Question about Belkin (F5D5231-4) Router
Putting in new bearings
How do i remove the right rear axle on my VR commodore to change the bearings and the seal??
  • detrosuk May 11, 2010
    how is this a router question, I understood that a VR commodore was a car!
  • 3 Answers
This may sound weird but ill tell you how i did mine.
take off wheel
remove breaks inc disk
from what i can remember there were a couple of bolt to undo behind the disc.
now the tricky part
i used an old axle (need something big and heave you can hold onto)
i used a chain to join axle in car and my spare one
held it in my hands and swing it hard and fast away from car
(pulling on axle you want to remove)
had to do it a couple of times and it pulled the old one out
Posted on Sep 14, 2009
How to replace rear bearings in ve commodore
Commodore's are not sold here in the USA. So I'll give it my best shot on two different rear axle setups Since he is mechanically inclined, Look at it. That's what I do before any job. If you have CV axles in back, This is to easy, he will figure it out. Remove the axle nut, remove the bolts for the bearing. Most light duty vehicles are set up like this. Next is the straight axle. You have to remove the differential plate, on most. Remove the bolt to release the center pin.( some others, you have to pry out the axles). Remove the tires, push in on the axles and remove the C clip, pull the axles out. Use a bearing puller or chisel out the bearings. There are different set ups for nissan's and honda's and lexus. These you have to remove the brakes to unbolt the axle to get them out.
Jul 12, 2012 | Holden Cars & Trucks
I have a 1999 Mercury Grand Marquis. i noticed a little diff fluid coming from the right rear wheel. I changed the wheel seal and axle bearing and put it all back together and filled the rear diff with...
first swap to a front tyre to eliminate that issue
new bearing shouldn't be rumbling
to get the bearing square on and home
did you use a press to fit the bearing to the rear axle
or tube method ?
and did the seal kit have this nifty plastic seal fitter so axle didn;t rip the seal surface
Apr 12, 2017 | 1999 Mercury Grand Marquis
Need to change rear seals in axcles how to? 98 gmc jimmy
First i would check to see if the axle air vent was clear if its not the oil is vary heavy and expands a lot this will build up pressure inside the houseing and cause the axle seals to leak if you can clear it the problem may fix it self its 80 90 weight oil thats thick stuff. If not you need to remove the rear wheels and brake drums then you have to remove the cover from the rear carriar catch the oil. Look inside the carriar houseing you will see the ends of the axles theres a small clip on each axle called a c clip remove them you can pull them out with your fingers. Then you can slide the axles out past the brake plates pry the seals out you might as well replace the bearings when your doing but thats up to you. Lube and install the bearings then the new seals you will need new seals lube the seal lips and vary carefuly slide the axle in taking care not to damage the seal install the c clip do the other side put a new gasket on the rear carriar tighten bolts to 20 ft lbs. Refill carriar 80 90 weight oil through filler plug on the side of the houseing until it just starts to run out hole put the plug in the rear drums on and wheels
Dec 30, 2010 | 1998 GMC Jimmy
I was told I need a new rear barring and axle seal how do I change it?
You have to pull the cover off the rear end and let the fluid drain. Then there is a single small bolt that holds a pin in for the spider gears. You must remove the bolt, pin and spider gears. Then take the wheel and brake drum off the side you want to change. Once thats off you can push the axle in and a clip should fall off the axle inside the carrier. Then you can pull the axle out exposing the seal and bearing you need to change. Just use a seal pulling tool to pull the old seal out and the bearing is under that. It is pressed in so it can be hard to get out. Lots of times they have to be cut out. To put the new bearing back in just use a hammer and socket that is close to the size of the outter edge of the bearing. If you put the bearing in the freezer overnight it will go in a lot easier. Then tap a new seal in and put everything back together and refill the rear end with GL5 put the posi additive in if you have a posi trac rear end. Hope this helps good luck.
Nov 20, 2010 | 1996 Jeep Grand Cherokee
How do you change the rear wheel bearings on a 2004 chevy express 1500 van?
