Xerox 265 toning problem
The charge assembly is in the Xerographic module or a separate part?
There is a XEROX mod to fix this problem?!?!!?
My repair lady is not too swift. How do I find out if my machine has this mod or what the mod # would be?
Thanks again, for your help! You are the first person I have talked to that even remotely understands my problem and how to fix it.
  • Greg Patt Jul 20, 2008
    I thought when you said Xerox mod you were saying Xerox MODIFICATION not Xerox module.
  • Greg Patt Jul 24, 2008
    I am sorry if you were insulted, it was not my intent!
    Here is your wording:
    "Xero Mod will fix it."
    Here was my response:
    "I thought when you said Xerox mod you were saying Xerox MODIFICATION not Xerox module."
    I also said:
    "The charge assembly is in the Xerographic module...
    ...this has been a constant problem for 6 months and we have tried your
    solution before and have gone through maybe 6-8 xerographic modules in
    the course of the last 6 months"
    So see, I DID know what a Xerographic module was, it just threw me off when you abbreviated it to "mod", which also an abbreviation for "modification"
    My "thanks for trying" rating was because your solution was probably true, it didn't really solve my problem, because in essence Xerox's Xerographic modules are ****, brand new ones do NOT fix my problem, repeatedly.
    Your comments have verified that and I appreciate that a lot, I REALLY do. But my situation now is to replace the copier because of crappy design and manufacturing on Xerox's end of their xerographic modules. I too know copiers and have been responsible for buying over 10 million dollars of Xerox's. I just no longer have big corporate support or dollars. I am now just a little 5 man shop trying to get by, and very frustrated because I have lots of work and can't get it done because my machine doesn't work the way it is supposed to.
    I see now where I should have rated it "helpful" instead of "thanks for trying" but in essence it didn't fix my problem. I'm sorry, this was my first time.
    Thanks again for your help!
    President:
  • 2,072 Answers
The charge assembly is part of the module. It is called the Xerographic module.Ther should be a small orange knob sticking out of the module that you can pull out and in that would clean the charge and possibly help. But replacing it would resolve your issue, I am 99 percent certain. The only other issue would be the developer housing, but if that were the problem the machine should fault out and just not run at all.I honestly am not sure of the number, familarity makes you not pay attention to some things. Those are customer replacable. Look up a place on google called The Parts Drop. Get the number and call, ask for Britt, he will help you with what you need. If you have a maintenance contract, Xerox will provide the xero module free of charge.
Its in a pretty big box. about 2 by 3 feet size.
You take the old one out by moving an orange lever sliding the old one out and putting the new one in, there is also a waste bottle on the left side of the machine you pop in and out.
Posted on Jul 20, 2008
  • Rick Kasper Jul 24, 2008
    I said neither. It is called a xerographic module. That is what it is called. Thats what it says on the box also.
    And that is what you need. The thanks for trying is insulting. I do know what I am talking about .
Code 09-700 xerox 4150
09-700 Toner Supplying Error RAP
The toner module has stopped supplying toner to the xerographic module.
Procedure
WARNING
Switch off the electricity to the machine. Disconnect the power cord from the customer
supply while performing tasks that do not need electricity. Electricity can cause death or
injury. Moving parts can cause injury.
1. Check that the tape seal has been removed from the xerographic module, PL 9.10 Item 1.
2. Remove the toner module, PL 9.10 Item 2. Check that the locking lever opens and closes
the toner shutter.
3. Install new components as necessary:
• Toner module, PL 9.10 Item 2.
• Xerographic module, PL 9.10 Item 1.
Jul 27, 2011 | Xerox WorkCentre 4150 Black and White...
Xerox 4150 my paper is a light shade of grey, what can it be thank you
Giacomos,
Is the paper a shade of grey with no image? or is there an image with a grey background?
If there is a image with a grey background you should try a new toner module. If that doesn't resolve the issue, clean the xerographic drum, make 10 blank copies, if the cleaning doesn't resolve the issue than install a new xerographic module.
Hope this help.
Apr 05, 2011 | Xerox WorkCentre 4150 Black and White...
Workcentre Pro 245 shows an "Internal Power Supply Failure". We just got the machine and it tested OK. We moved it carefully and tested it again OK. But an hour later, it showed this error...
There are 4 solutions to try and they don't fit in their entirety so I included links to each one. Please be sure to read the instructions entirely AND ensure you need to perform each one.
1. Power machine on and off http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(4322)
2. Clean the Charge Scorotron and the Transfer Corotron: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(4186)
3. Perform a Software Reset at the Printer: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(5315)
4. Replace the Xerographic Module and Transfer Unit: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(3362)
If none of those fail to resolve it call for service.
Hope it helps!
Mar 08, 2011 | Xerox Office Equipment & Supplies
Xerox workcentre C118 is not self toning. toner is ok, toner dispense motor is ok, toner augur is ok, but m/c. not toning.
Have you replaced the Drum Unit. Also known as a Xerographic module ? I suspect the developer has failed in it.
Feb 01, 2011 | Xerox CopyCentre C118 Copier
Xerox copy center C35 - Replace Xerographic module
You can try this.
Press the access button, You will see a button called Enablement Code, then enter this number. *33886714351 .
Make sure you entter the * first, that is the button bottom left on the keypad.
That should allow you 5000 more pages. But it can only be done once. May or may not work on that product. But thats all I know.
Feb 23, 2010 | Xerox Office Equipment & Supplies
Xerox 5765 enter diagnostics
any 9 code is xerographic. This machine isn't worth fixing if you want me to be truthful. The parts alone will cost you more than enough. Look for DC12 on ebay or something to upgrade.
Sorry, but its the best solution
Jan 08, 2009 | Xerox DocuColor 12 Color Copier
Posted the original problem as Blurry Copies for the Xerox WorkCentre X2424. Did what was suggested which was to clean the encoder with alcohol which is located in the drive/drum motor. Now the unit is...
Have u tried the any of the following?
Unlatch Then Relatch the Transfer Unit Below the Xerographic Module
Remove Paper and Other Obstructions From the Paper Path
Use Paper or Other Stock From a Fresh, Unopened ****
Dec 03, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Model Number
answered on the other note but, WIth a 265 the problem you have is coming from the xerographic module. Replacing that will help your issue. Charge assembly is going bad and getting hot the longer it runs.
You will start off fine, get some streaky deletions and copy after copy it wil get worse.
Jul 16, 2008 | Office Equipment & Supplies
jasbo
jasbo
