Question about RIM BlackBerry 7520 Handheld
I need help with volume
My bluetooth headset how do i turn it up so i can hear what im doing on my phone i have a blkberry7520 i can hear my calls just not the keys and message alerts what should i do ???
  • 10 Answers
You may have selected a profile that does not alert you audibly when you receive messages. You may select a different profile, edit the current profile or create a completely new profile. I'm attaching instructions for creating a profile and editing would be similar except you would select a profile then select "edit" for the menu. Be use you have "tone" or "vibrate and tone" selected and that the volume is not on mute. Always save your changes.
Create notification profiles
1.In the profiles list, click the trackwheel.
2.Click New Profile.
3.Type a name for the profile.
4.Click an item.
5.Click Edit.
6.Set how you want to receive notification for that item.
7.Click the trackwheel.
8.Click Save.
9.Click the trackwheel.
10.Click Save.
To turn on tones when pressing the keys, follow the following instructions:
Turn on tones when pressing keys
In the device options, click Screen/Keyboard. Set the Key Tone field to On. Click the trackwheel. Click Save.
Posted on Jul 23, 2008
Bluetube is connected to my cell phone but I can't hear anything
There may be linking issues between the headset and the phone. Page 11 of the user guide offers these suggestions. Also, here is a link for re-pairing your headset to the phone:
Plantronics Explorer 230 Pairing Instructions
Remember that you want to purge any possible bluetooth interference from your phone.
"Callers cannot hear me or I cannot hear caller/dialing tone:
The headset is not turned on or the headset is not connected to mobile phone. Press the call control button for 2 seconds until you hear a beep or see the indicator light glow blue to turn headset on.
Your headset is out of range. Move the headset closer to the phone or Bluetooth device.
Your headset battery is drained. Charge your battery using the AC power adapter supplied.
The listening volume is too low. Press the volume key up (toward the earloop) to increase the sound heard in the headset."
Good luck from Headsets Direct!
Jan 10, 2012 | Plantronics Explorer 232 Bluetooth Headset
Can not hear on bluetooth
did you check the volume?
may placing a call check the volume at that time for the Phone.
Jan 10, 2008 | Motorola Mobility H500 Wireless Headset
Even though the volume is turned all the way up on both my cell phone and on my plantronics 220,both fully charged,I can barely hear any type of call. whether its a given or recieved call.
Try to delete the bluetooth from the phone, and re-pair it or subscribe back on the phone. It may be that your headset is old and needs to be replaced. If this does not work look at the Plantronics M100 bluetooth headset.
I have included the users guide for the Plantronics Explorer 220 headset.
Jul 18, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Can barely hear on full volume? Plantronics 232
1. Stay away from ambient noises 2. Press the up volume for 3 seconds. 3. Make sure it's in your ear all the way.
Jul 15, 2010 | Plantronics Explorer 220 Bluetooth Headset...
How do i disconnect my HBH PV703 Headset from a damaged phone and connect it to another Phone
Step 1 - To reset your Bluetooth headset:
  1. Press and hold down the volume keys "+" and "-" on your headset at the same time, until your hear a beep and the light flashes red and green alternately.
  2. Press and hold down the volume keys on your headset until it is turned off. The headset is now reset as it was when purchased.
Step 2 - To pair the headset with your phone:
  1. Make sure the headset is turned off.
  2. Turn on the Bluetooth function and Bluetooth visibility in your phone (This makes the phone visible to other Bluetooth devices).
  3. Place the phone within 20 cm (8 inches) from the headset.
  4. Press and hold down the call handling key on the headset until it beeps, shows a steady green light and then flashes red and green alternately. If the indicator light only flashes red or green, simultaneously press and hold down both volume keys until the headset beeps and flashes red and green alternately.
  5. If your phone supports auto pairing, press "Yes" when you are asked to add the headset to the phone. If not, check your phone User Guide on how to pair the Bluetooth device. If required, the headset passcode is 0000.
  6. The headset beeps and flashes green when successfully paired.
Jan 21, 2009 | Audio Players & Recorders
Volume problem
there should be a volume button on your bluetooth, or you have turned your volume down on your phone, which is most likely, thats what i had done, crazy huh.
Dec 19, 2008 | Motorola Mobility Bluetooth Hands Free...
Audio on h700c
Check to see if you have not muted the headset or the phone.
Nov 05, 2008 | Motorola Mobility Bluetooth...
Can't hear anything in my bluetooth headset, mic is working
Hi--First, make sure your "mute" function is off.  Try holding both volume buttons at the same time for a second or two.  If that doesn't help, while you're having a conversation, either with or without bluetooth, make sure your phone's volume is turned up.  On a lot of phones the volume button will control both ringer and conversation volumes, but turning it up without the phone in use only affects the ringer volume.  My husband thought there was something wrong with his bluetooth until we noticed his phone volume was set too low--not as noticeable on handset, but bluetooth apparently needs volume up pretty high!
Sep 29, 2008 | HTC Touch P3450 Smartphone
Problems with my motorola hs850
Set your volume to mid range. If it continues you'll need to return it or exchange it. The voice pickup sencer in the bluetooth is defective. Or the phone needs an upgrade.
Jan 27, 2008 | Motorola Mobility Bluetooth Hands Free...
RIM BlackBerry 7520 Handheld Logo
100 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