Axle Shaft Bearing & Seal Removal & Installation To Remove:
  1. Raise and safely support the vehicle.
  2. Remove the axle shaft.
  3. If replacing only the seal, remove the seal using a suitable seal removal tool.
  4. If replacing the seal and bearing on the 8.6 inch axle, install the slide hammer and adapter behind the bearing and pull out the bearing and seal together.
  5. If replacing the rear axle shaft seal and the bearing on the 9.75 inch axle, install the J 29712 or equivalent bearing puller into the axle housing behind the axle bearing.
  6. Remove the axle shaft seal and the bearing by tightening the nut on the J 29712 bearing puller.
Use a slide hammer, bearing puller and adapter to remove the old axle bearing 88457g81.gif
To Install:
  1. Install the axle shaft bearing using a suitable size driver. Drive the bearing into the housing until the tool bottoms against the tube.
  2. Lubricate the seal lip and install the seal with a suitable seal driver. Make sure the seal is fully seated in the axle tube.
  3. Install the axle shaft.
  4. Fill the rear axle with the correct lubricant.
  5. Lower the vehicle.
Oct 18, 2010 | 2004 Chevrolet Express
Rear axle removal on a 2004 f150 fx4
First thing is to make sure you chock the front tires so the truck will not roll. Raise the rear end and set it on jack stands. Put the transmission in Neutral and make sure the parking brake is off. Remove the rear tires and disassemble the brakes on the side with the leaking seal. Place a drain pan under the rear differential and remove the cover. Remove the differential shaft lock bolt. You will need to turn the drive shaft by hand to access the bolt. It will be on the right side off the spider gear housing. Only use a 5/16 or 8mm 6 point box end wrench to remove the bolt. After you remove the bolt reach on the top of the spider gear housing and push the differential lock shaft down to remove it. Make sure the spider gears do not rotate after you remove the shaft. If they do you will need to realign everything to reinstall the lock shaft. Push the axle shaft in enough to remove the "C" clip from the tip of it. The axle will now slide out of the rear end. You can use the tip of the axle shaft to remove the axle seal. If you're changing the bearing as well you will need a slide hammer with axle bearing adapters to remove it. You can use a socket and hammer to install the new bearing and seal. Be careful not to damage the bearing and seal. I recommend packing grease in the back side of the seal. This helps prevent the spring on the seal lip from coming off. Assembly is the reverse. Clean off all the gear oil from the differential cover and the axle. You can use RTV as a gasket if the OEM gasket is damaged. Fill the rear end with new gear oil of the proper type. Refer to your owner's manual.
Jun 05, 2010 | 2004 Ford F150
How to replace rear axle seals
if the seal (s) is leaking you may have a bad bearing... to change.. remove the rear end cover, reach in pull the c clip on left or rt side. pull the axel out the side, use bearing puller to pull the old bearing, install new replacement bearing seal, put in axel, replace clip, reinstall rear cover, sealing properly, fill with rear gear lube to level of fill hole. get a chiltons manual for pictures and more detailed help.
Mar 10, 2010 | 1987 Chevrolet Caprice
How do you remove right rear axle on a 2004 ford crown vic to replace seal on wheel?
Section 05-02A: Axle, Integral Carrier — 8.8-Inch Ring Gear 1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual REMOVAL AND INSTALLATION Axle Shaft NOTE: Whenever replacing the rear axle lubricant, use Rear Axle Lubricant XY-90-QL (ESP-M2C154-A) or equivalent.
Removal
sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The rear brake anti-lock sensor must be removed before the axle shafts are removed. The rear brake anti-lock sensor is bolted on the rear disc brake caliper anchor plate.
  1. Raise vehicle to desired working height. Refer to Section 00-02 . Remove rear wheel (1007) and tire assembly. Remove rear disc brake calipers (2552) and rear disc brake rotors (2C026) .
  1. Clean all dirt from area of axle housing cover with a wire brush and/or cloth.
  1. Drain rear axle lubricant by removing the axle housing cover .
  1. Remove differential pinion shaft lock pin and differential pinion shaft .
  1. Push flanged end of the axle shafts toward the center of the vehicle and remove the rear axle shaft retaining u-washer from the button end of the axle shaft .
