2004 Nissan Maxima Logo
Posted on Jan 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2005 Nissan Maxima SL, trunk will not open when I hit the release button, switched on and off the valet switch, nothing happens.
  • Anonymous Mar 13, 2014
    Trunk will not open
Anonymous
Level 2:
  • Expert 237 Answers
  • Posted on Feb 01, 2011
Anonymous
Expert
Level 2:
Answers
237
Questions
Helped
125939
Points
659
Does it work when you press release on key fob?if so remove the glove box and make sure someone performing work previously in that area didnt foget to plug it in.
Have a 2005 nissan maxima and trunck wont open
It does not appear that the 2005 Nissan Maxima has a firewall although earlier versions did.------------------------------------------------------------------------------------
Mb Star C3
2answers
2004 nissan maxima trunk will not open using switch on side of driver door
do you have a valet switchin the glove box. open the glove box and see if there is a switch on the left side for the trunk valet then get back with me.
6helpful
3answers
2005 NISSAN ALTIMA 2.5S THE TRUNK RELEASE BUTTON DOESN'T OPEN THE TRUNK,ANY IDEA WHY?
check in your glove box on left hand side.valet switch may have accidentally set.let me know how you make out!
My 1996 maxima key wont open my trunk and neither will the trunk release button
the trunk release button has a little metal like a hammer that hits the trunk lock to release if bent will not open or if you disable it by pushing it down to disable trunk release button the key lock is frozen will not work even if key go's in normal. need to replace it. if u need to get in your trunk and if it is empty would be easy to do just open the middle part of the back seat panel and with a thin and sturdy stick and flash light can hit the little hammer to open it . hope it helps
Trunk light on ~ trunk not open ~ alarm going off
look for a what is called a valet switch under the dash.(it is a pushbutton switch or a toggle switch.) Have somebody help you and turn the key all the way to where it wants to crank the engine and press the button switch or flip the toggle switch at the same time . within 5 seconds at least.your antitheft light will come on and your alarm will sound once. That should bypass the anti theft locking and reset the ECU .Then try to start the car. I don't know if it will work , but give it a try.
1helpful
1990 nissan maxima trunk release switch
Actually, this car has security system that prevent the trunk opened without using the master key. I often use this to lock my trunk. Just slid up the tiny lever upward to allow the trunk open from inside. the lever is on the back trunk (in the center, behind the Tail light) where the trunk door hook up with the lock system.
Cheers..
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
