Question about IBM ThinkPad T20 2647 Notebook
Help me please help me , I not detect ethernet on windows XP ,i need driver for this.
    Genius:
  • 2,028 Answers
After reinstalling Windows XP, my PC can't detect
Yes you need to install the ethernet driver . You can download it here. You can either enter your service tag number which can be found on the back of your CPU or you can manually select the model. Once done, it will display all the available drivers for your device. Make sure you choose the right Operating System and download/save the ethernet driver you need. Install it ands reboot the computer. Once the right driver has been installed, your computer should be able to detect your modem again.
Hope this helps.
May 31, 2011 | Dell Computers & Internet
Bought a Gateway Netbook LT25 loaded with Windows XP. Was told by the salesman that I could upgrade to Windows 7, so I bought the software. Somehow, I screwed up the directions & ended up with Windows...
Try updating Win 7. Go to Programs and find Windows Update.
Microsoft might be able to provide the drivers automatically.
Afterwards visit www.intel.com/support/detect.htm
And run their auto detect tool. It works best if you run in Internet Explorer ;)
If you're still missing stuff, let me know and I'll help you track down what's left.
Dec 23, 2010 | Gateway LT2503u 10.1-Inch Netbook - Sesame...
Why is my ethernet driver missing ? where can i get an update done from ?
Well, there are a lot of reasons to cause your driver missing or outdated.
As to the solution, I'll recommend you to directly try Driver Detective and let the software have a free scan to automatically detect & update the missing drivers. This way things can be much easier & efficient. Also you don't have to risk install wrong drivers which might cause severe system issues.
Best regards!
Nov 16, 2010 | NEC 82559-based Fast Ethernet Adapter
My gateway inside my desktop keeps disconnecting from my ethernet can you tell me what I need to do I have a Sony VAIO VGC 310 with window 7 upgrade
This computer's original OS was Windows XP. Check with the Intel Website (www.Intel.com) to see if there is an updated driver for the Ethernet Card and Chipset for the Intel Pro/100 Ethernet Driver for Windows 7. Intel has a utility you can run (follow the instructions) which will detect all your Intel Chipset hardware and provide you with updated driver information. If there is no Windows 7 driver, try using these steps to correct the issue: 1) download the most current ethernet driver from Intel and save to a folder. 2) Once the download is complete, locate the file and right click on it, click on "Properties" 3) select the Compatibility tab and set the options to run the program in Compatibility mode for Windows XP Service Pack 2. 4) A little farther down in the windows, check the box that says "Run as Administrator" 5) apply the settings and close the properties box. 6) double click the the driver file to activate its install. Follow directions and see if this helps your issue. You may need to remove the originial driver files first. To do this, Go to the Device Manager in the control panel from the start menu, Find your Ethernet adapter in the Network Adapters hardware list, right click and select "uninstall" and check the box to remove the driver files, then click okay - then reboot the machine, the run the new driver file you downloaded from Intel in compatibility mode per my previous instructions. If this doesn't solve your issue, I recommend installing a new network card that is compatible with Windows 7. Its an easy install and shouldn't cost you very much . . . less that $25.00 and should take only about 15 minutes to install. Here is a link to Netgear and their Windows 7 compatible hardware Ethernet card for about $19.00. http://www.netgear.com/Products/Adapters/WiredAdapters/FA311.aspx
Your local Wal-Mart or Target will probably have these and other brands in stock.
Hope this helps FixYa! If you find this information helpful, please leave feedback.
Apr 06, 2010 | Gateway GT4016 Desktop PC
I need a ethernet controller driver for xp so i can get on the web
There's a lot of Ethernet controller driver for xp on the web, please identify which one and model to provide the exact driver for your Windows XP.
Sep 29, 2009 | Sun Micro QUAD ETHERNET CONTROLLER Micro...
Reinstalled windows xp now it says no modem detected
probably need your ethernet card reinstalled on your pc. right click on my computer and goto properties, then click hardware and device manager- you will probably have a yellow ! or ? by "ethernet controller"
you will need to goto the manufacturer of your computers website to download the driver on a diff computer and install it on yours.
Jun 03, 2009 | Computers & Internet
Wireless help!
try to open the show all networks window disable the default ethernet connectoin then enable the wireless net work
Jul 22, 2008 | Acer Aspire 5520-5908 Notebook
Ethernet adapter
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=in&dlc=en&product=3446906&lang=en this is link for your ethernet card driver and windows xp will automatically find driver of ethernet card if its not find then just copy sp2.cab and i386.cab in to %systemroot%\system32\drivers folder and then try to install it manualy
Sep 30, 2007 | Microsoft Windows XP Professional With...
i need an ethernet controller driver for my dell dimension 4600 the operating system is windows xp home edition
Sep 02, 2007 | Dell Dimension 4600 PC Desktop
IBM ThinkPad T20 2647 Notebook Logo
149 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