  1. Remove axle shaft from the rear axle housing , being careful not to damage the inner wheel bearing oil seal (1177) and rear brake anti-lock sensor ring.
Installation
NOTE: Check for presence of rear axle shaft o-ring (4A332) on the spline end of the shaft and install if not present.
sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Care must be taken not to let axle shaft splines damage oil seal or bearing assembly.
  1. Carefully slide axle shaft into rear axle housing without damaging rear wheel bearing (1225) or rear brake anti-lock sensor indicator (2C189) . Start splines into side gear and push firmly until the button end of axle shaft can be seen in the differential case .
  1. Install the rear axle shaft retaining u-washer on the button end of the axle shaft splines, then pull the shaft outboard until the shaft splines engage and the rear axle shaft retaining u-washer seats in the counterbore of the differential side gear .
  1. Position the differential pinion shaft through the differential case and differential pinion gears , aligning the hole in the differential pinion shaft with the lock bolt hole. Apply Rear Axle Lubricant to differential pinion shaft lock pin . Install differential pinion shaft lock pin and tighten to 20-41 Nm (15-30 lb-ft). sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Differential pinion shaft lock pin must be tightened to specification using Stud and Bearing Mount E0AZ-19554-BA (WSK-M2G349-A1) or equivalent.
    NOTE: Axle housing cover must be installed within 15 minutes of application of the silicone rubber or new silicone rubber must be applied.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure machined surfaces on both axle housing cover and rear axle housing are clean before installing the new silicone sealant. Inside of axle must be covered when cleaning the machined surface to prevent axle contamination. Tighten the cover bolts in a crosswise pattern to ensure uniform draw on axle housing cover .
  1. Apply Silicone Rubber D6AZ-19562-AA or BA (ESB-M4G92-A or ESE-M4G195-A) or equivalent. Install axle housing cover and tighten retaining bolts to 28-38 Nm (38-52 lb-ft).
  1. Add Motorcraft Rear Axle Lubricant XY-90-QL or KL (ESP-M2C154-A) or equivalent until it is 6-14mm (1/4-9/16 inch) below bottom of fill hole. Add 118.3 mL (4 oz) of Ford Additive Friction Modifier C8AZ-19B546-A (EST-M2C118-A) or equivalent to Traction-Lok axles. Install fill plug and tighten to 20-41 Nm (15-30 lb-ft).
  1. Install rear brake anti-lock sensor indicator . Tighten retaining bolt to 4.5-6.8 Nm (40-60 lb-in).
  1. Install rear disc brake caliper and rear disc brake rotor .
  1. Install wheels and tires.
  1. Insert Rear Bearing Remover T85L-1225-AH in bore and position it behind bearing so tangs on tool engage bearing outer race. Remove rear wheel bearing and inner wheel bearing oil seal as a unit, using Impact Slide Hammer T50T-100-A.
    Rear Disc Brake Caliper Anchor Plate
  1. Lubricate the rear wheel bearing with Rear Axle Lubricant.
  1. Install rear wheel bearing into the housing bore using Axle Tube Bearing Replacer T78P-1225-A.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Installation of rear wheel bearing or inner wheel bearing oil seal assembly without proper tool may result in an early bearing or seal failure. If inner wheel bearing oil seal becomes cocked in bore during installation, remove it and install a new one.
  1. Install the inner wheel bearing oil seal using Axle Tube Seal Replacer T78P-1177-A. Use Premium Long-Life Grease XG-1-C or K (ESA-M1C75-B) or equivalent between the lips of the inner wheel bearing oil seal .
  1. Install axle shafts as outlined.
May 13, 2009 | 2004 Ford Crown Victoria
Rear wheel bearing
SECTION 205-02B: Rear Drive Axle/Differential — Ford 8.8-Inch Ring Gear 2003 Mustang Workshop Manual IN-VEHICLE REPAIR Axle Shaft Removal
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
  1. Remove the rear brake disc (2C026). For additional information, refer to Section 206-04 .
  1. Remove the differential housing cover (4033) and drain the lubricant. For additional information, refer to Differential Housing Cover in this section.
