Question about Brother MFC-3240C All-In-One InkJet Printer
Brother 3240 printer
The screen is showing the problem # 52 and will not print, after it has undertaken cleaning
  • John Rigali
    John Rigali May 11, 2010
    Please describe a situation in which the printer does not print. Tell me the following:
    • the name of the program from which you're trying to print
    • what you're trying to print
    • how you're trying to print (are you clicking on a Print button? are you selecting a command from a pull-down menu?)
    • everything that happens as a result of your attempt to print
    • which "screen" shows "52"
    • anything else that appears with the "52"
  • John Rigali
    I am unaware of a "problem #52" with the MFC-3240C. Can you give us a situation in which the problem occurs, and describe the problem exactly?
The printer is in the computer system but will not print out on the printer---the button keeps jumping to "fax" and won't stay on "copy"
Posted on Jul 30, 2008
The printer will not print - this happened all of a sudden. The sreen came up with the number 52.
All the cartridges are either new or nearly new.
regards
Rob
Posted on Jul 21, 2008
Print quality is fine when printing from the computer, but is very light when copying. Toner is new. Toner Saver mode is set to off. Cleaned the glass. Any ideas?
Brother has a bulletin for this type of problem, they say to replace the "friction cap". It is located in the drive train and requires that the machine is stripped down to almost the bare frame. It is a labor intensive repair and should be undertaken by a trained technician. You can call Brother at 1-877-BROTHER to find a service center.
Jun 02, 2011 | Brother MFC-9840CDW Laser Printer
My Mfc 3240 Brother Printer will not Print and the readout says to get the trouble shooting and maintenance guide
When ever you get an error message like the one you are describing, there should be a numerical code with it.
Most of the time when you get an error code like this, it is a mechanical problem with the machine.
Try unplugging the power for about 5 minutes to see if that clears it out, otherwise you might as well replace it. A machine like this has been discontinued and is not worth paying for repairs.
Mar 25, 2010 | Brother MFC-3240C All-In-One InkJet...
My brother 3240 inkjet printer will not print the blue cyan colour. I've run the cleaning cycle a dozen times, What can I do to correct this problem?????
There's not a lot you can do, once the printhead is plugged like that it's a shop repair. It will need a new printhead that only a shop can replace and the cost of the new printhead is around $120.00. You're better off to buy the new similar machine from Brother for around $120.00 and get a new one year warranty.
Dec 31, 2009 | Brother MFC-3240C All-In-One InkJet...
My brother dcp 110c printer is unable to initiate and refers to routine maintenance - it does print out test sheets however and I have undertaken routine maintenance - not sure what else to do
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the
error is 50 or 51 there is error in Purge unit and printer require service.If the error is 48 - defective print head cable or circuit board.If the error is 46 the waste ink tank is full.Follow this:
1. Pres 'menu', 'mono start' then 'menu' one by one...
2. Press the arrow up or down to go to 'maintenance 80'.
3. Press 'mono start' several times to go to 'Purge'. Finding the PURGE will show some numeric value
which is Iassume the number of times the printer had cleaned.
4. Press 'arrow up' key and scroll for number "2" then press "set".Do the same for numbers 7, 8 and 3.
After you have entered this combination, the purge numeric value will be reset to 00000.
5.Restart printer
Nov 13, 2009 | Brother DCP-110C All-In-One InkJet Printer
When printing from word 2007 on vista bold type is gibberish
Try re-installing the printer driver(s) first. If no luck, then un-install the printer completely, reinstall and try again. You may also have an issue with an incompatible driver with Office 2007. After reinstalling the drivers, try to print a test page and see what happens.
Apr 17, 2009 | Brother MFC3240 Multifunction InkJet...
Brother MFC 3240 wont print when 1 ink is empty
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Nov 24, 2008 | Brother MFC3240 Multifunction InkJet...
My brother mfc 3240 won't print
What are you trying to do when you get that error message? Are you trying to change the cartridges or is this when you are trying to print?
Aug 18, 2008 | Brother MFC3240 Multifunction InkJet...
UNABLE TO CLEAN
http://www.fixya.com/support/t233921-not_printing
you need to get error code there are many posts on this your is simular to 210,215,110,115, 3240, 425, 445 etc etc
probally waste tank full, look under brother inkjets here on fixya
Nov 13, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-3240C All-In-One InkJet Printer Logo
48 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
