Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Downloading from sd card
Have just purchased a 5300 aio and am unable to download pictures from a 2gb SD card using the slot on front of machine. Works ok with 1gb.
  • 1 more comment
  • s89725 Jul 21, 2008
    Light comes on when sd card is inserted and reads my 1gb card okay . light also comes on for 2gb card and lcd screen says reading card but nothing happens.
  • tonyeo Jul 21, 2008
    kodak 5300 will not read 2g memory card
  • Matt D May 11, 2010
    What happens when you put the SD card in?
    Scholar:
  • 96 Answers
Thats a difficult situation and I apologize if this does not work. These are a few things Kodak will tell you to try though.
Take the sd card out.
Power the printer off.
Unplug the printer, you must do this for over 30 seconds.
Plug the printer in and turn it on.
Try the sd card again.
If that does not work, try a firmware upgrade from www.kodak.com/go/5300downloads.
As always, verify that the SD card is not configured with folders on the card. Aka Pictures cannot be in folders.
One other thing you could try is to format the SD card from your camera. This will delete your pictures though.
If none of these steps work, you may just need to try a new card.
Posted on Jul 22, 2008
Unable to use SD card higher than 2 GB capacity
If you're using a card larger than 2GB then it's an SDHC card, not an SD card. The *ist DL works with SD cards, which top out at 2GB. Even though higher-capacity SDHC cards will fit into the slot, they will not work with this camera.
Dec 30, 2013 | Pentax Ist D 6.1mp Digital Slr Camera With...
Can't find manual, SD card unusable. HELP!!!
The X1 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to use an SD card, 2GB and smaller.
You may download a copy of the manual from here.
Oct 17, 2012 | Konica Minolta DiMAGE X1 Digital Camera
In my computer right click on memory slot try to format it .it displaying microsoft unable to format it and in disk manger also it is showing unable to format. please give an appropriate solution.
look at page "3/9" of this document "http://www.pqi.com.tw/upload/download/SD%20%284%29.pdf" and it will show on the lower right hand side of the picture a slot that says "write protect", move that tab to unlock the card.
BTW this is a good technical document for SD cards in general if you are interested in how they function.
Sep 04, 2011 | PNY 2GB microSD Memory Card
I have a new HP computer with Windows 7. Someone gave me a PNY 2GB memory drive with photos I would like to download. Where do I put the memory drive?
that all depends on the model of your laptop, most current laptops have a slot for a standard sd card, if this is the case you will need a micro sd adapter.
if you dont have a port for an sd card you have 2 options, first you can buy a usb memory card reader (making sure it takes micro sd cards before you purchase) or, most mobile phones take the micro sd card so you can put it in your phone and either plug it into your laptop using a usb cable and try getting them that way, or if you can view the photos on your phone, bluetooth/email them across.
Aug 08, 2011 | PNY 2GB microSD Memory Card
I put my sandisk into the front of my computer, and my computer hasn't yet recognized it. How do I access my pictures?
As stupid as this sounds, make sure the micro SD is in the correct slot and fits snugly. If you find that you don't actually have a micro-sd slot, you can purchase a piece that the micro-sd goes into creating a disk that's SD size.
If that's not the problem, go to Start > Computer > and look for the removable storage device. If it shows up, dbl click on it and see if your pictures come up.
If that doesn't work, you may consider buying an external card reader that connects using a USB port on your computer. That should work. If not, there is a strong possibility your micro-sd is corrupted.
Sep 05, 2009 | SanDisk 2GB microSD Memory Card
Why cant I download my waypoint data to a 2 GB SD card. My Global map 5000c does not recognise the 2GB SD card. Do I need MMC/SD. Can I place the sd card in the slot beside the chart card ?. Thanks
You can place the SD card into the slot beside the chart card.
With the SD card in the GlobalMap unit by itself (take the chart card out), press MENU twice and choose BROWSE FILES. Does the unit indicate that an SD card is present? If yes, the card is working fine in that slot. Try the same thing in the other slot. If it only recognizes the SD card in one of the slots, the other slot is bad and probably won't work with any card. If the card is recognized in the BROWSE FILES menu, but the data that is on the card is not working, there could be compatibility issues with the data and the GlobalMap 5000.
Make sure the GlobalMap 5000 has the latest software update from http://www.lowrance.com/en/Products/Legacy-Products/GlobalMap-5000C/Downloads/GlobalMap-5000C-Software-Update-180/. You might need to get a different, smaller capacity card since your 2GB is not working.
If the 2GB SD card still isn't recognized in the BROWSE FILES menu after the update, the GlobalMap 5000 is not going to work with that 2GB card. You will want to get a different card. I suggest 1GB and smaller.
If this doesn't help, please let me know some more details. Is the 2GB SD card recognized in the BROWSE FILES menu. What are you seeing that makes you determine it does not recognize this card? What files are currently on this card? What kind of card is it (brand, model).
Jul 11, 2009 | Lowrance GPS
My computer does not recognize my SD 2GB SD Flash Card which I insert into my camera and take pictures. I have a slot on my computer for SD cards. Can I just put the card in the slot and access the...
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
Jun 24, 2009 | SanDisk 2GB microSD Memory Card
SD Card (2GB YES Make) Gives Formatting error
If you have a card reader or a printer with an SD card slot in it, try formatting the card or deleting all files on it using a PC. My laptop has a slot built-in I'm able to use. Check out your options. Try formatting it outside of your camera. I've heard of some card swapping between brands of cameras doing crazy stuff as you are experiencing.
Jan 07, 2009 | Kodak EasyShare C315 Digital Camera
Printer will not read SD card from Panasonic Lumix DMC TZ3
Put the card in an adapter or in your computer. Make sure the pictures are not in folders. The printer is unable to read them if they are.
Also, the file size of the picture cannot be over 8 MB and the image size has to be below 12 megapixels.
Jul 16, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Sd card not reconsized by pc
omg same thing keeps happening i have a vista and i try to download the photo's on my vista but it won't work
Jul 06, 2008 | DSC DV182 Camcorder
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
81 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
