Question about Tecnik Dishwashers
Hi i have a technik dishwasher it has flooded the kitchen, i managed to get all of the water out of the machine but now the pump seems to be running all of the time, someone has told me there is a flood switch on the wachine that will need re-setting but i can not find it can you please help me please either email me or ring me on 07875666327 uk number. many thanks chris
    President:
  • 1,462 Answers
Drain pump is running all time because there is water in bottom tray. tilt machine back to 45deg and water will flow out. otherwise, take front panel off and mop water out. alll that is required to reset flood switch is to get rid of the water
Posted on Jul 20, 2008
Pump running continuously, Yes there was a drain pack, have emptied water, float switch clicks when moved with screw driver. Only one red light shows ( last cycle - pots ) what else can I do... James
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
Aug 21, 2011 | Asko Dishwashers
No water in dishwasher
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jun 06, 2010 | Tecnik TDW2677 Built-in Dishwasher
Dishwasher turns on but nothng happens.
drain pump blocked and has overfilled flooding base pan and activating anti flood device tip machine to the left to remove water and consult handbook on how to clean pump outlet.
May 08, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Keeps flooding: pump comes on when switched off.
This sounds like an inlet valve problem, Replace it. Often a dirt particle gets in the valve.
Nov 01, 2009 | AEG 18 in. Favorit 44630W Slim-Line...
Won't fill with water
Bosch dishwashers typically have flood sensors in the bottom, below the motor. If there is still water in the pan the machine will not fill with water and only try to run the drain pump. Be sure there is no water in the dishwasher pan
Dec 02, 2017 | Bosch Evolution 800 SHE68M05UC Stainless...
Need to know how to re-set the anti-flood device
I managed to clean the filter inside the dishwasher and drain a little residual water. I then re-plugged in the appliance and the anti-flood device seemed to reset and I have n't had any problems since.
Jan 17, 2009 | Dishwashers
Dishwasher flooding
When you say that you tried other solutions.. it's hard to know which you've tried and which you haven't so I will suggest some basics first.. ( if you've tried them, then disregard)...
Have you checked or addressed the following:
  1. Cleaned the drain filter
  2. Checked the drain hose for crimps or restrictions
  3. Sure the drain system ( such as your feed thru the garbage disposal isn't clogged or restricting flow)
  4. Checked your water pump for an obstruction or you can determinbe if it is actually pumping
  5. The feed and returm hose ..to anf from the pump are not clogged, pinched or restricting flow.
These are the basics that you should have examined or confirmed aren't causing the problems you are seeing. One other as well.. are you sure your water inlet valve is completely shutting water from leaking in and over-filling the system? Check these items and you should be able to diagnose where the problem is.. Hope this helps you,
Sep 21, 2008 | Asko D1716 Built-in Dishwasher
Kenmore Elite - Flooded bottom
this is a necht dishwasher under one year old the problem is as follows. machine switche on make the normal noises to start with after about two minutes it beeps for about twenty seconds machine then stops. The water does not seem to be coming into the machine but a small amount of water does come in at the botom of the machine ie. where the waste is. Please can you help.
Thanks
Nov 19, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
Water flooding out
Hi KellyW,
The dishwasher drain hose may be clogged.  When the dishwashr starts up can you hear the water running into the Sink faucet drain. If not inspect the hose that attaches to the Sink Drain for restrictions.  Also in the bottom of the dishwasher you should have a filter.  If this filter is clogged you cannot expel water.  Clean the filter.
Oct 23, 2007 | Asko D1776 Stainless Steel Built-in...
Neff dishwasher continuously attempting to pump out water
I have just encountered the same problem on my S5433 XO GB/13. Did you manage to get a solution.
Jan 17, 2007 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwashers Logo
578 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
