Question about Electrical Supplies
Lawn mower won't run
I have john deere LT133 riding mower that will not start. It will crank over, and if you pour gas directly into carburetor it will start for a second. What do I do?
    New Friend:
  • 182 Answers
Make sure the tank has fuel and replace the fuel filter
Posted on Sep 21, 2008
I have a john deere stx46 that will crank but not start. Gas is getting to the carb but nothing seems be be coming out the other side of the carb. Could the carb be clogged?
pour a little bit of gas in the carburetor and try it. if it starts for a few seconds it may be clogged and need to be cleaned. change the spark plug first. and try if it wont start then try the carburetor.
Jun 09, 2016 | John Deere Garden
My john Deere 110- 42" cut lawn mower ran out of gas and won't crank back. Noticed the parking brake is engaged but will still roll. What is my problem?
Hi Shannon, It's either fuel OR electrical, First check electrics, If it cranks but not starting......
How to test a solenoid....
How to test lawn mower solenoid
How small engine governors work....
How Small Engine Governors Work any governor setup
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
Apr 29, 2016 | John Deere Garden
John Deere L130 riding lawn tractor will not start what do I do?
I'm assuming the motor will crank over, but not start. Remove the air intake cover & filter off the carburetor air intake. Do you smell gas? Is gas dripping out of the carburetor? If not, spray a couple shots of starting fluid or carburetor cleaner into the carburetor air intake throat. Close the choke & crank the engine. If it starts, & stalls, repeat the process. If it won't stay running, your carburetor float jet is gummed up & needs to be cleaned. Check & clean the spark plug. Does the spark plug fire when the engine is cranked? If no, then you have an ignition problem.
Mar 05, 2016 | John Deere L100 Series
Doesn't act like it is getting gas. Cranks but wont start. Will start if I pour gas in carboretor but won't stay running. Changed gas filter and fuel pump.
Hi: I sounds like it is not getting gas, it probably need the carburetor cleaned out. but first make sure the gas is turned on, tighten the carb . I you have left it for a long time with out running the gas out it most likely needs the carb cleaned Good Luck I hope I was of some help
Dec 19, 2015 | John Deere EZtrak Z225 Zero-Turn Riding...
I have a John Deer riding lawn mower SX95 with a fb460v kawasaki engine that only starts with fuel dropped into carburetor I have a good spark , I had changed the oil and filter , I also took the carb...
in the carb did any of the screws have any micro bored holes for gas to go through like in many small engine iv found . clogged with goop. does it have a gas bowl an a screw on bottom take it out if does an look it over close.
Jul 25, 2014 | John Deere Garden
John deere lawn tractor rx 95
carburetor needs cleaning. sounds like the Needle valve is not doing its job
Apr 22, 2014 | Garden
Wont start light dont work
If choked off. Pull a spark plug. May be full of gas.
Apr 03, 2014 | John Deere Garden
How to clean carburetor on John Deere JS36 Lawn mower
Indeed, a dirty carburetor can prevent the John Deere JS36 from starting or running correctly. Mine had this problem. A video that helped:
http://www.youtube.com/watch?v=ArCAivgAyww
The video is more in depth than you need but basically shows you what to look for inside the unit. Essentially: Remove the air filter assembly from the carburetor (a couple of bolts). Clamp off the fuel line, disconnect it from the carb. Unbolt the carb from the mower (a few bolts). Disconnect the choke and throttle arms from the top of it. Unscrew the cup from the carb, clean everything out. I used compressed air for all the little fuel channels. Reassemble, reattach.
Jun 11, 2012 | Garden
I have an L120 lawn tractor with a B&S 22hp v engine that will not start. I have changed the spark plugs, gas filter, both air filters. It cranks / turns over very strong but does not start. It...
Sounds like gummy gas. Try a shot of carburetor cleaner down the fuel line to the carburetor. Or take the carburetor apart and clean it, squirting through all the tiny holes and inspecting the float needle for abnormal wear. replace the float needle assembly if necessary.
Oct 17, 2011 | John Deere 420,1020,2010,2020,2510,2520...
Electrical Supplies Logo
468 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
