Question about Tascam CC-222mkIII CD Player / Recorder
The CD tray will not open after the "welcome"
I hope you already have found the answer, but, I have 20 some odd Tascams in the field and this is the training that I give my operators. When a defective CD is in the drive (or one that the unit thinks is defective) you can turn off the machine and let it power down. Then when you power it up keep pressing eject before it has a chance to read the disk. It will go into eject mode before it will go into diagnostic mode and when the disk is out the machine don't let it go back in. Most of the time the machine goes back to working like it should.
Posted on Jun 09, 2011
SOURCE:
CR 248 cd tray will not open
It possible that a belt has broken or come off. You need to look inside. If you need a new belt just measure the diameter in MM and search Google for the nearest size to your measurement.
Dec 28, 2012 | Crosley CR248 Turntable
Hi - the CD tray cannot open. It is empty - no CDs in there. I hear a buzz, but an "error" message comes on. I tried pushing on the tray while turning on; I unplgged the CD player, I put it on...
The loading tray belt has more than likely stretched or snapped.
The buzzing you hear will be the motor spinning freely.
The 'ERROR' message will show up because the tray isn't opening
and activating the 'tray open' switch, therefore the 'tray closed' switch
is permanently activated after the 'open/close button is pressed.
Aug 20, 2011 | Marantz CC-4300 5-Disc CD Changer
CD/DVD burner in Compaq Presario 5010NX w/ VistaBasic Reads and any DVD but has problems with CD's. If I load a music CD, sometimes it will open right up and I can play the music. Most times it just...
Microsoft updates may not have the driver you are looking when it is searching for drivers. When you are in the device manager make a quick note to the name of the device and go to http://www.compaq.com/country/cpq_support.html
and see if you can match the device to the driver for your pc. If you are able to find the correct driver and install it and still receive the same results then the drive itself may have a problem.
Mar 14, 2011 | Compaq (CDD480172) CD-RW Burner
The tray will not open,have tried to pull it open,but get message saying,"tray error"
in this case your cd player is absolutely ok just motor of tray has damaged just open your cd player and replace dc motor you can buy it from any electronics equipment shop..just read the specification which is written on motor and then buy it...
Mar 14, 2011 | Audio Players & Recorders
Tray for cd won't open and it says "mechaical error." Unlike in the past there seems to be nothing stuck or askew inside. I left unit on overnight and tray was apparently open because I saw it...
you need to open the cover of your component and have access to the mechanical system of the CD. The timing gears might got dislocated and you need to manually adjust them.check also if there are belts that are broken replace them.
Mar 07, 2011 | Yamaha GX-505 CD Shelf System
Samsung BP-1500 problems When I tried to update the F/W to V 2.0 081106_21_XSA.RUF I encountered a problem. I now cannot play any dvd's and my Samsung LCD cannot connect with the player. this is what I...
Just contacted manufacturer with same problem.....your unit needs to be updated....check website...can be done with flash drive or burn a cd
Dec 19, 2008 | Televison & Video
Tascam CD-RW2000
THE CARRIAGE UNIT (CD TRAY) is damaged, replace the tray
or the drive
or u can use it as is until its dead
Nov 08, 2007 | Tascam CD-RW2000 Burner
Disc tray won't open
needs new tray drive belt
Feb 08, 2007 | Philips FWP900 System
Tascam CC-222mkIII CD Player / Recorder Logo
300 people viewed this question
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
