Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Kodak all in one printer instalation error codes
New printer... installed followed instructions various error codes casme up turned off and on now error code says printhead missing, re install cant remove printhead but it seems perfectly in place?
  • james02 Nov 23, 2008
    after i reseated the print head i got 2 more prints from the printer then i got a horrible burning smell !, i removed the print head carrier I new immediately that it was burnt out, whew the smell of burnt silicon
    Scholar:
  • 96 Answers
Unfortunately, the only way to possible fix this error is to get the printhead out and reseat it. You can do that by removing the ink cartridges. Right above where the black ink cartridge was, at the top left hand corner of the printhead, if you push up towards the ceiling there should be a button that releases the printhead. You should now be able to tilt the printhead forward and pull it out of the printer. Reseat the printhead by putting it back in the printer and pushing straight back on the back wall of the printhead. It should snap into place. Replace the ink cartridges and close the printer. If the error clears, download the newest firmware from kodak.com so this never happens again.
If these steps do not clear the error however, call Kodak AiO tech support at 1800 421 6699 to get a new printhead.
Posted on Jul 21, 2008
My scanner quit working on my Kodak ESP3 AiO while everything else works fine. i get two different codes...1-2036, and 1-2007.
i have disc space, it is plugged in, and turned on, i have latest updates installed...dont know what else it could be
Posted on Sep 02, 2009
How do I fix error code 6202
Code 6202 To Reset. Disconnect from power source wait 2 minutes and reconnect. This should work. I believe it is a modem problem. Your manual should cover this. Contact Kodak for further problems Most issues are correctable by the user and the user should first consult the user/operators manual.
Jul 03, 2015 | Kodak Office Hero 6.1
Printer showing error code 3802
To resolve the error:
  1. Upgrade your printer firmware to the latest version:
    1. Locate and select the firmware for your printer.
    2. Follow the instructions to install the firmware.
  2. If your printer firmware is already up-to-date:
    1. Press the On/Off button on your printer control panel.
    2. Disconnect the power cable from the back of the printer.
    3. Wait 10 seconds to allow the printer to reset.
    4. Connect the power cable to the printer.
    5. Turn the printer on by pressing the On/Off button.
  3. If the error continues:
    1. Open the printer access door.
    2. Remove and install the printhead.
    3. Close the printer access door.
    4. Follow the on-screen instructions to calibrate the printhead.
      NOTE: If you are not prompted to calibrate the printhead, turn off the printer, wait 10 seconds, then turn on the printer
Feb 03, 2015 | Kodak Esp 3250 All-in-one Inkjet Printer
Why is my kodak 5250 showing error code 3807?
Error: "System status failed" (3807) Published 08/25/2010 11:38 AM ' Updated 08/28/2012 05:23 PM ' Answer ID 1249
How do I resolve the error message "System status failed" (error code 3807)?
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary
  2. Remove and install the printhead two times.
  4. Wait until the printer is ready to use.
If the error is resolved, upgrade your printer firmware:
  2. Follow the on-screen instructions to install the firmware.
If the error is not resolved, contact us.
Jul 01, 2014 | Kodak ESP 5250 All-in-One Printer
Advent resetting ink levels
Hi There
Your all-in-one printer is designed to stop printing before quality is compromised. Make sure you always use KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of non-Kodak brand ink cartridges or refilled ink cartridges. To purchase KODAK Ink Cartridges, go to the KODAK Store.
To resolve the error, replace the black ink cartridge with a new cartridge:
  1. Turn on your printer.
  2. Open the access door. For printers with LCDs, follow the instructions on the LCD screen.
    NOTE: For ESP 3250 and ESP 5250 all-in-one printers, if the ink cartridges don't move to the center when you follow the instructions on the LCD screen, see Printhead and ink cartridges do not move to center with access door open.
  3. When the printhead stops moving, pinch the latch on the black ink cartridge and lift it out of the printhead.
  4. Remove the new black ink cartridge from its bag.
  5. Remove the protective cap from the black ink cartridge.
    CAUTION: Insert the ink cartridge immediately to prevent the printhead from drying out.
