Preamp noise My Audio Buddy Preamp is hissing and crackling. One input is not working at all. The recording channel levels on my software are going sky high even without anything plugged into the preamp. Through a process of elimination I have worked out the cables etc are OK. Please advise if it is repairable and if so, an estimate of cost would be great. Thanks
  • KenO2 Jul 22, 2008
    Thanks!
    I thought that a repair might not be worth it. Thank you for confirming. I will try and track down an alternative preamp on ebay as a new Audio is still expensive at the moment. Thanks also for the link to zzsounds!
  • 1,512 Answers
Hi KenO2
First thing to check is that the phantom power is not turned on. If you are using a condenser mic, then it should. If you are using dynamic mic, then it will crackle and makes weird noises in the manner you describe. Other than that it sounds like you have a failing op amp in your preamp. This sort of repair work is not expensive(with respect to the outcome). I would anticipate $40-60 to fix it. Trouble is you can replace it super cheap at the moment 45% off for $64.95plus $9.95 shipping from zzsounds
So I guess that it may not be worth repairing, and more a replacement item for that money. If you have a mate with electronics experience, you could just replace the opamps at home for $10 worth of parts.
If you think my advice helped you to work out what to do, a FixYa rating would be great. Cheers
regards
robotek
Posted on Jul 21, 2008
  • Graeme Ross
    Graeme Ross Jul 22, 2008
    Hi Ken, I know that what I had given you was "helpful", was expecting that I had given you enough information for you to make a decision about what to do with your problem. If you still have any questions I am happy to go the extra mile for you.
    A "FixYa" rating is the only thing that really counts for us in here as I don't get paid for taking the time to work through this problem for you. Any chance of an upgrade. Thanks mate :)
    robotek
NAD C162 preamp quiescent noise level suddenly went up. Please help me diagnose?
If the noise is in both channels then you should look for something common to both channels. Capacitors are the likely cause, but some IC's might cause it. You say that the volume control doesn't effect it, if that is the pre-amp's volume control then the fault will be after that part.
Oct 26, 2017 | NAD Audio Players & Recorders
Preamp Noise
The rectifier is the only thing wrong with the amp. Typically a bad rectifier will pop fuses but that is not the only thing than can cause that. You could try pulling tubes to see if you could isolate the problem. Just be careful if you haven't even taken the tubes out before, those PCB sockets are kind of flimsy. pull one tube at a time and see in the crackling goes away
Jul 20, 2008 | Audio Players & Recorders
No Output from any channel
ok i got it now may be you are putting the codes in wrong pin thats why happening this problem.
Dec 18, 2007 | Sony STR-DE525
Static Noise
Is it a hissing noise or a distorted crackling noise? If it's a hissing noise then it's due to a bug in Windows that adds 30 dB of gain. It's easy to work around, though: Go into Recording devices, Properties button, Levels tab, right click on the level number so that it shows in decibels, and then adjust the level to 0 dB. It's supposed to be at 0 dB but Windows 7 defaults it to 30 dB for no reason. This isn't a problem on Windows XP or OS X.
Jan 04, 2012 | Samson G-TRACK USB RECORDING MICROPHONE...
I got a rode classic II with avalon m5 mic pre. So when i crank up my mic pre to 60 n i can start listening some hissing from my monitor...or is it normal for a valve mic coz when after recorded with this...
The hiss is caused by your monitor system level and your preamp gain being so high. At high gain settings, a preamp is going to get noisy, and tube mics have a higher noise level to begin with.
If you can't hear it on your recordings, then it's not a problem.
Sep 17, 2011 | Rode Classic II Professional Microphone
6 mnths old Alto L8 Mixing desk developed hiss on channel 1 only.
The slider or the amps for channel 1 may have a problem.
Sliders do wear out.
Try shorting channel 1 input and see if that affects the noise. A hissing noise is probably a bad preamp chip. That is shop work at a repair facility.
Aug 16, 2009 | Music
Sound very distorted
This turntable has a preamp switch on it, which is probably on and what is causing the distortion. Take off the metal record platter by lifting up on the two holes gently. Turn the pre-amp switch to 'off' and then try it again. This is probably it...
Or you can plug it into an input that doesn't have a preamp and that should work.
Dec 25, 2008 | Audio Technica AT-PL50 Turntable
How do you connect Audio Buddy to computer
You probably connect the Audio Buddy via a USB or firewire cable. I use both types of audio interfaces. Your mac will sense which bus has audio. Go to System Preferences panel and select sound. Select input. You should see your Audio Buddy listed if it is connected properly. You can set levels from this panel and test the device by looking at the two level meters. Speak into the mic; the level meters should move from left to right. Go to the output panel and chose your monitoring device. I prefer the built-in speakers, but you could also connect your monitor to the USB interface or even the Audio Buddy. If I need better quality monitoring I plug a mini cable into the earphone jack and use a desktop speaker. Don't try to use that headphone jack for anything but monitoring - the quality is not great. If the Audio Buddy software requires that you select an input source, always use USB, never line or built-in mic. Another way to capture audio from an Audio Buddy or similar device is to use Wiretap Studio Pro or Roxio CD Spin Doctor for audio capture. I use both.
Dec 03, 2008 | M-Audio M Audio Audio Buddy Microphone
Preamp not working
befor we go inside we make cleaning with lubricant contact cleaner from radio shack and apply it over all control switches while you are moving it-apply also in all sockets and put your plugs in it(in-out-in-out).after all above if not pass you have to ask for help from qualified service center.
Jul 19, 2008 | Audio Players & Recorders
Low audio input
You need to use a mic preamp or a mixer with a mic preamp built in. The inputs on the FCA202 are line level and they won't work with a mic directly.
Dec 02, 2007 | Behringer F-CONTROL AUDIO FCA202 External...
267 people viewed this question
 Grubhead
Grubhead
