Question about A4tech PK5
Not connectingmy webcam
When trying to open quickcam is telling me the following
webcam was not found or is not working properly
check to see if camera is properly plugged into the usb port and then press the reconnect button
Ive done that and nothing is happening!! i insert the driver but still not working
  • 781 Answers
Uninstall any driver for webcam and unplug webcam
1) reinstall drivers make sure they are for your operating system
2) when driver installed it should come up with a screen asking you to plug camera in. if not reboot when drivers installed and then plug camera in then it should be found and installed . this method works most of the time any USB device should not be plugged in until drivers installed
Posted on Jul 21, 2008
Logitech quickcam web not connecting to pc Please help
Check Following Instructions:
1. Check your Cam properly conntected to the computer via USB.
2. Check Logitech quickcam drivers Install. - If not install from this website -
http://www.driverfiles.net/Cameras/Logitech/QuickCam%C2%AE-Express-Driver/download/page,sh,39397,444,17,.html
Apr 25, 2010 | Logitech Quickcam Web Webcam
I am not a computer person.I was wondering if logitech webcam C250h will work with skype?
Yes, I have a Logitech WEBcam (not the same model) and I use Skype.
After you installed Skype then :-
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video.
If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam
Also check the Audio Settings for the Microphone THEN click on Save.
Avoid connecting the WEBcam to an USB hub.
Mar 09, 2010 | Logitech Webcam
My camera quit working in skype, any suggestions in troubleshooting? the green light isnt coming on at all, it was working like 5 minutes ago
To test if the Logitech QuickCam is functioning, check the USB cable, make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video.
Dec 14, 2009 | Logitech QuickCam Connect Webcam
Frozen video on calls
Try putting the camera under VFW (Video For Windows) control - it involves a registry edit and can be found here
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/webcam/mstacamfix.html
It didnt work for me at first - I had to download the windows amcap as well. VFW doubled my fps
If you open the 'webcam' menu on the webcam picture frame and also open 'Statistics' you can monitor the f/p/s during transmission - Generally try and keep the frames per second above 1.0 fps to prevent freezing. I transmit the 'small image' with my contacts and they zoom up to 200% -all on the webcam frame menu. When you open 'Statistics' you can tell if you are on VFW control - it will say VFW along the lower panel.
I also increased my virtual memory following an error message.
Sep 28, 2009 | Logitech QuickCam Connect Webcam
My webcam works only once then I have to reboot.
check device manager and update driver
have you set cam up with skype
Go to TOOLS, then OPTIONS, and click on
Audio Settings
and set the Microphone and Speakers
to the computer Audio Card.
Then click on the Video Settings.
The camera if installed properly
will come up and show a picture.
Then on the bottom of the page click on Save.
Feb 17, 2009 | Logitech QuickCam Pro 5000 Webcam
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Aug 13, 2008 | Logitech Quickcam Ultra Vision Webcam
Logitech Quickcam install on a Mac OS X or mac laptop
i dont know if this will help, i coulndt get my quickcam to work (didnt seem to even recognize it was plugged in ) but i got this and it works now , just follow the readme file it will tell u where to put the patch to make it work, :)
http://webcam-osx.sourceforge.net/
Jan 10, 2008 | Logitech QuickCam Webcam
some times webcam cable may faulty
Jan 07, 2008 | Logitech Webcam
Logitech Quickcam for Notebooks Pro
Start by checking that you have no device conflicts. Look in your device manager for any asterisk's or explication points. It is possible the drive was not installed properly. It is a common problem with vista.
Oct 10, 2007 | Logitech QuickCam for Notebooks Pro...
Logitech Cam 5000
have you tried plugging the webcaminto a different computer tomake sure the camsnot broken?
Mar 16, 2007 | Logitech QuickCam Pro 5000 Webcam
A4tech PK5 Logo
80 people viewed this question
Top A4tech Computers & Internet Experts
micky dee
Tony
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