  6. Insert the black ink cartridge into the printhead.
  7. Press down on the tab until you hear a click.
  8. Close the access door. For printers with LCDs, follow the instructions on the LCD screen.
    NOTE: For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
If the error continues, upgrade the firmware for your printer:
  1. Press the Cancel button on your printer to clear the error message. (If the error does not clear, contact us.)
  2. Upgrade the firmware for your printer:
    1. Locate and select the firmware download for your printer.
  3. If the error continues, contact us.
Support Link :
Mar 29, 2012 | Office Equipment & Supplies
Error code 3508 after installing a new cartridge
As Kodak suggests in these cases - upgrade the firmware for your printer.
  1. Upgrade the firmware for your printer:
If the error continues, try to contact Kodak
Oct 03, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
My 5250 printer cannot load paper properly. It loads unevenly and displays error messages 3424, 3618, or lately 3520. I tried to upload new firmware, but no new firmware is available.
Hi there.
The error 3520 requires a firmware upgrade. Please click on this link for the firmware update.
Installation Instructions:
  1. Verify that the KODAK All-in-One Printer Home Center Software is installed and can communicate with your printer.
  2. Download the firmware file to your computer.
  3. Double-click the *.exe file, then follow the on-screen instructions. Wait for "Update complete! You may now use your Kodak Printer." to appear on your computer.
  4. Click OK to complete the firmware installation.
If your using a Mac, please click on this link.
Let me know if you need further assistance.
Thank you!
Aug 10, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Screen says "Printer error."
Welcome to Fixya
If the error occurred when you were trying to use a feature of EASYSHARE Software:
  1. Run the Repair utility:
    1. Select Start > Settings > Control Panel > Add or Remove Programs.
    2. Click KODAK EASYSHARE Software.
    3. Click Change.
    4. Click Next.
    5. Select Repair, then follow the instructions.
  2. Try the feature again.
If the error occurred when you were installing or upgrading EASYSHARE Software:
  1. Uninstall your current version of EASYSHARE Software:
    3. Select Remove.
    4. Follow the instructions to remove the software.
  2. Go to the Clear Utility for KODAK EASYSHARE Software at www.kodak.com/go/clear, then follow the instructions to run the utility.
  3. After restarting your computer, go to KODAK EASYSHARE Software at www.kodak.com/go/easysharesw, and install the latest version of software, free of charge.
Thank you for using Fixya!
Mar 23, 2011 | Computers & Internet
Error code 3825
Answer: Answer last updated:11-17-08 Error code resolutions are updated on a regular basis. If, after you search, you cannot find a resolution to your error, the instructions below can help you.
IMPORTANT: Print this page before continuing.
Search for a resolution to your specific error code:
  1. Go to KODAK EASYSHARE Software Support.
  2. In the box under Find Answers, type the complete error code (without spaces), then click Search. An example is 12x413x1304x
If you don't find information for your specific error, follow the instructions below:
    3. Select Remove.
    3. Click Change.
    4. Click Next.
Nov 03, 2010 | Office Equipment & Supplies
Fatal printer error
1. First open the top of the unit remove the ink tanks and set them aside.
2. Remove the printhead and then unplug the printer. re-insert the printhead back into the printer. Remove it again and re-insert it. Do this 3-5 times. If you need help doing this, there are instructions on installing a printhead in the electronic manual PDF file provided by Kodak. (What this removal and re-install is doing is scraping of anything that might be disrupting the contact between the printhead and the printer)
3. Now install the printhead and install the ink tanks.
4. Plug in the printer want for it to bootup.
5. If the error comes up again you need to contact to Kodak about getting a new printhead or Return your printer and exchange if for a new one.
Also do be sure to update your software and printer firmware through the Kodak site or through the software provided. These printers print nice photos and the ink is cheep. Dont let this road bump turn you away from them.
Kodak and or I am not responsible for any data loss or any damage to any equipment that occurs as a direct or indirect result of following the procedures described above.
Feb 25, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
1,288 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
