to dump the holding tank of the condensation.
Jul 12, 2010 | LG LP1200DXR Portable Air Conditioner
Constant leaking water
The unit must be level and the hose lower than the machine. -Good Luck-Ned_
Aug 23, 2009 | Frigidaire FAP094P1Z Portable Air...
Amana AP095R Portable Air Conditioner is dripping water constantly. It didn't use to do this. What's wrong here?
all air conditioners condense water .. the water is normally drained to the outside thru a hole near the outside bottom of the unit .. the unit has to be mounted so that it doesnt tilt inward .. the drain hole has to be cleaned once in a while ... if its clogged or if the unit is tilted inward then the water will drain inside the house .. less likely but possible is a cracked or damaged drip pan inside the unit ... thats a shallow pan under the condenser (cold) coil that captures the water and directs it toward the outside drain .. so check the tilt and clean the drain
Aug 17, 2009 | Heating & Cooling
We have a 9000 btu portable frigidare air conditioner, we are constantly having to manually drain the bucket even with drain pump hose attatched. Is it possible tat the drain pump is broken? Occasionally...
Wow maybe you have a lot of moisture in the air.
It is a strong posibility the pump has trash in it. periodically clean out the pump for best results.
I realy have never even seen a 9000 btu portable ac or worked on one. Just guessing.
Jun 25, 2009 | Frigidaire FAP094P1Z Portable Air...
New unit has loud noise & doesn't drain. Too late to return!
drain line kinked? trying to diagnose a noise problem over the inter net really hard . could be compressor
Jun 17, 2009 | Danby Portable Air Conditioner
Wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Apr 01, 2009 | GE APN08AA Portable Air Conditioner
Excessive water draining from portable A/C
It appears that you have changed the location of the unit, I mean have you relocated to an area whwre the humidity is high, usuallly coastal areas have high humidity.If not is there a door that is being constantly left open causing a lot of fresh high humidity air into the room
Jun 04, 2007 | Maytag Portable Air Conditioner M6P09S2B
Heating & Cooling Logo
548 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