  1. Remove the differential pinion shaft (4211).
    1. Remove the differential pinion shaft lock bolt (4241).
    1. Remove the differential pinion shaft.
  1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the axle shaft groove.
    Remove the U-washer (4N237).
    1. Push the axle shafts (4234) inboard.
    1. Remove the U-washer.
  1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Damage to the rear brake anti-lock sensor (2C190) may occur if it is not removed before the axle shaft.
    Carefully remove the rear brake anti-lock sensor. For additional information, refer to Section 206-09A .
  1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal.
Rear Wheel Bearing and Axle Shaft Oil Seal Removal
  1. Remove the axle shaft (4234). For additional information, refer to Axle Shaft in this section.
  1. NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged.
    Using the special tools, remove the rear wheel bearing and wheel bearing oil seal.
Installation
  1. Lubricate the new rear wheel bearing with the specified lubricant.
  1. Using the special tools, install the new rear wheel bearing.
  1. Lubricate the lip of the new wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. Using the special tools, install the new wheel bearing oil seal.
  1. Install the axle shaft. For additional information, refer to Axle Shaft in this section.
Installation
  1. Lubricate the lip of the wheel bearing oil seal
    Install the two axle shafts.
    Install the U-washer.
    1. Position the two U-washers on the button end of the axle shaft.
    1. Pull the axle shaft outward.
  1. NOTE: If a new pinion shaft lock bolt is unavailable, coat the threads with Threadlock and Sealer EOAZ-19554-AA or equivalent meeting Ford specification WSK-M2G351-A5 prior to installation.
    Install the differential pinion shaft.
    1. Align the hole in the differential pinion shaft with the case lock bolt hole.
    1. Install a new differential pinion shaft lock bolt.
  1. Install the differential housing cover and fill the rear axle with the specified lubrication. For additional information, refer to Differential Housing Cover in this section.
  1. Install the rear brake anti-lock sensor. For additional information, refer to Section 206-09A .
  1. Install the rear brakes. For additional information, refer to Section 206-04 .
  1. Install the tire and wheel assembly. For additional information, refer to Section 204-04 .
  1. Lower the vehicle.
Apr 10, 2009 | 2004 Ford GT
Replace left rear axle seal 1999 ford explorer
Axle Shaft Removal
  1. Remove the differential housing cover (4033).
    1. Loosen the bolts and drain the lubricant from the rear axle housing (4010).
    1. Remove the bolts.
    1. Remove the differential housing cover.
  1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Turning the differential case (4204) or an axle shaft (4234) with the differential pinion shaft (4211) removed will cause the differential pinion gears (4215) to fall out of the assembly and damage the components.
    1. Remove the differential pinion shaft lock bolt.
  2. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the U-washer groove.
  3. Remove the U-washer (4N237).
  4. Push the axle shaft inboard.
  5. Remove the U-washer.
Reinstall the differential pinion shaft.
  1. Install the differential pinion shaft.
  2. Install the differential pinion shaft lock bolt finger-tight.
  3. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal (1177).
Seal Removal
  1. Remove the axle shaft (4334). For additional information, refer to Axle Shaft in this section.
  1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the wheel bearing oil seal (1177) by itself. Always remove the rear wheel bearing (1225) and the inner wheel bearing oil seal at the same time.
    NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged with foreign material.
    Using the special tools, remove the rear wheel bearing and wheel bearing oil seal together.
6c7eb46.gif Installation
  1. Lubricate the new rear wheel bearing.
    • For 4.0L SOHC and 4.0L EI with limited slip rear axles and 5.0L vehicles, use SAE 75W-140 High Performance Rear Axle Lubricant F1TZ-19580-B or equivalent meeting Ford specification WSL-M2C192-A.
    • For 4.0L SOHC and 4.0L EI with conventional rear axles, use SAE 80W-90 Premium Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Using the special tools, install the rear wheel bearing.
  1. Using the special tools, install the wheel bearing oil seal.
Feb 22, 2009 | 1999 Isuzu Rodeo
Belkin (F5D5231-4) Router Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
